    Improving mesh bed compensation with M558 HX
    1.8k
    • illyundefined
      illy @peter247
      @peter247 I always ran G29 S0 at full working temperature. 220c extruder temperature and 60c bed temperature. That's correct, right?
      @Phaedrux I tried to home Z with G28 Z command and it reported an error. This is my full config.g:
      ; Communication and general
      M575 P1 B57600 S0 ; Baud rate
      M111 S0 ; Debug off
      M550 PDISCOVERY ; Machine name
      ; Networking
      M552 S0
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M551 Preprap ; Machine password
      M586 P2 S0 ; Disable Telnet
      ; Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
      M552 P0.0.0.0 ; (0 = DHCP)
      M554 P192.168.169.255 ; Gateway
      M553 P255.255.255.0 ; Netmask
      ; Basic Settings
      M555 P0 ; Set output to look like RepRap_Firmware
      G21 ; Work in millimetres
      G90 ; Send absolute coordinates
      M83 ; but relative extruder moves
      M208 X-39 Y-10 Z0.0 S1 ; Set axis minima
      M208 X300 Y220 Z320 S0 ; Set axis maxima
      M143 H1 S295 ; Max. Extruder temp
      M143 H0 S125 ; Max. Heatbed temp
      M574 X1 Y1 S1 ; Set endstops at low side, active high endstop input
      M574 Z0 S2 ; Z endstop at low end, Z probe is used
      M558 P5 X0 Y0 Z1 I0 H5 A3 F120 T6000 ; Set Z probe type
      G31 P600 X32.7 Y35 Z0.5 ; Set Z probe trigger NEW
      M557 X67:270 Y75:265 S101.5:90 ; Define mesh grid NEW
      ; Axis and motor configuration
      M667 S0 ; Set Cartesian Mode
      ; Achsen Motor Richtung
      M569 P0 S0 ; Drive 0 goes backwards
      ; Extruder Motor Richtung
      M569 P4 S1 ; Drive 4 goes forwards
      M350 X256 Y256 Z256 E16:16 I1 ; Set 16x microstepping with interpolation
      M92 X1600 Y1600 Z8533 U1600 ; Set axis steps/mm
      M92 E2700:2700
      ;M92 E1800:1800
      M906 X1100 Y1100 Z900 E500 I30 ;E855 I30 ; Set motor currents (mA) and motor idle factor to 30%
      M201 X2000 Y2000 Z500 E120 ; Accelerations (mm/s^2)
      M203 X30000 Y30000 Z1200 E1200;E3000 ; Maximum speeds (mm/min)
      M566 X900 Y900 Z12 E40:40 ; Maximum instant speed changes mm/minute
      ; Thermistors
      M307 H0 A86.5 C432.2 D6.4 I0 B0 S1.0 V12.0
      ;M140 H-1 ;tells the firmware, there is no bed termistor
      ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P0 T100000 B3950 R4700 H30 L0
      ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
      M305 S"Extruder0" P1 T100000 B4725 R4700 H30 L0 C7.06e-8
      ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
      M305 S"Extruder1" P2 T100000 B4725 R4700 H30 L0 C7.06e-8
      M106 P0 S1.0 I0 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on; davor 500
      M106 P1 S1.0 I0 H2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1.0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P3 S1.0 I0 F500 H-1 ; Set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P4 S1.0 I0 F500 H-1 ; Set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0
      M106 P3 S0
      ; Tool definitions
      M563 P0 D0 H1 F2 S"Extruder0" ; Define tool 0
      G10 P0 R0 S0 ; Set tool 0
      M563 P1 D1 H2 F3 S"Extruder1" ; Define tool 1
      G10 P1 R0 S0 ; Set tool 1
      ; Definiert den X Offset
      G10 P0 X-32.7 L1 ; tool 0 offset
      G10 P1 X32.7 L1 ; tool 1 offset
      ; Prepare magnet control pins
      ;M307 H4 A-1 C-1 D-1 ; Heater 4 off for freeing the pin
      ;M307 H5 A-1 C-1 D-1 ; Heater 4 off for freeing the pin
      ;M42 P4 S0 ; switch on the magnet
      ;M42 P5 S0
      M208 S1 Z-0.2 ; set minimum Z
      ; Filament Sensor 0
      M591 D0 P2 S1 C3
      ; Filament Sensor 1
      M591 D1 P2 S1 C4
      ; SERVOS SETUP
      M307 H6 A-1 C-1 D-1
      M307 H7 A-1 C-1 D-1
      M42 P6 S0
      M42 P7 S0
      M570 H1 P3000 T50
      M570 H2 P3000 T50
      M98 P/macros/OVERRIDE_CFG_MACRO ;Run override macro of webinterface
      M98 P/macros/OVERRIDE_EXTRUDER_MACRO_0 ;Run override macro of webinterface for tools
      M98 P/macros/OVERRIDE_EXTRUDER_MACRO_1 ;Run override macro of webinterface for tools
      M572 D0:1 S0.2 ;Pressure advance
