    Piezo Orion + RRF 3.... Problems
    Third-party add-ons
    312
    • chop
      chop last edited by
      Hi everyone. I hope you can help me with my problems. So setup: duet 2 wifi firmware 3.1, Orion pcb 2. first of all, it's connected, digital v + goes to 3.3v ground and signal to z probe in. I have to invest the signal pin to make it work. Is that bad? If so, how can I fix the problem? Polarity? How do I change it? Well, I have adjusted the orion with a light touch it deflects to 1000. Otherwise it is at 0. I also use it as an end stop. If I want to determine the height now. I drive to the middle, move up until the nozzle scratches the paper, save it as z0 and then go 0.5mm down and move up via g31 s-1. I repeat that countless times. And always a different, increasing value comes out. Can that be backlash? Incidentally, printer is a hypercube meike config looks like this., Axis Limits
      M208 X0 Y0 Z0 S1; set axis minima
      M208 X310 Y300 Z260 S0; set axis maxima
      ; End stops
      M574 X1 S1 P "xstop"; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P "ystop"; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1; configure Z-probe endstop for low end on Z
      ; Z sample
      M558 P8 C "! Zprobe.in" R0.8 F500 Z1; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5; set Z probe trigger value, offset and trigger height
      M557 X5: 305 Y5: 295 S20; define mesh grid would be very grateful if you could help me
      engikeneer 1 Reply Last reply Reply Quote 0
      • engikeneer
        engikeneer @chop last edited by
        @chop Invertered signal is correct for the Orion, and it sounds like you've wired it all up correctly. If you're interested, here's my config from my Duet Wifi with an Orion & RRF3.1. I have defined a few more things in my M558 (I'd recommed you look at adding the H & T). I also don't have 'Z1' in there, but think I should... In your G31 line, your Z-offset should typically be around -0.1 to -0.3, definitely not 2.5 (that would mean when your orion triggers, the nozzle is 2.5mm above the build surface in mid air!)
        M574 Z1 S2                               ; Set endstops controlled by probe
        M558 P8 C"!zprobe.in" R1 H2.5 F400 T3000 A10 S0.005              ; Set Z probe type to effector and the dive height + speeds
        G31 P500 X0 Y0 Z-0.12 ;                  ; Set Z probe trigger value, offset and trigger height
        I'm guessing by running 'G31 S-1', you mean 'G30 S-1'?
        When you say you 'save it as Z0', what exactly are you doing? Using G92 to declare the position or something else?
        What kind of difference do you get between subsequent probes? Also, what is your print surface. I use Ziflex (magnetic removeable plate) which is a bit soft. If I probe the same point a lot (10+ times in quick succession), I find it does increase a little bit (max 50um) as you put a small (non permanent) dimple in the surface.
        Is your nozzle clean before probing? What temperature is your hotend/bed during the probing? It's recommended to probe with the nozzle at 130deg so any plastic that is left is a little squishy - you end up flattening it with subsequent probes (hence I use the A & S parameters to probe points multiple times). Probing too hot though can damage your build surface
        There's a chance your Z-axis is losing steps, but I'd doubt it. Post your full config.g and we can check for anything else that might be wrong
        i3 clone with a bunch of mods
        chop 1 Reply Last reply Reply Quote 0
        • chop
          chop @engikeneer last edited by
          @engikeneer
          Hi and first of all thanks for the answer. So the z2.5 yes ... ignore that. I was only testing it a bit. My config.g so far looks like this: Configuration file for Duet WiFi (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 15 2020 23:42:44 GMT + 0200 (Central European Summer Time)
          G90; send absolute coordinates ...
