Printer randomly stops and disconnect.
  • Hi there,
    I'm using duet for almost 2 years now. I'm using on a delta build, the printer was printing fine until last night. It started to randomly disconnect and restart the printer. I tried a firmware upgrade from 3.1.1 to new beta but the issue remains.
    The printed the STL file several times before the issue appears so the STL file should be fine.
    edit: The error happened without printing anything as well.
    I have tested just printer on: no reset
    Printer on with bed heater on: no reset
    Printer on with part cooler fan: reset happened.
    Printer on with just hotend fan on: reset happened.
    Printer on just with only hotend(no fan): reset happened.
    I checked the wire connections, they seem good.
    Console Info
    22.09.2020 13:02:58 	Connection established
    22.09.2020 13:02:57 	Connection interrupted, attempting to reconnect...
    HTTP request timed out
    22.09.2020 12:40:31 	Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
    22.09.2020 12:40:26 	M32 "0:/gcodes/Planters/Pumpkin/Pumpkin_face_sh.gcode"
    File 0:/gcodes/Planters/Pumpkin/Pumpkin_face_sh.gcode selected for printing
    M122 output
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-9T6BU-FG3SN-6J1DL-3S46L-1SYHD
    Used output buffers: 3 of 24 (11 max)
    Static ram: 23916
    Dynamic ram: 98384 of which 76 recycled
    Exception stack ram used: 272
    Never used ram: 8424
    Tasks: NETWORK(ready,139) HEAT(blocked,294) MAIN(running,410) IDLE(ready,20)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:48 ago, cause: software
    Last software reset at 2020-09-22 13:02, reason: StuckInSpinLoop, GCodes spinning, available RAM 7988, slot 0
    Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000409c Task MAIN
    Stack: 0041d5fd 00454a80 610f0200 3f800000 3ba3d000 43e07852 38969000 3f2ec33d 463b8001 00000000 424d5110 4bf13662 3f60d385 3f828f5c 453b8001 00000000 38533333 3f800000 3f800000 20000010 00000000 0000400f 00000000 00000001 0041cc09 0000400f 0041d5fd
    Error status: 0x020
    MCU temperature: min 46.5, current 47.1, max 47.7
    Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: position 89004, standstill, SG min/max not available
    Driver 1: position 89004, standstill, SG min/max not available
    Driver 2: position 89004, standstill, SG min/max not available
    Driver 5: position 0
    Driver 6: position 0
    Driver 7: position 0
    Driver 8: position 0
    Driver 9: position 0
    Driver 10: position 0
    Driver 11: position 0
    Date/time: 2020-09-22 13:03:37
    Cache data hit count 82611817
    Slowest loop: 31.27ms; fastest: 0.15ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 2.1ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 81.40ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is active
    WiFi firmware version 1.23
    WiFi MAC address 84:f3:eb:42:b4:09
    WiFi Vcc 3.35, reset reason Power up
    WiFi flash size 4194304, free heap 23872
    WiFi IP address 192.168.1.42
    WiFi signal strength -59dBm, reconnections 0, sleep mode modem
    Clock register ffffffff
    config file
    ; generated by RepRapFirmware Configuration Tool v3.1.1 on Fri Jun 05 2020 15:51:32 GMT+0300 (GMT+03:00)
    G90                                                  ; send absolute coordinates...
