Independent Z axis Homing using BL Touch
  • @fcwilt @Phaedrux @droftarts this is the new thread,
    After the changes recommended I tried executing homeall and it would keep repeating home all instead of after homeall was complete run bed g.
    config:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 07:45:49 GMT-0600 (Mountain Daylight Time)
    M550 P"A.C.E."                                     ; set printer name
    M918 P1 E4 F2000000                                ; configure direct-connect display
    M551 P"SpaceForceHu2020!!"                         ; set password
    M569 P0 S1                                         ; X physical drive 0 goes backwards
    M569 P1 S1                                         ; Y physical drive 1 goes backwards
    M569 P2 S0                                         ; Z One physical drive 2 goes forwards
    M569 P3 S0                                         ; E physical drive 3 goes backwards
    M569 P4 S0                                         ; Z Two physical drive 2 goes forwards
    M584 X0 Y1 Z2:4 E3                                 ; set drive mapping
    M671 X-23:523 Y0:0 S0.5;
    M92 X80.00 Y80.00 Z400.00 E415.00                  ; set steps per mm
    M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
    M906 X800 Y1500 Z800 E1000 I50                     ; set motor currents (mA) and motor idle factor in per cent
    ;M208 X30:470 Y0:250                               ; X carriage moves from 30 to 470, Y bed goes from 0 to 250
    M208 X0:500 Y0:500 Z0:500                          ; set axis minima
    ;M208 X500 Y500 Z500 S0                            ; set axis maxima
    ;Filiment Out Sensor
    M591 D0 P1 C"e0stop" S1                            ; filiment out sensor
    M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
    M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F600 T9000                ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X37 Y0 Z2.150                              ; set Z probe trigger value, offset and trigger height
    M557 X30:470 Y30:470 S25                           ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
    M307 H0 A340.0 C140.0 D600 S1.00 B1                ; enable bang-bang mode for the bed heater and set PWM limit
    M143 H0 S72                                        ; set temperature limit for heater 0 to 72C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin e0temp
    M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
    M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
    M563 P0 S"Hot end" H1 D0 F1:2                      ; define tool 1
    G10 P0 X0 Y0 Z0                                    ; set tool 1 axis offsets
    G10 P0 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
    bed:
    ; bed.g
    M561                      ; clear any bed transform
    ;G29 S2                     probe the bed and enable compensation
    G28                       ; home all
    G30 P0 X40 Y250 Z-505     ; probe near a leadscrew, half way along Y axis
    G30 P1 X450 Y250 Z-505 S2 ; probe near a leadscrew and calibrate 2 motors
    G29                       ; or G29 S1 - create or load bed compensation mesh
    home all:
    ; homeall.g
    ; called to home all axes
    G91                      ; relative positioning
    G1 H2 Z5 F9000           ; lift Z relative to current position
    G1 H1 X-505 Y-505 F21600 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F9000        ; go back a few mm
    G1 H1 X-505 Y-505 F7200  ; move slowly to X and Y axis endstops once more (second pass)
    G90                      ; absolute positioning
    G1 X213 Y250 F9000       ; go to first bed probe point and home Z
    G30                      ; home Z by probing the bed
    G1 Z10                   ; raise Z 10mm
    G32                      ; bed.g
    ;G91                     ; relative positioning
    ;G1 Z5 F150              ; lift Z relative to current position
    ;G90                     ; absolute positioning
    home z:
    ; homez.g
    ; called to home the Z axis
    G1 X213 Y250 F9000 ; go to first probe point
  • Notice that in your bed.g file you have a G28 which runs the homeall.g file.
    In your homeall.g file you have G32 which runs the bed.g file.
    So round and round you go.
    If you really want to always run bed.g when you home all then don't use G28 in your bed.g file. Rely on the bed being homed in the homeall.g file
    Also in your config.g file you have this M557 X30:470 Y30:470 S25 which is not going to work since the probe has a X offset of 37.
    Change the 30 to 40 and it should work fine.
  • You might want to consider creating a homeall.g file that works a bit differently than the approach spit out by the configuration tool.
