    PanelDueFirmware 3.2-RC3 released
    PanelDue
    2.0k
    • oozeBotundefined
      oozeBot @docbobo
      @docbobo - I've seen this as well..
      @wilriker - I've had the PanelDue not display an M291 S3 command like I described earlier several times today. There is no pattern to it that I've been able to find. However, I can say with certainty that it is still occurring.
      Like I mentioned before, it's within my homez.g file as interaction is expected when beginning a print.
      Thanks
      • wilrikerundefined
        wilriker @docbobo
        @docbobo Thanks for reporting. I'll investigate that.
        Manuel
        My Tool Collection
        • wilrikerundefined
          wilriker @oozeBot
          @oozeBot said in PanelDueFirmware 3.2-RC3 released:
          Thanks
          I need more information about your setup, please. Duet 2 or Duet 3 and standalone or with DSF?
          Also in which state is the machine when this pop-up should occur? Idle, Busy, something else?
          Manuel
          My Tool Collection
          oozeBotundefined 1 Reply Last reply Reply Quote 0
          • oozeBotundefined
            oozeBot @wilriker
            @wilriker we are using Duet 3 / RPi combos running 3.2b1 and the PanelDue is on 3.2-RC3+1. I just had it happen again on a machine that had been turned off overnight. What I didn't catch was the state reported in the top right corner of the PanelDue, but I believe it was "Printing". I feel sure this will happen again today, so I'll report back.
            I will point out that I didn't notice this nearly as often (or at all?) on the earlier betas.. it feels new to 3.2-RC3+1. Thanks
            wilrikerundefined 2 Replies Last reply Reply Quote 0
            • wilrikerundefined
              wilriker @oozeBot
              @oozeBot The state does not have to be from PanelDue. In fact it might even be wrong there. Please check the state in DWC while the dialog is still open.
              3.2-RC3+1 fixed a bug where these dialogs would not disappear if closed somewhere else, e.g. DWC. This seems to have introduced a regression as it seems.
              Manuel
              My Tool Collection
              • docboboundefined
                docbobo
                Just noticed the following in my DSF output:
                [error] Failed to merge JSON: {"key":"","flags":"d99fn","result":{"boards":[{"mcuTemp":{},"vIn":{}}],"fans":[{"actualValue":0,"requestedValue":0,"rpm":-1},{"actualValue":1.00,"requestedValue":1.00,"rpm":-1}],"heat":{"heaters":[{"active":0,"current":61.0,"standby":0,"state":"off"},{"active":0,"current":84.5,"standby":0,"state":"off"}]},"inputs":[{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":205,"state":"idle"},{"feedRate":50.0,"lineNumber":151,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"}],"job":{"duration":null,"filePosition":0,"layerTime":null,"timesLeft":{"filament":null,"file":null,"layer":null}},"move":{"axes":[{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed
                   System.Text.Json.JsonReaderException: Expected end of string, but instead reached end of data. LineNumber: 0 | BytePositionInLine: 1280.
                   at System.Text.Json.ThrowHelper.ThrowJsonReaderException(Utf8JsonReader& json, ExceptionResource resource, Byte nextByte, ReadOnlySpan`1 bytes)
                   at System.Text.Json.Utf8JsonReader.ConsumeString()
                   at System.Text.Json.Utf8JsonReader.ConsumePropertyName()
                   at System.Text.Json.Utf8JsonReader.ConsumeNextToken(Byte marker)
                   at System.Text.Json.Utf8JsonReader.ConsumeNextTokenOrRollback(Byte marker)
                   at System.Text.Json.Utf8JsonReader.ReadSingleSegment()
                   at System.Text.Json.Utf8JsonReader.Read()
                   at System.Text.Json.JsonDocument.Parse(ReadOnlySpan`1 utf8JsonSpan, Utf8JsonReader reader, MetadataDb& database, StackRowStack& stack)
                   at System.Text.Json.JsonDocument.Parse(ReadOnlyMemory`1 utf8Json, JsonReaderOptions readerOptions, Byte[] extraRentedBytes)
                   at System.Text.Json.JsonDocument.Parse(ReadOnlyMemory`1 utf8Json, JsonDocumentOptions options)
                   at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 100
                I also have that on startup for some other keys, e.g. "inputs" and "move". But the one above is reoccurring. It stop when the PanelDue's screensaver is on.
                Some more system info:
                M115
                FIRMWARE_NAME: RepRapFirmware for LPC176x based Boards FIRMWARE_VERSION: 3.2-beta1_2 ELECTRONICS: LPC176x FIRMWARE_DATE: 2020-09-15b1
                Board: biquskr_1.4 (LPCSBC)
                DSF Version: 3.2.0-beta1+1
                • wilrikerundefined
                  wilriker @docbobo
                  @docbobo When the screensaver is active it reduces update poll rate from 1Hz to 0.25Hz. So this rather looks to me as if the LPC build has issues with available RAM or better: cleanly handling the lack of available output buffers.
                  Manuel
                  My Tool Collection
                  • gloomyandyundefined
                    gloomyandy
                    @wilriker I look after the LPC port and have a couple of questions if you can spare some time...
                    1. Is the panelDue causing any extra json requests to be sent to DSF, or is it just likely that having both the panelDue and DSF making requests is putting extra strain on the available buffer space?
                    2. What are the assumptions made about available output buffers (if any)?
                    3. It seems odd that a partial response is being sent to DSF. Is that what you would expect if the system runs out of output buffers? I would have thought that it would make more sense to assemble all of a json response before sending it?
                    The LPC port uses the same mechanism for handling a lack of buffers as does the Duet ports, so it seems likely that if the LPC has problems then in other circumstances (under heavy load or whatever) the Duet versions will hit the same problem. We do have a smaller number of buffers defined (16), but that is the same as number used by some other Duet hardware (that using SAM3XA mcus), but perhaps those Duets will never be used with an SBC?