          M83; ... but relative extruder moves
          M550 P "Chop's Hypercube"; set printer name
          M669 K1; select CoreXY mode
          ; *** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
          M552 S1; enable network
          M586 PO S1; enable HTTP
          M586 P1 S0; disable FTP
          M586 P2 S0; disable Telnet
          M587
          M569 P0 S1; physical drive 0 goes forwards
          M569 P1 S1; physical drive 1 goes forwards
          M569 P2 S1; physical drive 2 goes forwards
          M569 P3 S1; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3; set drive mapping
          M350 X16 Y16 Z16 E16; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E404.00; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E600.00; set maximum instantaneous speed changes (mm / min)
          M203 X12000.00 Y12000.00 Z1200.00 E6000.00; set maximum speeds (mm / min)
          M201 X800.00 Y800.00 Z250.00 E800.00; set accelerations (mm / s ^ 2)
          M906 X850 Y850 Z1000 E900 I30; set motor currents (mA) and motor idle factor in per cent
          M84 S120; Set idle timeout
          M84 S0; Disable motor idle current reduction
          ; Axis limits
          ; End stops
          ; Z sample
          M308 S0 P "bedtemp" Y "thermistor" T100000 B4138; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C "bedheat" T0; create bed heater output on bedheat and map it to sensor 0
          M307 H0 A89.9 C419.7 D1.00 V24.2 B0; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0; map heated bed to heater 0
          M143 HO S120; set temperature limit for heater 0 to 120C
          M308 S1 P "e0temp" Y "thermistor" T100000 B4138; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C "e0heat" T1; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 A917.7 C197.3 D5.5 S1.00 V24.1 B0; disable bang-bang mode for heater and set PWM limit
          M950 F0 C "fan0" Q500; create fan 0 on pin fan0 and set its frequency
          M106 P0 C "BTK" S0 H-1; set fan 0 name and value. Thermostatic control is turned off
          M950 F1 C "fan1" Q500; create fan 1 on pin fan1 and set its frequency
          M106 P1 C "HEK" S1 H1 T25; set fan 1 name and value. Thermostatic control is turned on
          M563 P0 S "E3D" D0 H1 F0; define tool 0
          G10 P0 X0 Y0 Z0; set tool 0 axis offsets
          G10 P0 R0 S0; set initial tool 0 active and standby temperatures to 0C
          M501; load saved parameters from non-volatile memory
          M911 S22 R23 P "M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"; set voltage thresholds and actions to run on power loss
          T0; select first tool
          So far I've just been testing the orion without filament and without temperature. So the nozzle is clean. Of course you are right. I meant g30 s-1. What exactly did I do? often. m564. then x y in the middle. Put paper on the bed and drive it until it scratches. That defined as 0 G92 Z0. Then 0.5 mm down with z and up with g30 s-1. Very often. I never have an identical value. The only constant is that this value always goes into minus. A little more with each g30 s-1. I print on pertinax.
          • engikeneer
            @chop Nothing obviously out in your config, only thing I'd mention is your M350. Add 'I1' to the end of the line to enable interpolation (as long as you're sticking with x16 microstepping). Might be the default, but best to specify.
            Unrelated, but I think 'B4138' in your thermistor settings is the default so probably not quite right for your setup - you'll want to find the right value to go in there for your thermistors.
            Back to the Z-probe. That all seems a sensible workflow to me, though obviously be very careful using M564 H0 - I'd always prefer to to home properly, or at the very least use G92 to set all positions.
            I don't know anything about pertinax as a a material so can't comment on how that will affect things. Can you see any indentation after you do several probes? Your feedrate of 500mm/min is reasonably fast, but not crazy. I wonder if it is just hitting the surface a little hard.
            What kind of values are you getting from your G30 S-1? Are we talking 5um steps, 20um steps, or full 0.5mm each time?
            Have you tried adjusting the potentiometer on the Orion? Not sure whether you'd want to go more or less sensitive. I kind of found a sweet spot when I first fitted mine and haven't adjusted it since...
            Are you using the standard mount they ship with it, or something custom?
            Not sure if it will help, but here is a macro I use from someone else on the forum to see probe repeatability. It homes everything first (G28), then probes at 151,151 ten times - you can obviously change this. It then spits out all the measurements and the mean & std dev into the console.
