    BL-Touch and problems
    35
    721
    • n3ovo
      n3ovo last edited by
      Hello Sorry i know i have read a lot of Help messages about the BLTouch. Well here is Mine. I am working on upgrading my cr10s pro and the old board went bad. I got the new DUET Ethernet with the 7" screen .. seem to take me no time getting thee system running and all back on line. At the same time i get the new board and had them send me BLTouch . Well there is where the problems start, as you can see i just got the new system and i might be missing something .. i have tried a lot of the forum reading and still can't get the #$%^&* working
      Board: Duet 2 Ethernet (2Ethernet)
      Firmware:
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1(2020-05-19b2)
      Duet 2 Ethermet v1.04c
      I think i am using PIN#31 on the Expansion plug
      I have checked the wires and plugs with a multimeter. I know the connections are good i used my own wire so the colors are off. And again i checked like them 20 time Over and Over.
      I tried
      HEATER 3 pin8
      HEATER 4 pin13
      HEATER 7 pin 31
      Before you ask i used blank plugs as place holders so that i could not put it on the wrong pin, never changed anything with power on! I am thinking that The BLTouch is BAD???
      Cinfig.g;
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 25 2020 21:43:23 GMT-0400 (Eastern Daylight Time)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"CR10s_Pro"                              ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M551 P"n3ovo3"                                 ; set password
      M552 P192.168.1.66 S1                          ; enable network and set IP address
      M553 P255.255.255.0                            ; set netmask
      M554 P192.168.1.1                              ; set gateway
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S1                                     ; enable FTP
      M586 P2 S1                                     ; enable Telnet
      M569 P0 S0                                     ; physical drive 0 goes backwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S300                                       ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S                           ; set axis minima
      M208 X300 Y300 Z400 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      ; BLTouch - via exp.heater7
      M307 H7 A-1 C-1 D-1                             ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M558 P9 C"^zprobe.in" H5 R0.2 F500 T4000 X0 Y0 Z1; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed
      M950 S0 C"exp.heater7"                          ;
      G31 P25 X11.5 Y-10 Z2.15                        ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X80:400 Y80:400 P5:5                       ; Define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S150                                   ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q600                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:0 T45                            ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M591 D0 C3 P1 E1 S1				               ; Turn on functionality for a filament run-out switch
      M575 P1 S1 B57600                              ; enable support for PanelDue
      401 and 402 do nothing ... when i turn the printer it cyclus 2 time probe go out a back in .. Stays read looks like it ready to go .. but nothing happens.. (Might also say i have never had a BLTouch so i am not sure what it should DO)
      I will include my retractprobe.g & deployprobe.g & Reset BLTouch & Test BLTouch
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P7 S10 I1 ; deploy BLTouch
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P7 S90 I1 ; retract BLTouch
      ;0:/macros/Fix Errors/1_Reset BLTouch
      M280 P7 S160 I1
      ;0:/macros/Fix Errors/0_Test BLTouch
      M280 P9 S120 I1
      I know someone will look at this and say i know what you did wrong ... beats me .. I love the lay out i gotten good at the program and love being able to edit files from the SYSTEM DIR...Very Very Cool. now if I can just get the BLtouch thing working 😲
      I am going to Upload my Config.zip if that might help:
      Config.zip
      Thanks for a great Board and Software
      John G (N3OVO)
        I'm not afraid to die,
      i just don't want to be there
      when it happens
      dc42 droftarts 2 Replies Last reply Reply Quote 0
        dc42 administrators @n3ovo last edited by dc42
        @n3ovo said in BL-Touch and problems:
        You mean M401 and M402 I presume?
        Remove that line from config.g. It's needed for RRF2 but not for RRF3.
        Remove the I1 parameter and use P0 not P7. Likewise in retractprobe.g. Again, this is because you are using RRF3 not RRF2.
        HTH David
        • PCR
          PCR last edited by
          M280 P7 S10 I1
          try a
          M280 P0 S10 I1
          because you mapped the PWM Channel with the M950 Command to GPIO 0
          for example (taken from the wiki)
          M950 S0 C"exp.heater3"  ; assign GPIO port 0 to heater3 on expansion connector, servo mode
          M280 P0 S80  ; set 80deg servo position on GPIO port 0
          • droftarts
            droftarts administrators @n3ovo last edited by droftarts
            Does the BLTouch do a self test at power on? This checks that it's getting power. Probably not, because...
            Servo "0" has pin defined on heater 7, so should be on pin 31. This is the tenth pin from the top in your picture. A little hard to tell, but it looks like you're on the ninth pin. Move it down one. See https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/vqBUAZPsxMC5tRgt.huge
            As @dc42 says, deployprobe.g and retractprobe.g are set up for RRF2, as are your test BLTouch macros. Use M280 P0 rather than P7, and no 'I1'. For more info, see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3 for correct format.
