Temprature sensor error unknown temperature sensor channel
@JTM said in Temprature sensor error unknown temperature sensor channel:
M575 P1 S1 857600
That should be B57600 not 8
This post is deleted! -
@Phaedrux Thanks for the help mate, did as you suggested and went to home all axis and got
G28 X
Operation has been cancelled -
I suggest going through this guide to ensure endstops are working and motors are moving are going the right direction.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
@Phaedrux Thanks for all your help Mate, still going through the checks, the motors and end stops seem to all be wired correctly and moving the right way, i keep getting this message when homing z
G28 Z
Error: in file macro line 9: G30: Z probe 0 not found
Error: Homing failedi will keep looking the M280 deploy and retract macros work but homing doesnt activate the probe so im guessing the Gcode for homing is missing something?
please post your revised config so we can see your current
M558
line that configures your z probe -
@bearerthis is the config.g file
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y450 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
;Miscellaneous
M575 P1 S1 B57600
M501 -
i think you might need
C"^zprobe.in"
added to the line withM558
?M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
edit: presuming thats where your zprobe is connected?
@bearer said in Temprature sensor error unknown temperature sensor channel:
C"^zprobe.in"
Genius ! thanks mate did the trick now homes all axis ! temp sensor works, extruder works all i need now is to calibrate i think woohoo !! thanks so much to everyone for your help !
M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
Can't believe I didn't catch that!
@Phaedrux you guys are awesome ! appreciate the help as i'm as green as it gets almost ! lol
Ive calibrated my steps so now all axis move the perfect distance, extruder extrudes exactly 100mm when i tell it too, only issue i have is homing Z. I have used the test and calibrate procedure in this link https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
i have done the calibration several times i manually move the bed up to be catching a width of paper, send M92 Z0 comand to set sero. i then drop the bed down 10mm and send G30 S-1 and i consistently get an av figure of 1.8mm. Now i changed my congig.g code which was G31 X0 Y0 Z0 P25 to G31 X0 Y0 Z1.8 P25 and it still home 14mm high ? am i doing something wrong obviously? -
1.8mm trigger height sounds reasonable. 14mm high? Where is that coming from? How are you measuring that? After homing if you jog to z0 the nozzle should be touching the bed.
@Phaedrux i have a E3d super volcano on this machine so i measure from the bottom of the block with a ruler to the bed and it homes 14mm high every time. i can move the nozzle to the bed via the controls sure, but i thought it would home to the required printing height each time if set correctly?
@Phaedrux when i home Z it raises the bed hits the Zprobe then the bed drops 10mm or so?
@JTM what height does DWC report Z is at after homing Z? If 0, but nozzle is off bed, post your homeall.g and homez.g
@droftarts its says 0 on the console
homeall :
generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:10 GMT+1000 (Australian Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningHome z:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:11 GMT+1000 (Australian Eastern Standard Time)
G1 X15 Y15 F6000 ; go to first probe point
;G90 ; absolute positioning -
The print height gets set by the slicer.
The important thing is that after homing you can do a G90 G1 Z0 move and the nozzle touches the bed. If that works, then when you start the print it will go to the right height.
Maybe show a photo of what you mean with the 14mm if you still think something is wrong.
@Phaedrux said in Temprature sensor error unknown temperature sensor channel:
G90 G1 Z0
that did the trick ! so when the print starts it moves to z position 0? i didnt know that. I am trying a print lets see what happens but im finding i have to heat the extruder manually before starting a print. Ill figure it out tommorow
![0_1600329782267_E2B2A79B-9311-4AC2-BCFF-1A5728E3112A.jpeg](Uploading 100%) I have started a print almost completed ! There are a couple of bugs to iron out but this board is amazing! So quite ! I have the wrong nozzle for the print as it was a rush to see it working but almost done! Just printing in reverse ! Lol but Iām sure there is an easy fix for it !
Thanks heaps guys I really appreciate all the help ! -
you have to wait a bit after the image upload reaches 100% otherwise the image will no be displayed
