Heater fault on heater 0
When trying to heat up the print bed on my Ender 3 I set it to 80°C and when it reaches 80° it automatically gives me a fault message. I didn't have this problem when I was running early update of 2.05, but I think that when I last updated the firmware that is scrued everything up with the bed heating unit.
@Asabol please post the config to be able to check, and which hardware and exact firmware is used?
@JoergS5 ; Configuration file for Duet WiFi (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 19:34:06 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; physical drive 0 goes goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E741.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M305 P0 T98801 B4185 R4700 ; set thermistor + ADC parameters for heater 0
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M305 P1 T98801 B4185 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S255 ; set temperature limit for heater 1 to 255C; Fans
M106 P0 S0.45 I0 F20 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 F20 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F20 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool
Your temp limit for bed heater is 80. So when you set its temp to 80, its probably overshoots it by 1-2c and gives you fault or at leat warning message. If you want to heat your bed to 80, rise max limit of it by lets say 10C and all should be fine.
Also let as know what firmware version are you using, from console send M115 and post result here.
@aidar The printer says that I am using version 2.03.
I think aidar pinpointed the cause of your problem, but you should still consider updating your firmware to 2.05.1.
Easiest way is to download this zip file and upload it as is to the /sys folder via DWC.
@Phaedrux Ok thank you to both you and Aidar the printer works correctly know and it doesn't give me an error when I get up to 80°C.