            • stuartofmt
              stuartofmt last edited by
              If it helps - I was setting up a BLT a week or so ago and (with help from this forum) ... here is the relevant section from my config.g
              M950 S0 C"exp.heater3"                        ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000           ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X42 Y5 Z2.21                         ; set Z probe trigger value, offset and trigger height
              M557 X45:220 Y10:220 S20                      ; define mesh grid
              In my case - exp.heater3 is pin8 (fourth pin from "bottom left").
              In your case - exp.heater3 is pin31 (as stated - 10th pin from "top left").
              • stuartofmt
                Edit to above post
                In your case - exp.heater3 is pin31 (as stated - 10th pin from "top right").
                • n3ovo
                  Hello Again ... I would like to THANK all who helped. I now have a working BL-Touch ... My wife and I Me where shocked, How fast you all answered me with help .. I does pay to get in a great group of people. It was on the wrong pin and I was was using the wrong commands for the wrong port .. so I am a happy camper..(I'm A HAPPY man) 😎
                  But as always one steep forward 2 steps in #$%^... i got it probing and it is doing good but i can not get it to start probing from the center of the bed for z-homing ( homeall or homez) Keeps wanting to home and the X-0 and Y-0 witch puts if off the bed and that will not work. I come to the wizards once again with G-Code In Hand
                  Ps if you would look over the CODE real quick and see if i made any more boo boos. thanks
                  M208 X40 Y-40 Z0 S                             ; set axis minima
                  M208 X375 Y375 Z400 S0                         ; set axis maxima
                  M558 P9 C"^zprobe.in" H4 R0.2 F1000 T4000 X200 Y220 Z1; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed
                  G31 P25 X25 Y5 Z3.15                           ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                  M557 X45:310 Y25:310 P6:6                      ; Define mesh grid
                  ; deployprobe.g
                  M280 P0 S10 ; deploy BLTouch
                  ; homeall.g
                  ; called to home all axes
                  G1 H2 Z7 F6000          ; lift Z relative to current position
                  G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X5 Y5 F6000       ; go back a few mm
                  G1 H1 X-305 Y-305 F240  ; move slowly to X and Y axis endstops once more (second pass)
                  G1 X-150 Y-150 F6000      ; go to first bed probe point and home Z
                  G30                     ; home Z by probing the bed
                  G1 Z7 F100             ; lift Z relative to current position
                  ; homez.g
                  ; called to home the Z axis
                  G1 X-150 Y-150 F6000 ; go to first probe point
                  As Always Thanks again
                  John Out (n3ovo)
                  when it happens
                  DIY-O-Sphere 1 Reply Last reply Reply Quote 1
                  • DIY-O-Sphere
                    DIY-O-Sphere @n3ovo last edited by DIY-O-Sphere
                    If the offset is set correct, you have to calculate the center by subtracting the values from the center.
                    As an example
                    When you bed is 335x335 (375-40, set by the limits in config.g)
                    335/2-25= 142.5
                    Change that line
                    to
                    G1 X 142 Y 142 F6000
                    Edit: In homeall.g and in homez.g
                    (UTC+1)
                    • n3ovo
                      oK THANKS Just fixed both all and z .. tried to do a mesh and i get error g29 "zprobe was not triggered during probing move"
                      this is because it homed to X and Y no problem but did not move back to the table before going down for first??
                      What did i do Now 😧
                      Ho and thanks ...
                      when it happens
                      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
                      • DIY-O-Sphere
                        @n3ovo
                        I'm not shure if I got you...
                        But the machine has to be homed completely before executing a G29
                        So run a G28 first
                        (UTC+1)
                        • stuartofmt
                          stuartofmt last edited by stuartofmt
                          One thing I would suggest is to set your Axis Limits like this
                          M208 X0 Y0 Z0 S1                            ; set axis minima
                          I suspect your current settings are confounding the situation.
                          Then take a look at your z-probe offset as measured in your G31 command. The distance from the nozzle to the probe in your case is 25mm in the X axis. The cr10s-pro looks to be (more-or-less) the same setup as on my Ender 5. Probe to the left of the nozzle when viewed from the front. It could be the mount but for reference - I have a 42 mm offset.
                          You can then play with the M557 command to keep the probing inside the bed. Lastly you may try this form of M557 - it probes in a grid pattern starting at the min X and Y positions with a distance specified by the S parameter (in mm). In this way there is no need (or advantage) to start probing from the middle of the bed. You could start with S40 to make it quicker (also helps with initial leveling using the bed leveling screws).
