    Toolchanging Machine [Duet3]
    304
    • lavanyaaroraundefined
      lavanyaarora
      I'm building a toolchanger using e3d toolhead and tools.
      I have a duet 3.
      I plan on having 8 tools, for which I understand I need 8 toolboards and 2 distribution boards.
      Q1) can I use 2 distribution boards with just 1 duet (24V)
      Q2) Would it be enough to power 8 tools? (6 hemeras with supervolcano, 1 laser module, 1 CNC milling module)
      Q3) as for my CNC tool I'm really confused. Can I use any router? Does it need to be under certain watt and volts? Is there any website/company which sells milling toolhead which is small and programmable by board.. I mean I know I can control it's motion but can I control its speed? And would it be powered from mains or PSU
      Thanks!
      Happy Making
      dc42undefined TCundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @lavanyaarora
        @lavanyaarora said in Toolchanging Machine [Duet3]:
        I have a duet 3.
        The answer to Q1 and Q2 is yes. However, as your laser and CNC tools won't have heaters or stepper motors, using tool boards to drive them sounds like overkill to me. You can drive them from the Duet 3 main board instead. Tool boards are great for direct-drive extruders.
        I'll leave Q3 for others with more CNC experience to answer.
          lavanyaarora
          But how will I connect 6 hemeras to a single duet I will need some sort of expansion right
            lavanyaarora
            I also have 5 motors (3 for z)
              I meant that tool boards were overkill for the laser and CNC tools. You can use tool boards for the Hemeras.
              • TCundefined
                TC @lavanyaarora
                @lavanyaarora Where are you planning to have the rest positions for 8 tools? All at one side of the frame?
                TC
                lavanyaaroraundefined 1 Reply Last reply Reply Quote 0
                • Alex.crundefined
                  Alex.cr
                  @lavanyaarora
                  As for Q3:
                  What are you trying to cut? We might be able to lead you in the right direction. If you’re using the e3d tool changing system you will need a relatively small/lightweight solution.
                  E3d has come up with a small open source system for their tool changer machines designed to cut recently extruded parts called ASMBL. Link below.
                  I am currently planning a tool changer machine and this is the direction I plan on going. The tool changer mechanism and machine stiffness just don’t lend itself to much more than power and cutting capability.
                  https://e3d-online.com/blogs/news/asmbl
                  Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                    lavanyaarora @TC
                    @TC all at 1 side yes. Printed is over a meter tall and meter wide. Print surface is 615x615x640
                      lavanyaarora @Alex.cr
                      @Alex-cr I have looked at it, I just wished they would source the parts, assemble and sell as a tool head. I would pay 2x the cost. Their sourcing guide is not good
