    Belt Keeps Breaking During Prints
    troubleshooting
    • Ubelherzundefined
      Ubelherz
      It's been happening quite often-- I've been having issues with my Delta printer in which during a print, the nozzle gets stuck on part of the print and ends up destroying the belts in the process. Below are pictures of the most recent attempt-- the printer got stuck on the corner with the tears as shown.
      Any idea as to why it occurs?
      Thanks in advance!!
      arhiundefined 1 Reply Last reply Reply Quote 0
      • arhiundefined
        arhi @Ubelherz
        @Ubelherz said in Belt Keeps Breaking During Prints:
        How do you mean "destroying belts", I don't see how a nozzle catch can damage a belt ? Any images of the belt itself?
        (As for the question of why you have nozzle catch I'm not a delta expert so no clue how to and what exactly you need to calibrate to not have that problem, but it is probably calibration issue)
        • Vetiundefined
          Veti
          the belt should slip over the pulley before braking and the motor should skip steps way before.
          the force required to break a belt is quite significant.