      G28
      M98 P/macros/T_freeAll ;Free all Tools
      M98 P/macros/OVERRIDE_NETWORK_MODE ;Run override macro for network
      Phaedruxundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @illy
        @sykb said in Improving mesh bed compensation with M558 HX:
        Yes trying to home just Z without first homing X and Y will lead to an error as I described. Does it give the error if you have X and Y homed prior?
        illyundefined 1 Reply Last reply Reply Quote 0
          It's not recommended to use x256 microstepping. It has a high load on the CPU for step generation and there's very little reason to use it. Use x16 with interpolation to x256 enabled. Lower cpu load and you still get the benefit of quiet smooth motor movement.
          • illyundefined
            illy @Phaedrux
            @Phaedrux I've just tried it. I commented out all the M564 commands and did not change another commands in the homing files. I homed X and Y first and then G28 Z. It reported the same error as before.
            @Phaedrux said in Improving mesh bed compensation with M558 HX:
            I'll try it later, thank you for the support!
              Phaedrux Moderator @Phaedrux
              Z15
              It's because your g1 x y move to position the probe also contains a z move. Z hasn't been homed yet so it's complaining. At the start of the file you're already lifting the z axis with an S2 move so you don't need to move it again afterwards.
              • illyundefined
                illy @Phaedrux
                @Phaedrux It's working now. Thank you! But my main problem is not solved yet. The mesh bed compensation does not compensate the uneven bed during printing as you can see in the pictures above. Maybe you also could help me.
                • Vetiundefined
                  Veti @illy
                  its hard to see from the picture, but it looks like the probe is in front of the extruder, so your offset is wrong it would be -Y35
                  • peter247undefined
                    peter247 @peter247
                    @sykb
                    @peter247 said in Improving mesh bed compensation with M558 HX:
                    @sykb
                    Is your off set correct ?
                    So this say your probe is 32.7mm to the right of the nozzle X axis and your probe is 35mm to the back of the nozzle Y axis , Correct ?
                    Yep , I think I was right ? , it does look like the probe is right front
                    Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                    • Vetiundefined
                      Veti
                      can you make picture that shows the entire bed and carriage?
                      • Damienundefined
                        Damien
                        After trying to figure out and finally figuring out(I think) how to input mesh grid for my printer which has center of bed as origin; I have decided to make my origin back to its original place in the corner.
                        I've decided this because I am not getting a good consistent squish across the various spots on my bed. Plus, I am not confident that the mesh on my bed that I got is correct. (See below)
                        I'm just about to redo my trigger height, but I have a question. In the guide(https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe), it calls for you to bring your nozzle to the center of the bed and do the paper test. Afterward, it asks you to begin your trigger height routine. BUT, here is my question...
                        Seeing as my probe offset is so far(x-60 Y-12), isn't it a better idea to bring the probe over the same spot I did the paper check to make sure I have a consistent base height? Or, does the programming for the G29 somehow compensate for this?
                        Thanks in advance!
                          Phaedrux Moderator @Damien
                          @Damien said in Improving mesh bed compensation with M558 HX:
                          Yes you can do that. It may help with any tilt inherent between the bed and the nozzle.
