Attempting to extrude with no tool selected
  • I have a Anycubic Kossel and I'm trying to extrude filament for the first time. The extruder stepper motor does not turn.
    this is in config.g
    M350 E256 I0 ; configure microstepping without interpolation
    M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z80.00 E96.00 ; set steps per mm
    M566 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X720000.00 Y720000.00 Z720000.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30
    I got this error.
    G10 P0 S0
    Error: Attempting to extrude with no tool selected.
    M120 M83 G1 E-50 F3600 M121
    27/07/2020, 23:11:13T-1
    Error: Attempting to extrude with no tool selected.27/07/2020,
    23:11:13T-1
  • Hi,
    Did you select a tool first?
    You can do this from the web interface.
    Or you can add a T0 command to the end of your config.g file.
  • I'm not sure how to do this. What command do I use? Thanks for the help
  • I'm assuming you know how to navigate around in the Duet Web Control (DWC) interface.
    See attached to where you can click to select a tool.
    Or you can execute a T0 command from the DWC or add it to your config.g file.
  • Just open your config.g file and add T0 at the bottom of your config.g
  • Thanks guys, I'm such a noob lol. Well I'm learning.
  • Moderator
    @Elvis0z said in Attempting to extrude with no tool selected:
    I think you may also have an issue with your steps per mm and using x256 microstepping. I suggest you change to x16 microstepping with interpolation enabled on E for now.
  • @Phaedrux said in Attempting to extrude with no tool selected:
    How would I do that?
  • @Elvis0z said in Attempting to extrude with no tool selected:
    You have a command M350 E256 I0
    Simply delete that line and add E16 after the Z16 in the M350 line below.
  • Thanks heaps Phaedrux.
  • @fcwilt Thanks fcwilt