    M83                                                  ; ...but relative extruder moves
    M550 P"3DPBD"                                         ; set printer name
    M665 R105.5 L215.79 B85 H250                          ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0                                        ; put your endstop adjustments here, or let auto calibration find them
    ; Network                                                       ; Set machine name
    M552 S1                                                             ; Enable network
    M587 S"**********" P"**********" I192.168.1.42 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
    M586 P0 S1                                                          ; Enable HTTP
    M586 P1 S1                                                          ; Enable FTP
    M586 P2 S1
    M569 P0 S1                                           ; physical drive 0 goes forwards
    M569 P1 S1                                           ; physical drive 1 goes forwards
    M569 P2 S1                                           ; physical drive 2 goes forwards
    M569 P3 S0                                           ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                                     ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                              ; configure microstepping without interpolation
    M92 X200.00 Y200.00 Z200.00 E860.00                  ; set steps per mm
    M566 X2400.00 Y2400.00 Z2400.00 E1200.00             ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00          ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z3000.00 E1000.00             ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30                         ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                              ; Set idle timeout
    M208 Z-0.1 S1                                        ; set minimum Z
    M574 X2 S1 P"xstop"                                  ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop"                                  ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop"                                  ; configure active-high endstop for high end on Z via pin zstop
    M558 P5 R0.4 C"zprobe.in+zprobe.mod" H10 F1200 T2400 ; set Z probe type to effector and the dive height + speeds
    G31 P500 X11 Y0 Z2.5                                 ; set Z probe trigger value, offset and trigger height
    M557 R80 S20                                         ; define mesh grid
    G31 P100 X0 Y0 Z-0.15						    ; select probe threshold 100, trigger height -0.1, and zero XY offsets
    M308 S0 P"bedtemp" Y"thermistor"  T100000 B3950 C0 R4700      ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                                ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 B1 S1.00                                     ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                              ; map heated bed to heater 0
    M143 H0 S90                                         ; set temperature limit for heater 0 to 90C
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 C0 R4700          ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                                 ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
    M143 H1 S270                                        ; set temperature limit for heater 0 to 270C
    M950 F0 C"fan0" Q500                                 ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                       ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                                 ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H-1                                       ; set fan 1 value. Thermostatic control is turned off
    M950 F2 C"fan1" Q500                                 ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S1 H1 T55                                    ; set fan 2 value. Thermostatic control is turned on
    M106 P1 T55 H1								; Fan1 (hotend fan) 55 dereceye gelince otamatik çalışacak.
    M563 P0 D0 H1 F0                                     ; define tool 0
    G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
    G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"   ; set voltage thresholds and actions to run on power loss
    T0                                                   ; select first tool
    M501
    Added gcode just in case:
    https://drive.google.com/file/d/1UV3N9EP4Mat29JB7NouU1rkMbhNFI9Fp/view?usp=sharing
  • Moderator
    @reahax said in Printer randomly stops and disconnect.:
    Error status: 0x020
    For the error status, @dc42 informs me there is a bug in 3.2b1 and the leading '02' should be ignored. So the error status shows no error. For the rest of the M122 report, I think it just shows a reset while printing.
    With the above, it does rather sound like a wiring fault.
    Additionally, in your config.g:
    Remove, or at least comment out, M587 line. As well as a security hazard, it's wearing out your WiFi flash memory. See note at end of https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
    It's unlikely your're using zprobe.mod for anything, so remove '+zprobe.mod' from the above. You also have two G31 commands after this; it'll be using the second one. Probably best to delete the first.
  • @droftarts said in Printer randomly stops and disconnect.:
    Error status: 0x020
    Thanks for your help, I will check wire connections again.
    I'm using smart effector, does smart effector have anything
    with or it's safe to remove?
  • Moderator
    Ah, sorry, in that case leave it in.
    Try testing for reset with fans disconnected and/or heater disconnected. This should show if it's the board or the wiring.
  • @reahax Did you try replace sd card? I compiled (I hope correct version) firmware and checked map file. According to stack in you M122 the issue is reading blocks.
  • Yeah without any wire connection printer still resets.
    Thanks for this info, I can try with replaced sd card. It's okay to copy files to another sd card?
  • @reahax Yes, it's ok
  • Thank you @felek
    When I insert the sd card to pc got:
    "please insert the last disk of the multi-volume set and click ok to continue" message from windows. However, I copied the files another card, and the printer works fine at the moment.
  • Moderator
    2 years of use on a small SD card is pretty good.
