Duet 2 Z Axis Stepper Beeping
  • I am trying to set up a printer using a Duet 2 Wifi and am having trouble with the Z axis stepper. Any time I send a movement command to the stepper it seems to try to move and makes a beeping sound. All of the other stepper drivers are working.
    If I move the Z stepper to a different driver the stepper works and if I move another stepper to the Z driver it still makes the beeping sound so it seems to be something with the board.
    If anyone could give any insight as to why the Z axis might not be working or any troubleshooting steps I could take it would be much appreciated!
  • Can you Post your congig.g?
  • See attached. Thank You!
    config.g
  • Moderator
    Can you also post the results of M122 and M98 P"Config.g"?
    What kind of beeping sound are we talking? Can you record it with your phone?
    This is a hang printer?
  • @Phaedrux We have figured it out. the steps per mm were not defined for the Z axis but were for the other two axes