    My homeall.g file looks like this:
    M98 P"homeZ.g"
    M98 P"homeX.g"
    M98 P"homeY.g"
    Then if you wanted to level the bed only when doing a home all you could add G32 to the end of the file
    M98 P"homeZ.g"
    M98 P"homeX.g"
    M98 P"homeY.g"
    G32
    Keep in mind the bed leveling will likely change the Z=0 datum so you probabley should add the following to the end of your bed.g file
    G1 X213 Y250
    G30
  • This post is deleted!
  • @fcwilt bed g will not execute the independent axis homing and instead skip past them. In addition i get this error when running home all:
    	G28
    Error: Some computed corrections exceed configured limit of 0.50mm: -505.000 -505.000
  • @Gost101 said in Independent Z axis Homing using BL Touch:
    	G28
    To repeat, you have a G28 near the start of your bed.g file.
    This invokes homeall.g.
    And homeall.g ends with G32 which invokes bed.g again.
    Which invokes homeall.g again, which invokes bed.g again - forever.
    I have no idea what this does to the attempt to actually level the bed. Do the Z steppers appear to be trying to level the bed?
  • @fcwilt The stepper motors do not attempt to level z. here is my code:
    config:
    A.C.E.
    Send code...
    Status
    Busy
    Mode: FFF
    Tool Position
    X
    53.0
    Y
    90.0
    Z
    0.97
    Extruder Drives
    Drive 0
    0.0
    Speeds
    Requested Speed
    3 mm/s
    Top Speed
    3 mm/s
    Sensors
    Vin
    12.1 V
    MCU Temperature
    37.9 C
    Z-Probe
    1000
     Tools
     Extra
     Control All
    Tool	Heater	Current	Active	Standby
    Hot end
    T0 - Load Filament	Heater 1
    off	22.9 C
    0
    0
    Bed	Heater 0
    off	24.3 C
    0
    0
    Temperature Chart
    System Directory
    0:/sys/config.g
    M557 X40:470 Y40:470 S25                           ; define mesh grid
    bed:
    ; bed.g
    G1 X213 Y250
    G30
    home all:
    ; homeall.g
    M98 P"homeX.g"      ; executes home X Axis
    M98 P"homeY.g"      ; executes home Y Axis
    M98 P"homeZ.g"      ; executes home Z Axis
    G32
    home x:
    ; homex.g
    ; called to home the X axis
    G1 H1 X-505 F6000 ; move quickly to X axis endstop and stop there (first pass)
    G1 H2 X5 F3600     ; go back a few mm
    G1 H1 X-505 F1200  ; move slowly to X axis endstop once more (second pass)
    home y:
    ; homey.g
    ; called to home the Y axis
    G1 H1 Y-505 F6000 ; move quickly to Y axis endstop and stop there (first pass)
    G1 H2 Y5 F3600     ; go back a few mm
    G1 H1 Y-505 F1200  ; move slowly to Y axis endstop once more (second pass)
    home z:
    ; homez.g
    And I still get this error after removine the g28:
    	G28
  • @fcwilt the mesh bed calibration will run but I do not see it ever move to calibrate the x axis being level using the independent z axis.
  • might want to increase the maximum compensation.
    Mine is set as 15mm. check your config.g
    ;Leadscrew locations
    M671 X-10:-10:333  Y22.5:277.5:150 S15  ;Front left, Rear Left, Right  S15 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
  • Hi,
    OK less see...
    In your config.g file you have this M671 X-23:523 Y0:0 S0.5;
    That command is related to bed leveling being done in bed.g so you might as well put it there to keep things together.
    The S parameter, which defaults to 1, sets the maximum correction to 0.5.
    Move the M671 command from config.g to the beginning of bed.g and change the S parameter to 1.
    If that fails you can change the parameter to a larger value OR you can call G32 multiple times in the homeall.g file.
    Below G32 is called three time - two may be enough - three may be too little - just experiment until it works.
    G32
    G32
    G32
    In your bed.g file you have these commands:
    The Z parameters need to be Z-99999
  • @fcwilt @Thalios
    So now the Z axis are being independently homed. At least they move to the locations and for z after the center bed z probe. It will then run the mesh bed calibration.
