    PanelDueFirmware 3.2-RC3 released
    PanelDue
    507
    • wilriker
      wilriker Moderator last edited by
      I am pleased to announce the third release candidate for PanelDueFirmware 3.2. This release contains primarily bug fixes and a few small changes in behavior. See below for details.
      Version 3.2-RC3
      Upgrade Notes and Limitations
      See 3.2-RC2
      Changes since RC2
      • Extrusion and retraction commands are now a single line to prevent being interleaved by other commands
      • Screensaver is now a popup to better interact with existing or incoming popups
      • No longer fetch detailed M409 for Fans or Sensors (as they are currently not required)
      Bug Fixes since RC2:
      • Screensaver timeout select pop-up would not disappear when clicking anything but "Set" or a tab button
      • Extrusion factor was not always targeting the correct extruder
      • Extrusion factor controls were not hidden if amount of tools was decreased
      • Bed and chamber controls were not hidden if they were removed from config
      • If a JSON key path was too long it would result in an endless fetch-loop
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2-RC3
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      • wilriker
        I just released 3.2-RC3+1 with one additional bugfix. I expect this to be the last release candidate before releasing 3.2 final.
        Version 3.2-RC3+1
        Bug fixes:
        • Message box was not closed on PanelDue if closed e.g. in DWC
        Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2-RC3%2B1
        Manuel
        My Tool Collection
        • oozeBot
          oozeBot last edited by
          Thanks. We'll update all our panels this morning and report back with any issues.
          @wilriker - one item I'd like to ask, with the introduction of the Object Model, could Baby Steps be modified to mirror what's set in DWC instead of being fixed at .02mm?
          wilriker 1 Reply Last reply Reply Quote 0
          • wilriker
            wilriker Moderator @oozeBot last edited by
            @oozeBot said in PanelDueFirmware 3.2-RC3 released:
            Baby step amount in DWC is a DWC-local setting that RRF does know nothing about. Therefore unfortunately this cannot be mirrored to PanelDue.
            Manuel
            My Tool Collection
            • BoA
              BoA last edited by
              I would like to se a setting for baby steps - step in paneldue πŸ˜„
                Current babystepping amount is present in the OM already, it's in move.axes[n].babystep.
                • wilriker
                  wilriker Moderator @dc42 last edited by
                  @dc42 I think the request is rather about the amount to be applied when pressing the babystep buttons.
                  Manuel
                  My Tool Collection
                    Ah, I misunderstood.
                    • wilriker
                      wilriker Moderator @BoA last edited by
                      @BoA said in PanelDueFirmware 3.2-RC3 released:
                      This can be added quite easily. Though, I would like to fix this to 4-6 preset values because user-input is always quite tricky.
                      How about:
                      • 0.01
                      • 0.02
                      • 0.05
                      • 0.1
                      Something smaller? Something larger? Something completely different?
                      Manuel
                      My Tool Collection
                      oozeBot 1 Reply Last reply Reply Quote 2
                      • oozeBot
                        oozeBot @wilriker last edited by
                        @wilriker that would certainly cover it for us! However, long term, I'd still suggest syncing this with DWC through the Object Model.
                        Thanks!
                        • wilriker
                          Once user variables have been implemented in RRF this would be very easy.
                          Manuel
                          My Tool Collection
                          • oozeBot
                            I wanted to report back that I'm seeing an M291 S3 popup on the PanelDue fail to display randomly..
                            I'll be doing more testing today and through the weekend, so maybe I can put my finger on the exact scenario which is causing it.
                            To quickly describe where I've seen it happen, it's at the beginning of a job when homing - I have an M291 S3 command in my homez.g file. It's here that sometimes the popup is never displayed on the PanelDue.
                            Thanks
                            • docbobo
                              docbobo last edited by
                              I just set up my 5i with an BTT SKR 1.4 Turbo using 3.2-RC3 together with all the other betas (DWC, DSF, FW).
                              At least for me, M300 doesn't result in any sound coming out of the PanelDue, even though it does beep when I am pressing some of the buttons.