            M291 P"Probe will be tested 10 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
            G28
            G30 P0 X151 Y151 Z-9999
            G30 P1 X151 Y151 Z-9999
            G30 P2 X151 Y151 Z-9999
            G30 P3 X151 Y151 Z-9999
            G30 P4 X151 Y151 Z-9999
            G30 P5 X151 Y151 Z-9999
            G30 P6 X151 Y151 Z-9999
            G30 P7 X151 Y151 Z-9999
            G30 P8 X151 Y151 Z-9999
            G30 P9 X151 Y151 Z-9999 S-1
            P.S. apologies for the brain dump and many questions... 😛
            chop 2 Replies Last reply Reply Quote 1
            • arhi
              arhi last edited by
              use the analog out, coax cable to connect it to zprobe.in and dynamic threshold configuration and if you mounted it properly it will work. using the digital output requires you to properly tune the untunable %@(^_&^ potentiometer on the pcb.
              chop 2 Replies Last reply Reply Quote 0
              • chop
                chop @arhi last edited by
                @arhi pls gimme a example config. I will test it
                arhi 1 Reply Last reply Reply Quote 0
                • A Former User
                  A Former User last edited by
                  Don't Get me started on about the Piezo Orion.
                  I bought a genuine one to test which arrived earlier in the week. Upon opening the packaging i'm met with printed parts that looked like they were printed by a blind man in an awful hurry.
                  Hey ho I think, I will re-print the parts myself properly.
                  then i plugged it into my test stand, a Duet 2 set up purely for testing things on the bench and it was dead, no L.E.D at boot nothing. so i take a look at the board, seems like it was hand soldered by the blind guy who did the printing with components askew an solder splashes....
                  One email to Precision Piezo later with the pictures included below and they reply that they think the unit was either damaged during transit or during fitting, but they refunded me, which leads to the question if they thought it was possibly a installation issue why refund me ?
                  Be very careful about buying this thing
                  • chop
                    @engikeneer said in Piezo Orion + RRF 3.... Problems:
                    G28
                    16.10.2020, 22:37:21 Stopped at height -0.110 mm
                    16.10.2020, 22:37:19 G30 S-1
                    16.10.2020, 22:37:15 Stopped at height -0.083 mm
                    16.10.2020, 22:37:12 G30 S-1
                    16.10.2020, 22:37:08 G30 S-1
                    Stopped at height -0.060 mm
                    16.10.2020, 22:37:08 M120 G91 G1 Z0.5 F6000 G90 M121
                    16.10.2020, 22:37:04 Stopped at height -0.055 mm
                    16.10.2020, 22:37:02 G30 S-1
                    16.10.2020, 22:36:59 Stopped at height -0.032 mm
                    16.10.2020, 22:36:58 G30 S-1
                    16.10.2020, 22:36:54 G30 S-1
                    Stopped at height -0.025 mm
                    16.10.2020, 22:36:47 G30 S-1
                    Stopped at height -0.002 mm
                    16.10.2020, 22:36:43 G30 S-1
                    16.10.2020, 22:36:37 G30 S-1
                    16.10.2020, 22:36:32 G30 S-1
                    Stopped at height 0.000 mm
                    16.10.2020, 22:36:27 Stopped at height 0.000 mm
                    16.10.2020, 22:36:25 G30 S-1
                    16.10.2020, 22:36:24 M120 G91 G1 Z0.5 F6000 G90 M121
                    Stopped at height 0.002 mm
                    16.10.2020, 22:36:24 G30 S-1
                    16.10.2020, 22:36:17 G30 S-1
                    16.10.2020, 22:36:09 G30 S-1
                    16.10.2020, 22:36:03 G30 S-1
                    Stopped at height 0.005 mm
                    16.10.2020, 22:35:53 G30 S-1
                    16.10.2020, 22:35:44 G30 S-1
                    16.10.2020, 22:35:35 G30 S-1
                    Stopped at height 0.007 mm
                    16.10.2020, 22:35:25 G30 S-1
                    Stopped at height 0.010 mm
                    16.10.2020, 22:35:16 Stopped at height 0.010 mm
                    16.10.2020, 22:35:15 G30 S-1
                    16.10.2020, 22:35:07 G30 S-1
                    • chop
                      @engikeneer
                      16.10.2020, 22:43:59 Error: Z probe readings not consistent
                      16.10.2020, 22:43:38 Error: Z probe readings not consistent
                      16.10.2020, 22:43:13 Error: Z probe readings not consistent
                      • chop
                        chop @arhi last edited by chop
                        @arhi
                        if i use Analog DWC says Z-Probe 492 and not 0. without contact.
