    Help with Slic3r PE 2.2
    Example setups and prints
    • peirofundefined
      peirof
      I generally use CURA 4 to SLICE the models to print, but when switching to FW v3, I want to try Slicer PE .... But in the first model I try, I am having problems, it brings the supports up to the top face.
      I include some image captures:
      The model is a"Dragon hotend backpack"
      01 Model to slice
      02 Model Sliced with Slicer v2.2 PE 01
      03 Model Sliced with Slicer v2.2 PE 02
      04 Support Settings Slicer 2.2 PE
      THIS IS THE MODEL SLICED WITH CURA, SIMILAR SETTINGS, OK.
      05 Model Sliced with Cura 4 01
      I know this is not something directly related to the DUET board, but it is a forum where there are people who can help me ...
      Thank you
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @peirof
        @peirof that does seem odd... have you tried enabling 'support on build plate only'? I've found that is better where I can get away with it. It seems that's what you have in Cura?
        Is your model available somewhere so we can try recreating your issue? I can't find it on thingiverse
        i3 clone with a bunch of mods
        • peirofundefined
          peirof
          @engikeneer said in Help with Slic3r PE 2.2:
          ey....
          this is, thanks @engikeneer