                          Remember to add something like this in your slicer pre-print code. Note that the G29 S1 makes sure that the results of the last bed-leveling (G29) are recalled. Personally - I do not do a G29 for each print - maybe once a week or if I am going to print something in fine detail.
                          M117 Homing
                          G28 ; home all without mesh bed level
                          G30 ; Do a single probe just to be sure
                          ;Optional Bed leveling - enable G29 when needed
                          M117 Leveling Bed
                          ;G29   ; uncomment to re-probe the bed
                          G29 S1 ; enable mesh
                          • n3ovo
                            Hello Again ... back with more questions and as alway the last answers help all of my past problems 😲
                            1. how big can the sd-card 64 ? 128?
                            2. I would like to add a camera to the system. is there just a wifi/wired small camera i can use for monitoring the printer at will get me a JPEG picture like it's neededs ( thought I see something before but forgot you look closer now i just forgot.
                            Now on to my next problem ... i have been working on my printer bed all this time as soon as i got the Bed Mash Compensation working ( and man was my bed messed up )
                            i got it all working but when i go to print it will not move down to the set height of printing nozzle. Stays at the bl-touch hight. ??? tried and tried. Worked all night on it and just can't get is to working . I know that it is something i have (Again) mist!
                            I am Sending my code but i don't think this will show anything. Also sending what i have tried to follow
                            M29 S1                                         ; Load height map from file, activate bed compensation default name 0:/sys/heightmap.csv
                            M92 X80.00 Y80.00 Z400.00 E136.00              ; set steps per mm started at 93
                            M84 S100                                       ; Set idle timeout
                            M208 X50 Y-25 Z0 S                             ; set axis minima
                            M208 X290 Y290 Z400 S0                         ; set axis maxima
                            G31 P45 X25 Y5 Z-2.90                           ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                            M557 X55:290 Y25:290 P6:16                      ; Define mesh grid
                            G10 P0 X45 Y0 Z0                                ; set tool 0 axis offsets
                            M501                                           ; M501: Read all stored parameters
                            ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                            • list itemCalibrate the Z probe trigger height
                              Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                              Cancel any currently active mesh compensation with M561
                              Use the X and Y jog buttons to position the nozzle over the centre of the bed
                              Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                              Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                              Jog the head up by 5 to 10mm
                            Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
                            Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                            In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                            Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                            To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.
                            when it happens
                            droftarts Phaedrux 2 Replies Last reply Reply Quote 0
                            • jay_s_uk
                              jay_s_uk last edited by
                              Your trigger height should be a positive value, not a negative value.
                              Change
                              to
                              G31 P45 X25 Y5 Z2.90
                              Wyze cam v2 https://wyze.com/wyze-cam.html can be used to transmit the required video for printer monitoring.
                              • droftarts
                                See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Specification
                                Spoiler: up to 32GB capacity, formatted as FAT32
                                See @jay_s_uk's reply for your Z height issue.
                                  Phaedrux Moderator @n3ovo last edited by
                                  ; Z-Probe ; BLTouch - via exp.heater7
                                  Remove the M307 line entirely. It's not used in RRF3.
                                  And remove the X200 Y220 Z1 from your M558 line, those values are not used there at all.
                                  Does your X axis endstop really trigger when the nozzle is 50mm inside the printable area?
                                  You're S parameter is missing the 1 there as well.
                                  • stuartofmt
                                    @n3ovo -- The gcode that I posted a few days ago should pretty much "just work" for you. Given the similarity between your Ender and mine.... Z offset will be different and you are using a different pin but other than that .....
                                    I'm still suspicious of your X axis offset. Can you include a picture taken from the front that shows the nozzle and the probe? It's hard for me to see that 25mm is correct given how most BLTs mount relative the the stock ender hotend. Having said that, anything is possible - but worth double
                                    checking.
                                    • n3ovo
                                      Thanks All, I Did my FIRST Print ( I will show Pictures Below ) All your help was just Wonderful to a newcomer. Don't be worried I will have more question .. hope that i can pass on to someone my help like you all did for me.
                                      I think I have fixed all errors in my config.g ( don't yell if i missed some there were a lot! 😲
                                      PXL_20200904_050511652.jpg PXL_20200904_050459312.jpg PXL_20200904_050450000.jpg PXL_20200904_050442914.jpg PXL_20200904_050434439.jpg PXL_20200904_050426396.jpg
                                      I know i can do better.but no to bad for the first print.
