    Bad printing quality for unknown reason
    442
    • Phantom329
      Phantom329 last edited by Phantom329
      I am working on a new build but I cannot get a decent print. Every print comes out much worse than I would expect. I printed a benchy and a spiralized vase as a test. I though it was over extrusion but I recalibrated my E steps. I thought it could be retraction but the vase was spiralized so no retraction. This is with printing from a completely stock Cura PLA profile. I don't know what to look at next, this is my first scratch build so any help is appreciated.
      Spiralized Vase
      3D Benchy
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 24 2020 07:39:49 GMT-0400 (Eastern Daylight Time)
      M550 P"Phantom Cube"                               ; set printer name
      M669 K1                                            ; select CoreXY mode
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S0                                         ; physical drive 2 goes backwards
      M569 P3 S0                                         ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X200.00 Y200.00 Z400.00 E410.00                ; set steps per mm
      M566 X720.00 Y720.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z600.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250.00 E1000.00              ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600 E1600 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M208 X350 Y310 Z310 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in" H20 F240 T6000                ; set Z probe type to unmodulated and the dive height + speeds
      G31 P25 X0 Y-15 Z14.5                              ; set Z probe trigger value, offset and trigger height
      M557 X40:300 Y20:280 S65                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 A176.4 C339.5 D7.2 S1.00 V23.8 B1          ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 A297.7 C97.1 D6.5 S1.00 V24.0 B0           ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
      • jay_s_uk
        jay_s_uk last edited by
        i'm guessing your thermistors settings are wrong as they're the default values.
        Do you know what thermistors you used?
        • Phantom329
          Ok that could make sense... It came from a parts kit so I will have to do a bit of digging to get the exact information. I have a config that came with the kit but it looks like some lines changed in the update to RRF 3.
          EDIT: Also, bed and extruder both say 21.7C at idle so I assumed they were set correctly.
          ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
          M80				; Turns on the ATX power supply
          G90                                                ; Send absolute coordinates...
          M667 S1                                            ; Select CoreXY mode
          M550 PBLV mgn Cube                                 ; Set machine name
          M552 S1                                            ; Enable network
          M587 S"your_wifi_name" P"your_password"            ; Configure access point. You can delete this line once connected
          M586 P0 S1                                         ; Enable HTTP
          M586 P1 S0                                         ; Disable FTP
          M586 P2 S0                                         ; Disable Telnet
          M569 P0 S0                                         ; Drive 0 goes backwards blv: its was S1
          M569 P1 S0                                         ; Drive 1 goes backwards blv: its was S1
          M569 P2 S1                                         ; Drive 2 goes forwards
          M569 P3 S1                                         ; Drive 3 goes backwards WAS 0
          M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
          M92 X200 Y200 Z400 E405.18                         ; Set steps per mm for Bondtech.
          M566 X600 Y600 Z24 E300                            ; Set maximum instantaneous speed changes (Jerk) (mm/min)
          M203 X20000 Y20000 Z600 E2000                      ; Set maximum speeds (mm/min)
          M201 X3000 Y3000 Z100 E5000			   				 ; Set accelerations (mm/s^2)
          M906 X1600 Y1600 Z1600 E1600 I30                   ; Set motor currents (mA) and motor idle factor in per cent
          ; Pressure advance
          ; M572 D0 S0.05					   					; disabled Pressure advance
          M208 X-23 Y0 Z0 S1                                 ; Set axis minima
          M208 X320 Y321 Z350 S0                             ; Set axis maxima
          M574 X1 Y2 S1                                      ; Set active high endstops edit: Y endstop is high(max).
          ; Filament sensor
          M591 D0 P1 C3 S1				 					  ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0)
          M574 Z1 S2                                         ; Set endstops controlled by probe
          M307 H1 A372.3 C109.6 D4.6 B0			  		 ; Set PID for hotend values
          M307 H0 A99.1 C453.2 D2.2 B0					  ; Set PID for heated bed values
          M558 P1 H5 F200 T9000 I0 R0.5			 		  ; Set Z probe type mini ir sensor
          G31 P500 X-2 Y-16.4 Z1.043                         ; Set Z probe trigger value, offset and trigger height
          M557 X30:270 Y30:270 S80			   				; Define mesh grid
          M305 P0 T100000 B3950 C0 R4700                     ; Set thermistor + ADC parameters for heater 0
          M143 H0 S100                                       ; Set temperature limit for heater 0 to 100C
          M305 P1 T100000 B3950 C0 R4700                     ; Set thermistor + ADC parameters for heater 1
          M143 H1 S260                                       ; Set temperature limit for heater 1 to 260C
          M106 P0 S0 I0 F500 H-1                             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T35                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S1 I0 F500 H1 T35                          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1                                      ; Define tool 0
          G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
          G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
          ; Automatic power saving
          M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          M564 H0                                   	   ; Let the Jog buttons work blv: added to allow jog buttons
          • Veti
            Veti last edited by
            @Phantom329 said in Bad printing quality for unknown reason:
            since they are all 100k thermistor the 25C degree value is the same for all. they differ at high temperatures.
            • Phantom329
              Ok I set the thermistors to B3950 like the original config says since I can't find any documentation about the parts from the kit. I'll run another print after I auto tune and see how it goes.
              • Veti
                Veti last edited by
                can you post a link to the kit?
                Phantom329 1 Reply Last reply Reply Quote 0
                • Phantom329
                  Phantom329 @Veti last edited by
                  @Veti Its the full BLV MGN Cube kit https://www.aliexpress.com/item/4000216439704.html
                  • Phantom329
                    @Veti I think it printed better but it still has the weird lines artifact. Printing a benchy now.
                    EDIT: Benchy failed but same story.
                    print
                    Veti 1 Reply Last reply Reply Quote 0
                    • brotherchris
                      brotherchris last edited by
                      Hey, I just happen to see you said Cura, just a wild guess on my part. Is your Slicer set to 3mm filament?
                      Phantom329 1 Reply Last reply Reply Quote 1
                      • Veti
                        Veti @Phantom329 last edited by
                        maybe they supplied a semitec thermistor. try B4725 C7.06e-8
                        • Phantom329
                          Phantom329 @brotherchris last edited by
                          @brotherchris Nope, I have the extruder and material set to 1.75mm.
                          • Phantom329
                            I slowed down the printing speed to 30mm/s and on one side it printed almost the same, smaller blobs. On the other side, though, it printed with minimal blobs and shows pretty clean lines. I'm tempted to blame the feeder... its a knock-off dual drive feeder and I had to rebuild it like 10 times to make it smooth. My friend also said it could be the hotend which is a v6 clone. What do you think?
                            • Veti
                              Veti last edited by
                              print a temperature tower
                              • Phantom329
                                @Veti Seems like its not a temperature issue
                                  Looks over extruded and overheated.
                                  • Veti
                                    did you just print the tower? it looks the same for all heights.
                                    you need to script the change of temperature
