Controller for my larg format 3D printer
  • Hello,
    I'm new to this forum and this is my first post.
    I am looking for information regarding the electronics to use for my large 3D printer which I am finalizing these days. At the moment I can get the axes to move with a simple Arduino + Ramps, but from here to print there is a big difference!
    The printer has a useful printing area, for now, of 600x600 mm, with 600 mm of travel for the Z axis (maximum useful dimensions of 1800x900x1800 mm).
    The print bed is fixed, the XY plane moves "up and down".
    At the 4 corners of this plane there are guides (round in the prototype, ball recirculating on the final version), with motors and ball screws. So 4 guides, 4 motors and 4 ball screws.
    This plan should be calibrated every time the Z axis is zeroed, to do this I thought of controlling the 4 motors independently and using the (optical) limit switches, 1 for each motor, in order to have a fixed reference for each edge of the XY plane.
    The head will currently house a single MK8 type extruder. A different extruder will be mounted in the future.
    On the final version there will be the possibility to mount up to 3 extruders at the same time, to have 3 different materials to be used during printing.
    A heated surface is provided for the current version, 2 separate ones for the possibly higher version.
    A heated chamber is also provided.
    The connection between with the printer should be both wi-fi and ethernet.
    An SD-Card slot and a USB port must be present.
    Finally, a light indicator is required for the status of the machine (on, in operation, heated chamber, end of printing, etc ...) and an emergency button.
    In summary:
    1 X Axis motor
    1 Y Axis motor
    4 Z Axis motors
    3 Extruders
    2 X Axis optical limit switches (minimum and maximum)
    4 Y axis optical limit switches (2 minimum and 2 maximum)
    8 Z axis optical limit switches (4 minimum and 4 maximum)
    1 heated floor
    1 heated chamber
    light indicator
    emergency button
    At the moment the engines are Nema 17 powered at 24 volts.
    A larger version with Nema23 motors powered at 48 volts is planned.
    Which controller should I use to be able to manage my printer in a safe and efficient way?
    Thank you
    Bernard
    P.S .: sorry for my English
  • @bernardomattiucci said in Controller for my larg format 3D printer:
    1 X Axis motor
    1 Y Axis motor
    4 Z Axis motors
    3 Extruders
    1 Duet_3_Mainboard_6HC
    1 Duet_3_Expansion_board_3HC
    The duet only needs 1 endstop on one side. the other is enforced by software.
    the duet does not regard endstops during normal operation, only homing moves.
    so with the duet you only need 1 y and 1 y endstop.
    z endstops would be best replaced by a probe. this allows you to use independant z levelling using multiple motors.
    https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
    duet only support up to 32V see
    https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview
    VIN in the range 12V-32V must be provided to the Duet.
    1 heated floor
    1 heated chamber
    https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_a_chamber_heater
    emergency button
    see https://duet3d.dozuki.com/Wiki/Connecting_an_Emergency_Stop
    light indicator
    4-pin DotStar LED strip connector: This is to connect and power DotStar LED strips. In firmware 3.01 there is also experimental support for NeoPixel LED strips. When using NeoPixel, connect the Duet DO pin to Neopixel DI and leave the Duet CLK pin not connected. A maximum of 50 NeoPixel LEDs can be controlled. Caution! The total current draw of the Raspberry Pi (including any attached USB devices), DotStar LEDs and other devices powered from the 5V and 3.3V rails on the Duet must not exceed 3.0A.
    what about a paneldue?
    https://duet3d.dozuki.com/Wiki/PanelDue
    if you use the raspberry pi version of the duet the connections of the pi are used.
    sd slot is there, the paneldue has a seperate one. usb is there, but connection via the web interface is better
  • Ok, Thank's.
    I enclose a functional diagram of what I understood by reading the documentation. Probably some connection is wrong, in which case I would be happy to get further suggestions.
    I'm not sure if the hot ends are connected correctly. But at the moment the priority is to take the electronics and get the car moving!
    Thank you
    Bernardo
    there are currently some limitations
    see
    https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
    Filament monitors for extruders driven by expansion boards and tool boards are not yet supported. Support is planned in release 3.3.0. The filament monitor will need to be connected to the board driving the corresponding extruder.
    A heater on an expansion or tool board can only be controlled by a temperature sensor on the same expansion board.
    As @Veti says, the thermistors for the extruders should be connected to the expansion board. Support for filament monitors for extruders connected to expansion and tool boards is one of our highest priorities, and I expect to start work on that for the 3.3 release even before 3.2 stable is released.
    If your extruders are direct drive and have modest motor current requirement, you may wish to consider using three tool boards instead of one 3-channel expansion board, because it will simplify the wiring to the tool heads.
    For maximum fail-safeness, I suggest you connect the emergency stop button to the main board if possible.
