Ender 5 plus X ripple
This is across the X axis and each ripple is about 60mm apart , so I think is caused by wheels ? Is this normal amount of error ?.
Going to order some more wheels to see if I can fix it or even thinking of fitting linear guides.
Because it could be a case "does a falling tree make a sound if no one is there to monitor it ?"
does the pattern change if you use a different grid spacing?
@Phaedrux
That was 30mm spacing .
if I try 60mm spacing which is each ripple I get a flat graph .
and 15mm spacing