                                      sending my config.g just to see if i got it all worked out
                                      M208 X0 Y0 Z0 S 1                              ; set axis minima
                                      M208 X290 Y290 Z390 S0                         ; set axis maxima
                                      M558 P9 C"^zprobe.in" H4 R0.2 F1000 T4000      ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed
                                      G31 P45 X25 Y5 Z3.22                           ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                      M563 P0 D0 H1                                  ; define tool 0
                                      Thanks John G N3OVO
                                      when it happens
                                      • stuartofmt
                                        Congratulations on your first print - doesn't it feel great when that happens !!
                                        A couple of observations.
                                        I think your line for the axis minima may have an error (space between S and 1). I'm not sure if its an error but its not clear if to me how the interpreter will see it. i.e. I believe it needs to be
                                        Also - Its not clear that you have the correct form for your M557 line. The documentation is a little vague - but it does suggest the form you have is deprecated. Does your bed leveling actually happen ? The new form is to just define the bed limits and the probe interval.
                                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
                                        Good luck moving forward 🙂
                                        Phaedrux 1 Reply Last reply Reply Quote 1
                                          Phaedrux Moderator @stuartofmt last edited by
                                          @stuartofmt said in BL-Touch and problems:
                                          The M557 command he has in there is perfectly fine.
                                            It looks pretty good for a first print!
                                            Now that you have everything functional it's time to do some calibration. Mainly the extruder and all that entails. This guide might help you along.
                                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                                            Then you may want to look into tuning pressure advance once the extruder is calibrated.
                                            https://duet3d.dozuki.com/Wiki/Pressure_advance
                                            After that it's all a matter of learning the slicer settings.
                                            • n3ovo
                                              Just When you though it was SAFE ... More Problems... Printer is working .. Started tuning the printer and i seem to have a problem. It is only printing on one side of the bed. I tried to print a case for the i7 screen .. I know i am jumping the gun. I wanted to protect the Screen.
                                              Anyway here is a Picture Only the Right Half:
                                              As you can see it prints right up to the X limit Switch hits and the closes of the BOX .....
                                              Any thoughts Would help .. I know it is something that i have done Just don't know
                                              I am using CURA 4.7
                                              ;Cura 4.7 Config Before Printing
                                              M501 ;Read stored parameters
                                              M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                                              M203 X9000.00 Y9000.00 Z180.00 E6000.00 ;Setup machine max feedrate
                                              M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                                              M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                                              M220 S100 ;Reset Feedrate
                                              M221 S100 ;Reset Flowrate
                                              G28     ;Home All
                                              ;G29 S2  ;Reset Saved Bed Level
                                              G29 S0  ;Auto bed Level and then Use it
                                              G92 E0 ;Reset Extruder
                                              G1 Z2.0 F3000                   ;Move Z Axis up
                                              G1 X15 Y30 Z0.28 F5000.0        ;Move to start position
                                              G1 X15 Y275 Z0.28 F1500.0 E15   ;Draw the first line
                                              G1 X18 Y275.0 Z0.28 F5000.0     ;Move to side a little
                                              G1 X18 Y30 Z0.28 F1500.0 E30    ;Draw the second line
                                              G1 X150 Y150 Z2.0 F3000         ;Move to center of table then Move Z Axis up
                                              Here is My config.g
                                              M208 X300 Y300 Z390 S0                         ; set axis maxima
                                              G31 P45 X25 Y5 Z2.69                           ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                              when it happens
                                              • Veti
                                                Veti last edited by
                                                Test manually
                                                i assume from your config that the bed is 300x300
                                                issue G0 X0 Y0
                                                see that the head moves to one edge of the bed
                                                then issue G0 X300 Y300 and see if its moves to the opposite side of the bed
                                                n3ovo 1 Reply Last reply Reply Quote 0
                                                  M501 ;Read stored parameters M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration M203 X9000.00 Y9000.00 Z180.00 E6000.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                                                  Remove those lines from your cura start gcode. Also make sure that you have reprap gcode flavor selected.
                                                  It seems like your axis minima maxima is not quite right.
                                                  0,0 should be the front left corner of the bed. If the nozzle can go further to the left or front than that, the minima would then be negative.
                                                  • n3ovo
                                                    Just checked accordance on the printer If I type 0 0 it's up in the front left hand corner If I type 300 300 it's in the back right hand corner It goes to the center at 15150 I can hit any part of the bed and with a tape measure as close as I can possibly get it's right on the money So why is the program Why when I print does it go crooked It looks like when I print it it only thinks it has half a bed but only half on x why seems okay
                                                    when it happens
                                                    • BoA
                                                      BoA last edited by BoA
                                                      "Origin at center" in cura(or some other slicer You are using) machine settings perhaps ?
                                                      Or....
                                                      G10 P0 X45 Y0 Z0
                                                      Why Do You have tool offset 45mm for X axis ??