    However I'm still getting:
    G28
    Error: Some computed corrections exceed configured limit of 1.00mm: -2.040 2.318
    Where is this coming from?
    config:
    bed:
    ; bed.g
    M671 X-23:523 Y0:0 S1       ; Z axis lead screw locations
    G30 P0 X40 Y250 Z-99999     ; probe near a leadscrew, half way along Y axis
    G30 P1 X450 Y250 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
    G1 X213 Y250
    G30
    home all:
    ; homeall.g
    G32
    G32
    G32
    home z:
    ; homez.g
  • As I said you need to increase the S value in your M671. You have it set at 1mm. Your G32 says you have -2.xx to +2.xx, so a total of 4.5 to 5mm difference. Make it 6mm and be done with it.
  • Moderator
    G28
    Increase the S value in M671 X-23:523 Y0:0 S1 to something like S5.
    Make sure that the Z axis motors are connected as they are defined by M584 and the leadscrew positions (M671), or the correction will go the wrong way. Currently you have:
    M584 X0 Y1 Z2:4 E3
    So the motor plugged into motor driver 2 (the Z driver) should be driving the left hand side leadscrew at X-23, and the motor plugged into driver 4 (the E1 driver) should be driving the right hand side leadscrew at X523.
  • @droftarts said in Independent Z axis Homing using BL Touch:
    M584
    @droftarts The Z axis motor at X 523 will go down while the other goes up. How would I correct this? I did increase the S value to 5.
    bed g
    ; bed.g
    M671 X-23:523 Y0:0 S5       ; Z axis lead screw locations
    G1 X213 Y250
    G30
    config:
  • Moderator
    M584 X0 Y1 Z2:4 E3
    Which motor is connected to driver 2 and which to driver 4?
  • @Phaedrux that would be the motor that goes down.
  • Moderator
    That answer makes NO sense. We can’t see what you’re seeing, so you need to answer questions clearly, or we end up with another 100+ post thread.
    If the motors are moving the wrong way during levelling ie it gets worse not better, either swap the Z motor connections, or change M584 to
    M584 X0 Y1 Z4:2 E3
    Mapping the correct motor to the correct leadscrew is fundamental to bed levelling, and is clearly covered in the documentation. Please read and follow documentation more carefully, it’ll save you a lot of time and unnecessary questions.
  • @droftarts @Phaedrux Both z axis work fine going up and down during all other aspects of the calibration eg, home z, manually going up and down. Only when the x axis is trying to be leveled via the z axis does the motor 2 z axis move so far down that the x axis becomes uneven to the bed.
  • Moderator
    @Gost101 the bed levelling rotates around X0, so one side (should be the right side, at X523) will move much more than the other side. If the left side is moving a large amount, and as I’ve told you three times now, swap the Z motors connections at the Duet over!
  • @droftarts I understand now. I had a brain fart right then. It's all fixed. It works very well now. Now for some reason the height map is very weird compared to what it used to be. This is what I see. So I have to do anything to my slicer Cura to use the mesh bed?
  • Moderator
    @Gost101 glad you got it working. You didn’t post an image of your bed mesh, though.
  • @droftarts I fixed the height map now its working. It had a corupt file that I just had to delete. Do I have to do anything with my slicer?
  • Here is my Slicer Settings:
    Start:
    M220 S100 ;Reset Feedrate
    M221 S100 ;Reset Flowrate
    G28 ;Home
    G29 S1 ;Z probe
    G92 E0 ;Reset Extruder
    G1 Z2.0 F3000 ;Move Z Axis up
    G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
    G1 X10.1 Y200.0 Z0 F1500.0 E15 ;Draw the first line
    G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
    G1 X10.4 Y20 Z0 F1500.0 E30 ;Draw the second line
    End:
    G91 ;Relative positioning
    G1 E-2 F2700 ;Retract a bit
    G1 E-2 Z0.2 F2400 ;Retract and raise Z
    G1 X5 Y5 F3000 ;Wipe out
    G1 Z10 ;Raise Z more
    G90 ;Absolute positionning
    G1 X0 Y{machine_depth} ;Present print
    M106 S0 ;Turn-off fan
    M104 S0 ;Turn-off hotend
    M140 S0 ;Turn-off bed
    M84 X Y E ;Disable all steppers but Z
  • Once I'm done I will create a new thread for people in the future to look at for my printers configuration.
  • Then I will work on the ultimate printer project which will take 1 year + to finish. I appreciate all the help that you all provide @fcwilt @droftarts @Thalios @Phaedrux @dc42. Will there be an expansion board in which I could plug in my own stepper driver? Curious about testing a closed loop system.