                              Am I missing anything there?
                              BoA 1 Reply Last reply Reply Quote 0
                              • BoA
                                BoA @docbobo last edited by
                                @docbobo I would say M300 is processed by the board, not the panel. If Your board has no "beeper" then no sound πŸ˜‰
                                docbobo 1 Reply Last reply Reply Quote 0
                                • docbobo
                                  docbobo @BoA last edited by
                                  @BoA Well, the documentation seems to say
                                  Play beep sound, use to notify events like the end of printing. If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
                                  wilriker BoA 2 Replies Last reply Reply Quote 1
                                  • wilriker
                                    wilriker Moderator @docbobo last edited by
                                    @docbobo Yes, M300 are supposed to be played by PanelDue. I have to investigate the problem because it worked when I tested a while back.
                                    Manuel
                                    My Tool Collection
                                    • docbobo
                                      @wilriker πŸ‘ Let me know if there's anything I can do.
                                      BTW, when running mesh compensation, I noticed that coordinates for X Y Z were updating the screen, even though it was in sleep mode. Doesn't seem to happen while printing.
                                      wilriker 2 Replies Last reply Reply Quote 0
                                      • BoA
                                        BoA @docbobo last edited by BoA
                                        @docbobo I am not sure, but isn't the board responsible for sending this M300 to panel to make it beeping?
                                        • wilriker
                                          @docbobo said in PanelDueFirmware 3.2-RC3 released:
                                          Will let you know if that's necessary, thanks.
                                          I am not exactly sure if I understand what you mean. Du you mean it's waking up the panel from screensaver when running mesh compensation?
                                          If so, here's the small list of what will wait up the panel from screensaver:
                                          • Incoming message pop-up
                                          • Machine state changed e.g. Idle to Busy or Printing to Paused, etc.
                                          Manuel
                                          My Tool Collection
                                          • docbobo
                                            docbobo @wilriker last edited by docbobo
                                            @wilriker no, it’s not waking up the panel. It was mostly black, just the numbers for x, y, and z were appearing.
                                            oozeBot wilriker 3 Replies Last reply Reply Quote 0
                                            • oozeBot
                                              oozeBot @docbobo last edited by
                                              @docbobo - I've seen this as well..
                                              @wilriker - I've had the PanelDue not display an M291 S3 command like I described earlier several times today. There is no pattern to it that I've been able to find. However, I can say with certainty that it is still occurring.
                                              Like I mentioned before, it's within my homez.g file as interaction is expected when beginning a print.
                                              Thanks
                                              • wilriker
                                                wilriker Moderator @docbobo last edited by wilriker
                                                @docbobo Thanks for reporting. I'll investigate that.
                                                Manuel
                                                My Tool Collection
                                                • wilriker
                                                  Thanks
                                                  I need more information about your setup, please. Duet 2 or Duet 3 and standalone or with DSF?
                                                  Also in which state is the machine when this pop-up should occur? Idle, Busy, something else?
                                                  Manuel
                                                  My Tool Collection
                                                  oozeBot 1 Reply Last reply Reply Quote 0
                                                  • oozeBot
                                                    @wilriker we are using Duet 3 / RPi combos running 3.2b1 and the PanelDue is on 3.2-RC3+1. I just had it happen again on a machine that had been turned off overnight. What I didn't catch was the state reported in the top right corner of the PanelDue, but I believe it was "Printing". I feel sure this will happen again today, so I'll report back.
                                                    I will point out that I didn't notice this nearly as often (or at all?) on the earlier betas.. it feels new to 3.2-RC3+1. Thanks
                                                    • wilriker
                                                      @oozeBot The state does not have to be from PanelDue. In fact it might even be wrong there. Please check the state in DWC while the dialog is still open.
                                                      3.2-RC3+1 fixed a bug where these dialogs would not disappear if closed somewhere else, e.g. DWC. This seems to have introduced a regression as it seems.
                                                      Manuel
                                                      My Tool Collection
