    Idle temperature hot-end and bed to high
    360
    • ddenundefined
      dden
      Hi, I just finished installing a duet2WiFi on my Ender3Pro and everything seems to work ok. Only funny thing is that the idle temperature of both my hot-end and bed are around 39 degrees Celcius. How can I calibrate these temperatures because in my opinion they should be in the low twenties and of course will also influence the temperatures in the high ranges. Hope someone can point me in the right direction.
      • Vetiundefined
        Veti
        post your config.
        did you follow the guide for the maestro and took the maestro resistance values for the duet wifi?
        ddenundefined 3 Replies Last reply Reply Quote 0
        • ddenundefined
          dden @Veti
          @Veti Yes I did. I followed the guide to the letter
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • ddenundefined
            dden @Veti
            @Veti I will post my config tomorrow, I just turned the printer off
            • Vetiundefined
              Veti @dden
              @dden said in Idle temperature hot-end and bed to high:
              that would be wrong as the duet wifi has different resistance value
              ddenundefined 1 Reply Last reply Reply Quote 0
              • ddenundefined
                dden @Veti
                @Veti Ok so now I am worried. Let’s dig in tomorrow
                • ddenundefined
                  dden @Veti
                  @Veti Below is my config
                  ; Configuration file for Duet Maestro (firmware version 2.03)
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Aug 28 2020 14:54:26 GMT+0200 (Central European Summer Time)
                  M550 P"Ender 3 Pro" ; set printer name
                  M552 S1 ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0 S0 ; physical drive 0 goes backwards
                  M569 P3 S0 ; physical drive 3 goes backwards
                  M350 X16 Y16 Z16 E128 I1 ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z400.00 E790.00 ; set steps per mm
                  M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X235 Y235 Z260 S0 ; set axis maxima
                  M574 X1 Y1 Z1 S1 ; set active high endstops
                  M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                  M557 X10:220 Y10:220 S20 ; define mesh grid
                  M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
                  M143 H0 S80 ; set temperature limit for heater 0 to 80C
                  M305 P1 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 1
                  M143 H1 S275 ; set temperature limit for heater 1 to 275C
                  M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S0 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 S0 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
                  M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  T0 ; select first tool
                  • Vetiundefined
                    Veti @dden
                    The Duet wifi can not do 128 with interpolation. only x16. Maestro can do x128 with interpolation
                    Adjust the E Steps accordingly.
                    Duet Wifi has a Resistance of R4700. R2200 is duet Maestro
                    ddenundefined 2 Replies Last reply Reply Quote 1
                    • ddenundefined
                      dden @Veti
                      @Veti Thanks I will correct these settings.
                      • ddenundefined
                        dden @Veti
                        @Veti I corrected the settings and now everything works like a charm. Thank you very much for your help. Much appreciated!!
                        droftartsundefined 1 Reply Last reply Reply Quote 1
                          droftarts administrators @dden
                          @dden you can just leave the R value out. The firmware knows the proper value from the hardware.
                          • ddenundefined
                            dden @droftarts
                            @droftarts Thanks good to know.
