how can make fan 2 be a fan tool instead of fan 0 in duet 2 wifi
  • hi how can make fan 2 be a fan tool instead of fan 0 that does not work for me was probably short and the fuse burned I replaced another fuse ifind fuse 15 and now fan 2 and 1 work, and fan 0 does not work for me anymore, I tested it and tried to run fan 0 but it does not work itry M106 P0 S0 I0 H-1 not work, I connected to fan 2 and it works for me and I can control At cooling speed, the problem is that it is not controlled from the slicer how do I make it a fan tool thanks to the helpers
  • Moderator
    You would bind fan 2 to your tool command.
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
    M563 F2
  • @Phaedrux Thanks i reading It confused me A little.
    How do you write this?
    Just add to fan line like that.
    M563 P0 F2?
    or M563 f2?
    Maybe my 0 fan needs resetting that's why he doesn't work after a the fuse Destroyed
    Isee some gcode Interesting
    M562: Reset temperature fault
    There's one for the fan? M562 f0?
  • Moderator
    Post your current config.g.
    You will have an existing M563 in there to define the tool. It tells which heater to use, which extruder drive, and which fans to use.
  • @Phaedrux Thanks this is my config
    M563 P0 S"hotend" D0 H1 F0 ; define tool 0
    Ineed to change it to D0 H1 F2?
  • @Roei3d no.
    Can you post your whole config as theres more to set than just that
  • Moderator
    @Roei3d What firmware version are you using? Send M115 and post reply.
    For RRF2, you use the 'A' parameter in M106 to define which logical pin the fan is connected to. Logical pin numbers for fans are Fan0=20, Fan1=21, Fan2=22 (see https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers)
    So this will create Fan0 using Fan2 output:
    M106 P0 A22 S0 I0 H-1
    M106 P1 S0 I0 H45
    In RRF3, you define the fan0 on the fan2 pin with M950 first:
    M950 F0 C"fan2" Q500                           ; create fan 0 on pin fan2 and set its frequency
    M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
    You don't need to bind any fan to your tool (if you only have one tool) as fan 1 is thermostatically controlled anyway. Fan0 doesn't have to be bound to the the tool either; it just controlled from the slicer with M106 S[0-255] commands. So tool definition can just be:
     M563 P0 S"hotend" D0 H1 ; define tool 0
  • @jay_s_uk this is my all config
    M550 P"Ender 3 Pro BLV"                            ; set printer name
    M918 P1 E4 F2000000                                ; configure direct-connect display
    M551 P""                                   ; set password
    M569 P0 S0                                         ; physical drive 0 goes backwards
    M569 P1 S0                                         ; physical drive 1 goes backwards
    M569 P2 S1                                         ; physical drive 2 goes forwards
    M569 P3 S0                                         ; physical drive 3 goes backwards
    M584 X0 Y1 Z2 E3                                   ; set drive mapping
    M92 X80.00 Y80.00 Z400.00 E411	                   ; set steps per mm
    M566 X500.00 Y500.00 Z24.00 E3000                  ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E250.00               ; set accelerations (mm/s^2)
    M906 X700 Y700 Z700 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
    M84 S10                                            ; Set idle timeout
    M208 X245 Y230 Z240 S0                             ; set axis maxima
    M574 X1 Y1 S1                                      ; set active high endstops
    M574 Z1 S2                                         ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000                              ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-40 Y-12 Z1.582                          ; set Z probe trigger value, offset and trigger height
    M557 X20:235 Y20:220 S60                           ; define mesh grid
    M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 0
    M143 H0 S80                                        ; set temperature limit for heater 0 to 80C
    M305 P1 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 1
    M143 H1 S250                                       ; set temperature limit for heater 1 to 250C
    M106 P0 S0 I0  H-1 T45                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S0 I0  H1 T45                              ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S0.8 I0 F20 H1:0 T45                       ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    ; Pressure Advance
    M572 D0 S0.35
    M501                                               ; load saved parameters from non-volatile memory
  • @droftarts said in how can make fan 2 be a fan tool instead of fan 0 in duet 2 wifi:
    M115
    this is my m115
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
  • @droftarts thnks for the help this do the trick A22 change fan2 to fan 0 thanks',
    And another question fan0 has a different mosfet from fan 1-2 ? Could it be that FAN0's mosfet has burned out and the other fan 2 fan1 connections have a different mosfet?
