    g32 reporting
    267
    • tracar
      tracar last edited by
      is it normal for the Duet2 wifi to report this more than 1 time when only one G32 is done ?
      9/29/2020, 9:00:27 PM M98 P"0:/macros/BLTouch/G32 to level bed"
      Leadscrew adjustments made: 0.079 0.082, points used 2, (mean, deviation) before (0.080, 0.001) after (0.000, 0.000)
        What firmware version are you running?
        How did you initiate the g32?
        Where is the report showing up multiple times?
        tracar 1 Reply Last reply Reply Quote 0
        • tracar
          tracar @Phaedrux last edited by
          @Phaedrux
          3.1.1
          g32 was initiated ftom the web interface terminal
          in the console
          • fcwilt
            fcwilt last edited by
            Could you post your bed.g file?
            Thanks.
            • tracar
              tracar @fcwilt last edited by
              @fcwilt
              ; bed.g
              M400 ; Finishes all current moves and clears the buffer
              G4 S1 ; wait 1 second
              M280 P0 S160 I1 ; Alarm Release and Push-Pin UP
              M402 ; Retract probe just in case it's down
              M561 ; clear all bed compensation
              G28 ; home all axis
              G90 ; absolute positioning
              G30 P0 X440 Y291.5 Z-99999 ; probe near a leadscrew, half way along Y axis
              G30 P1 X0 Y291.5 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
              G1 X220 Y318 F8000 Z10 F800 ; move probe to center of the bed
              G30 ; set Z0 position with the probe
              M402 ; retract probe
              ; uncomment as needed to probe a height map after an auto bed level OR not and use an old map
              ;G29 S0 ; Probes and makes a new probed height map
              ;G29 S1 ; loads a previously saved height map
              fcwilt 1 Reply Last reply Reply Quote 0
              • fcwilt
                fcwilt @tracar last edited by
                @tracar said in g32 reporting:
                ; bed.g
                G28 ; home all axis
                JOOC why did you include the commands in bold? I have nothing like them and everything seems to work.
                Thanks.
                • tracar
                  tracar last edited by tracar
                  here is the problem:
                  i mean to say when i do a bed level ( only once ) i get many reports back at the same time.
                    The macro you're running in your screenshot is not bed.g
                    • tracar
                      @Phaedrux said in g32 reporting:
                      it was a G32 from a macro containing only this:
                      G32 ; level bed
                      the above screen shot is what the duet posts back, it is not all the time, like every tenth g32..
                        Alright, so to recap, occasionally running G32 will output the results multiple times to the console and the DWC popup.
                        Do you happen to have any leveling code in your homeall? Just asking because it gets called in bed.g
                        • tracar
                          homeall
                          No leveling code in Homeall..
                          you answered it, if it occasionally does this then all is ok.
                          thanks for the reply
                            I wonder if it's a firefox thing. Is that windows 7?
                            • tracar
                              yes win7