    You have only shown one fan per extruder. Do you not have print cooling fans as well as heatsink fans?
  • Right now, my top priority is to get the car moving in the best way.
    In the prototype that I have already assembled (and which "moves" with Arduino + Ramps), several components are still missing, such as the heated bed or the walls of the room.
    In addition, only 1 extruder will be mounted for the moment.
    In the diagram I tried to insert everything that came to my mind and that concerns the prototype in the 3D printer version.
    In reality the head, in the final version, will have 2 extruders or a laser diode or a small cutter for soft materials. But they are still ideas for later versions.
    At the moment I am interested in being able to move the printer with the self-leveling and MK8 extruder that I have on the old printer. The rest will come calmly and in the future!
    Consequently, I can connect the hot end directly to the mainboard by eliminating some pieces that are not needed at the moment.
  • @dc42 said in Controller for my larg format 3D printer:
    we have time to do everything!
    I am not an expert in this electronics (until now I have only made CNC with breackout board, driver and linuxCNC) and that is why I asked for information.
    I am making this machine for myself, but I would like to put a larger version of it on the market. I am open to any suggestions and / or collaboration ... because I think the project is interesting!
    Yes, No problem
    I forgot about it
    To clarify the point about tool boards:
    • If the extruders will be direct drive, then for each extruder you are likely to have 4 motor wires, 4 fan wires, 2 heater wires, 2 thermistor wires. That's 12 wires going to the hot end assembly (with the possibility of reducing it to 10 if you share the V+ wires to the heater and fans). if you want to add a BTouch, that's 4 more wires. if you want to use fans with tachos, even more wires.
    • A direct drive extruder with a tool board mounted on the extruder assembly needs just power and ground, plus 4 CAN wires (which can be reduced to 2 if the wires are not too long). That's even if you use fans with tachos and a BLTouch. For the case of a single extruder, it also costs less, even if you include a tool distribution board to make future expansion easier.
    • If the extruders are not direct drive, then it's probably simpler to use the 3-channel expansion board instead.
    Think of an tool board as a single-channel expansion board, small enough to be mounted on the tool head, and with lower maximum motor current than the 3-channel expansion board.
  • how long is "not too long"? 750mm? 500mm? "Depends"?
    @oliof said in Controller for my larg format 3D printer:
    I suspect that 1m would be OK. Ideally, ferrite beads would be added at one end of the cable, to reduce reflections.
  • The "small" (this one) has a useful print volume of 600x600x600mm expandable up to 1200x1200x1200 with Nema17 motors. The moment of the X and Y axes is a toothed belt with recirculating ball guides. Z axis with recirculating ball screws and recirculating ball guides.
    The "large" version uses Nema23 motors instead and will have useful dimensions of 1000x1000x1000 mm expandable up to 3000x3000x3000 mm. The movement of the X and Y axes is by rack with linear encoder. Z axis with recirculating ball screws and recirculating ball guides.@oliof
    this project
    My prototype (pictured) uses structural and mechanical parts recovered from old CNCs and 3D printers and has a useful volume of 600x600x600mm.
  • @dc42
    this Toolboard?
  • yes that is the one
    More info on the tool board at https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board.
  • @dc42
    beautiful
  • Hello to you, fellow large format printer maker 😉
    Instead of this, I'd suggest you to use only one limit switch at the top of one of your Z axis corner and install a BL touch or any other probe you like somewhere on your tool head.
    The printer will first go to its home position, moving until it hits the endstop. Then it will go down until the Z probe hits the bed. Next step will be to probe each corner, near your leadscrews. After that, the printer will adjust the bed to make it leveled automatically.
    I only have 2 Z axis on my printer but that's how I did it, same principle for you there with 4 axis. It's much easier to do it this way.
  • @MrDui
    Thanks for the suggestion, very interesting!
  • Ok
    If I am not mistaken, then, I should take the following:
    1 Duet 3 Mainboard 6HC +
    1 Duet Toolboard +
    1 Duet PanelDue 7" +
    1 BLTouch
    Correct?
    1 Duet Toolboard +
    if you want 3 extruders, then you need 3 toolboards or 1 Duet_3_Expansion_board_3HC
  • @Veti
    at this moment i only need 1 extruder
    Thank you
    Bernardo
    You might also want to buy a Tool Distribution board. You can manage without it, but it make wiring easier when you add more extruders. If you don't use one, you will need add a CAN termination resistor, and provide a fuse in the VIN feed to the tool board. See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Connecting_CAN_FD_Bus_and_Power.
  • Good morning,
    is there the possibility of having the 4 motors of the Z axis of the "closed loop" type with 4 linear encoders mounted on the recirculating ball guides placed at the 4 edges of the XY plane?
    Not yet, but we have a closed loop expansion board for Duet 3 under development.
  • Ok, then I have to wait ^ _ ^
    Thank you