                        how to tune?
                        • arhi
                          arhi @chop last edited by
                          @chop said in Piezo Orion + RRF 3.... Problems:
                          you need to run the analog output to the zprobe.in using a coax cable (I'm using balanced audio cable for e.g.)
                          config:
                          ; ORION ANALOG
                          M558 P1 C"!zprobe.in" R2 H6 F2400 T3600 A4 S0.03 K0
                          G31 X0 Y0 Z-0.1 P250
                          how to use it:
                          homez.g
                          ; HOME Z WITH ORION
                          M400
                          T0
                          G90
                          G0 X0Y0 F3000           ; go to center of the bed, complain if X or Y not homed
                          ;G0 Z5   F900  H2        ; drop bed for 5mm
                          G4S3                    ; wait 3sec
                          G31 P{sensors.probes[0].value[0] + 3}
                          G30                     ; Probe the bed at the current XY position.
                                                  ; When the probe is triggered, set the Z coordinate
                          						; to the probe trigger height.
                          the G31 here takes current reading from the analog input and set treshold to +3 that value
                          bed.g
                          ; bed.g
                          G29 S2 ; delete compensations
                          M561   ; clear any bed transform
                          G28    ; home
                          M400
                          M913 X30 Y30 Z100 ; go to first test point
                          M400
                          G4 S1
                          M400
                          G29 S0
                          this way the issue with sh$%%^tty potentiometer on the board for setting trashold for digital output is solved.
                          There's still issue with mounting ppiezo but that's another bag of worms, but this is the good start so you at least have treshold set right.
                          notice that if you are having "premature trigger" with
                          you can change to +5 or more, but that really means that you are picking up a lot of noise and you need a better cable or that your head is vibrating or .. it should work with +2 or +3
                          • arhi
                            arhi last edited by
                            also note that you want probing to be "fast" as the fastes you hit the nozzle better it will react, piezo do not like to be "slowly pressure" it likes to be tapped. The problem with current firmware is that it slows down when the read value is close to treshold (and it always is as it does not change like with ir sensor). dc42 said he'll change this in one of the next versions but so far it has not happened so you need to push the speed in the m558
                            • chop
                              @arhi
                              thanky you. but how can i adjust the trigger?
                              • arhi
                                @arhi
                                this does it:
                                analog output from the orion ignores the pot, so don't touch the pot.
                                this reads the current value of the analog output from the orion ( sensors.probes[0].value[0] and sets the new treshold value to read value+3
                                • chop
                                  @arhi hm . changed from 1 to 25 and nothing changed
                                  • arhi
                                    @chop what do you expect to change?
                                    • chop
                                      @arhi the trigger value in dwc its @ 492 and with s lot of preasure it Gos over 500
                                      • arhi
                                        @chop what you see in DWC is the read of the analog value, that will not change by any g-code, it's what the orion is sending and it changes as the orion is deformed. the G31 I gave you changes the threshold. to see the threshold value you need to send just G31
                                        • chop
                                          @arhi ah okay. Ty! Today i will give some anti backlash nuts a shot. After install i will try your Tipps.
                                          • chop
                                            chop @chop last edited by
                                            @arhi @engikeneer
                                            So it works! Thank you for your help. But now I have the next problem. How can I use the orion correctly? How do I set z. no matter what I do . He starts printing in the air. With rrf3 I determine z with 92z0 right? Then I create a mesh. What do I have to enter in his? I'm still new to rrf. before marlin sorry. do not quite understand all of this yet
                                            • arhi
                                              arhi @chop last edited by arhi
                                              @chop now you need to manually figure out the Z offset of the probe and put it in the config.