                    T3P3Tonyundefined dc42undefined wilrikerundefined 3 Replies Last reply Reply Quote 1
                    • T3P3Tonyundefined
                      T3P3Tony administrators @gloomyandy
                      @gloomyandy said in PanelDueFirmware 3.2-RC3 released:
                      I cant answer the other questions, but the old SAM3X MCUs wont be supported connected to an SBC. Its close to the resource limit on Duet 2s using SAM4s
                      www.duet3d.com
                        gloomyandy @T3P3Tony
                        @T3P3Tony said in PanelDueFirmware 3.2-RC3 released:
                        Thanks for the information Tony. I suspected that might well be the case!
                          dc42 administrators @gloomyandy
                          PanelDueFirmware 3.2 requests the frequently-changing parts of the object model using M409; whereas earlier firmware uses M408 to get the status response. The data returned by M409 is almost certainly larger than the data that was returned by M408, so it's more likely to cause a shortage of output buffers.
                          The code is supposed to detect when output buffer overflow occurs, and when that happens return {err:-1} instead of an incomplete response, to avoid JSON parse errors. Maybe that change hasn't reached your fork yet; or maybe there are some conditions under which that overflow detection doesn't work properly.
                          BTW we are looking to release RRF 3.2beta2 on Monday or Tuesday.
                          HTH David
                            gloomyandy
                            @dc42 Thanks for the update. The current 3.2 LPC fork is based on the Duet3D 3.2-beta2 (as released) version not sure if the checks you mention are present in that or not. I see there have been a lot of changes in the SBC interface for beta2. I will be integrating/testing those as soon as beta2 is released and will investigate this further once I have the beta2 changes.
                            • wilrikerundefined
                              wilriker @gloomyandy
                              There are a very few extra requests going through to DCS (macro and file listings) but they are sent very rarely. It's your second thought that I'd true though, PanelDue with the latest firmware does make an ObjectModel request once per second and that puts extra strain on the available output buffers such that e.g. Duet 2 with no SBC and 24 buffers regularly responds with out of buffer messages if PanelDue and DWC are connected (I use this example since SBC support needs even more memory)
                              1. What are the assumptions made about available output buffers (if any)?
                              Sorry, I don't understand this question.
                              1. It seems odd that a partial response is being sent to DSF. Is that what you would expect if the system runs out of output buffers? I would have thought that it would make more sense to assemble all of a json response before sending it?
                              It really seems odd to me that the binary communication between RRF and DCS sees partial responses, though I am not totally familiar how these are assembled. For JSON responses, AFAIK, it does actually try to allocate the required output buffers dynamically and errors out if along the way there are not enough available. @dc42 and/or @chrishamm should be able to shed some more light on this part.
                              There has been a fix added to RRF 3.2-beta1 such that in this case it at least returns a clean error instead of a partial response. Since I don't know how close your fork actually is to "mainline" it was an assumption that this might not have been included yet.
                              Did not want to offend you or your work. Sorry, if that came across like "not my fault, go blame someone else".
                              As an addition to what @T3P3Tony already mentioned the old SAM3 based Duet boards never even got to RRF 2 - due to the lack of RAM. So they will never support SBC (officially).
                              Manuel
                              My Tool Collection
                                gloomyandy @wilriker
                                @wilriker Thanks for the reply, my question about "assumptions" was just speculation I wasn't sure if it was assumed/required that there was sufficient buffer space for say a certain type of json response. I can confirm that that when running with the panelDue/SBC all 16 buffers (on the LPC version) are indeed used so I think your diagnosis of a lack of buffers is correct.
                                It looks like the SBC interface has changed a fair bit between beta1 and beta2 so I'll take a closer look at the partial json problem once I've merged the beta2 changes. Will let you know if I think there may be a general problem there.
                                @wilriker @dc42 @T3P3Tony Thanks again for you help.
                                • wilrikerundefined
                                  wilriker @docbobo
                                  @docbobo said in PanelDueFirmware 3.2-RC3 released:
                                  @wilriker 👍 Let me know if there's anything I can do.
                                  So, I tried but unfortunately (or luckily) I cannot reproduce your issue with M300 not playing on PanelDue. I tried playing various tunes from various sources (USB, HTTP, Panel itself) in in all cases sounds were played as expected.
                                  Can you provide me with an example? Also I am running RRF 3.2-beta2 now. Please check if that makes a difference.
                                  Manuel
                                  My Tool Collection
                                  docboboundefined 1 Reply Last reply Reply Quote 0
                                  • docboboundefined
                                    docbobo @wilriker
                                    @wilriker said in PanelDueFirmware 3.2-RC3 released:
                                    Will do. However, won’t be able to do this before the end of week.
                                      Yes, it uses a separate task now.
                                        I have just checked, and the code to avoid sending malformed JSON responses when there is output buffer overflow is present only for M409 responses. I've made a note to fix this in the next beta.
                                        • wilrikerundefined
                                          wilriker @oozeBot
                                          I tracked this down to be an issue (or intended? limitation - waiting on feedback from @chrishamm) in DSF. M291 in macros will currently not update state.messageBox in the ObjectModel and that's the source for these dialogs showing up on PanelDue. It works if M291 is sent directly.
                                          As mentioned before I notified @chrishamm about this.
                                          Manuel
                                          My Tool Collection
                                          • wilrikerundefined
                                            wilriker @docbobo
                                            @wilriker no, it’s not waking up the panel. It was mostly black, just the numbers for x, y, and z were appearing.
                                            Unfortunately I cannot reproduce this one either. Can you tell me exact steps to reproduce this?
                                            Manuel
                                            My Tool Collection
