    New hemera settings
    3.2k
    • ziggymanpopoundefined
      ziggymanpopo
      My question is not as much how do i fix it as how do i check it ??.. if that makes sense ??
      • Vetiundefined
        Veti
        pt1000 sensor do not need calibration. their properties need to be the same.
        does your pt1000 sensor come in the cartridge format that fits fully in the e3d hotend?
          ziggymanpopo
          Im missing something guys no idea what but if i set the temp to 205 it runs nicely up to that temp as far as the displayed temp goes the results make me question the actual temp..
            ziggymanpopo
            And yes x501 is the correct entry given by the supplier for the sensor also the r factor
              ziggymanpopo
              Yes indeed also put a small amount ik f heatoastvon it befoyr i slid it in,, good fit
                ziggymanpopo
                Yes the other manufacture used the same metal
                3mm carriage in a hemera. little heat paste fit good
                Thanks for the input guys i gotta finish later its 3 am 😁 again. lol
                  ziggymanpopo
                  what i changed.
                  The whole x carrage
                  It now ri s on two linear rail
                  Of course the hemera
                  A new pt 1000 sensor
                  Changed from a capasitive z-stop to a nozzle activated z-stop controled by a limit Sw.
                  Also upgraded the x axes stepper to a 2amp.
                  And a 10mm belt to compensate for the added weights ...
                  Z is dailed in nicely and current have been
                  adjusted 1100 m.a. on the x stepper
                  Vetiundefined 1 Reply Last reply Reply Quote 0
                    ziggymanpopo
                    Oh and the steps on the extruder per the hamera e3d site
                    • oliofundefined
                      oliof
                      What does your part cooling setup look like? The hull of the benchy up to that line has quite steep overhangs until the point where it recovers, so this could be an effect of bad cooling or overhang performance. Make sure to print the outer wall last in this section of the benchy so the overhangs can adher to the inner wall as well.
                      (Here is a great resource interpreting Benchy prints and what the individual features test for https://github.com/3DprinterDiscord/wiki/wiki/3D-Benchy).
                      • Vetiundefined
                        Veti @ziggymanpopo
                        @ziggymanpopo said in New hemera settings:
                        you should run the steppers at around 75% of the rated current
                        try 1700ma
                          ziggymanpopo
                          So i know why 70% must be a reason.. does it change
                          For a belt versa a ballscrew
                          • Vetiundefined
                            Veti @ziggymanpopo
                            @ziggymanpopo
                            duet2 only goes in steps of 100ma
                              ziggymanpopo
                              Thsnks for the benchy imfo. It will help.
                              The cooling is like the fang two curved airducts and a squirrel cage type fan it seems to be way mor than i need for pla or petg
                                ziggymanpopo
                                I seam to get rhe best results whem i turn the fan realy low 30% Or so
                                  ziggymanpopo
                                  I thinnk it would be prudent to get conformation of exactly where my temp sits then go after the cooling setting. I think my bigest prolem is figuaring out where my settings should be since everything has changed cant go by what i had ...right ??? The question is where to start my calibation
                                  I thought after reviewing the links i was sent about pid that We depend on the value of the given device
                                  (sensor or termistor) to be correct i guess whats throwing me is when i print anywhere close to 210°c
                                  The effects are like its way too hot.. so i an thinking of buying test equiptment capable of telling me acctual temps. (Multi meter with a sensor.)
                                  Get that dialed in. what do you thinkn good place to start ???
                                    ziggymanpopo
                                    The prints keep improving but cant seam to get rid of the large error on the bow
                                    Anyone have any idea what caused it
                                    Her i ran two benches at 200and 205c
                                    Thebsteper curennt change helped a little
                                    But for some reason the line on the bow justnis persistend.
                                    Ive gone up to 220c to the point where it cisablt melts the deck and its still there
                                    so dont think its temp related
                                    Thought maybe is mechanically hung up. But its always in the same place
                                      ziggymanpopo
                                      I also moved the benchy to a div spot on the build platform
                                      Also ran the same slicer program from laptop to rule out slicer. ????
                                      Im baffled running out of things to check and ideas
                                        ziggymanpopo
                                        Current rating is 1.33amps is it possable this js where my prob is extruder ma??? 😳
                                          ziggymanpopo
                                          Extruder current??
                                          • Vetiundefined
                                            Veti
                                            you are running at 950 which is about 70%. that should be fine
