    Ender 5+ and Duet 2 wifi Configuration
    • rexx
      rexx last edited by
      I have just finished step 1 for the connection of my duet 2 wifi. I am now working on step 2 wiring but would like to know if anyone has the configuration numbers for the Ender 5+ for step 3 as i am unable to locate any of the numbers i need ie.. esteps and questionable answers as they are all different from one person to the next. Also noting that another forum indicating that the BL Touch also requires additional coding as well. Hopefully someone can help me along. Is there a one file (zip) that someone has created for all this? Thanks in advance.
      • Veti
        Veti last edited by
        the ender 5 is very similar to the ender 3
        so if you follow the maestro guide
        https://duet3d.dozuki.com/c/Duet_2_Maestro
        this will get you quite far.
        note that duet wifi and maestro have different resistors for the thermistors. (R4700)
        esteps should be calibrated for each machine individually.
        • mitch
          mitch last edited by
          Another reference. I rewired my ender 5 pro for duet2:
          Here is my wiring diagram using Cat6 cables and the original Z axis wiring.
          https://drive.google.com/file/d/1IE73tfQX7RgpArzxZJwyxEA-VIYsMFzE/view
          I did add a BLtouch as well. My config is at the bottom:
          https://www.randoprojects.com/2020/07/26/ender-5-mainboard-upgrade/