                                              1. super important is that you heat up your bed and nozzle before you home Z with the orion
                                              2. super important that you clean a nozzle before you probe (so heat up, wipe, retract, wipe is what I do, visually inspect when nozzle is sitting above center of the bed that nozzle is clean)
                                              3. after you home Z, you then need to find the "offset"
                                              this offset is normally in the range of 0 to -0.1mm depending on how sensitive your orion is and how fast you probe so it's basically the travel your bed does during a trigger delay. how to setup this offset ... ppl have different preferences, what I do is I'd leave nozzle in the center of the bed (homing position) and do
                                              G0Z1
                                              this should have your nozzle close to the bed but not touching it
                                              disable soft limits
                                              M564 S0 H0
                                              now I put piece of paper between nozzle and bed and start reducing this value
                                              G0Z0.5
                                              G0Z0.3
                                              G0Z0.2
                                              G0Z-0.2
                                              till I get to point that paper is being grabbed by the nozzle
                                              this position need to be your Z0 so see how far you are from it (you know what Z value you gave it), change the sign of that value and put in the config of the probe (G31, the Z value):
                                              e.g.:
                                              hope this helps
                                              btw, do this while everything is HOT and nozzle is clean. Otherwise not much point in using orion, as if you probe cold those are not real value during print.... this is why I like the durable print surfaces like printbite as if you have those soft print surfaces they can dislike the hot nozzle so then you might want to work hot but heat up the bed to your print temperature but heat up the nozzle to lower temp like 100-120C enough for it to "get bigger" but not hot enough to damage the print board if you mess something up
                                              useful read: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                              • arhi
                                                arhi last edited by arhi
                                                one hint, since digging hot nozzle into print bed is a real solution when you do this first time I suggest you use a PCB on top of your print bed, or use glass as your print surface for the first test... so both probe over the hard surface that's temperature resistent (pcb/FR4 or glass) and start the first print on top of such surface to be sure you got the probing and configuration (offset) properly calibrated
                                                going further, one other hint .. before you start printing, make sure that ORION Is ok and that you are not drowning in noise .. so run a test probing same point many times
                                                • chop
                                                  @arhi ty . I will try. But, how to set z0 corect? After z0 i can set offset !? Right? Once i get the offset. I have to tell the Slicer to use the mesh?
                                                  • chop
                                                    @arhi said in Piezo Orion + RRF 3.... Problems:
                                                    G0Z1
                                                    disable soft limits
                                                    M564 S0 H0
                                                    G0Z0.5
                                                    G0Z0.3
                                                    G0Z0.2
                                                    G0Z-0.2
                                                    e.g.:
                                                    hope this helps
                                                    Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                                                    Cancel any currently active mesh compensation with M561
                                                    Use the X and Y jog buttons to position the nozzle over the centre of the bed
                                                    Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                                                    Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                                                    Jog the head up by 5 to 10mm
                                                    Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
                                                    Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                                                    In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                                                    Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                                                    To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.
                                                    Thats what i do...print starts mid air
                                                    • arhi
                                                      arhi last edited by
                                                      testing the repeatability - very important with piezo
                                                      G28
                                                      M401
                                                      G30 P0 X151 Y161 Z-9999
                                                      G30 P1 X151 Y161 Z-9999
                                                      G30 P2 X151 Y161 Z-9999
                                                      G30 P3 X151 Y161 Z-9999
                                                      G30 P4 X151 Y161 Z-9999
                                                      G30 P5 X151 Y161 Z-9999
                                                      G30 P6 X151 Y161 Z-9999
                                                      G30 P7 X151 Y161 Z-9999
                                                      G30 P8 X151 Y161 Z-9999
                                                      G30 P9 X151 Y161 Z-9999 S-1
                                                      M402
                                                      change X and Y values to be in the center of your bed
                                                      more details here: https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output/4
