    Z trigger height
    282
    • FelixH
      FelixH last edited by
      Hi all,
      Probably a very silly question, but I am in doubt right now, so please bear with me...
      On my Marlin Machines, I use the following start G-Code to set the Z-Probe Offset:
      M851 Z-0.32 ; set z probe offset
      On my Duet machines, I have the value hard-coded to the config.g file.
      My question is: can I also set the probe offset on the start G-Code also on the Duet Machines? I am assuming that much, but I just want to be sure...
      BTW: I know that on Duet is called Trigger Height and is calculated differently...
      • Veti
        Veti last edited by
        yes you can issue the G31 command just like the M851 in marlin
        FelixH 1 Reply Last reply Reply Quote 0
        • FelixH
          FelixH @Veti last edited by
          @Veti thanks for the confirmation. If I add it on the initial Gcode, I can adjust it more rapidly, without having to reboot the board.
          Veti fcwilt 2 Replies Last reply Reply Quote 0
          • Veti
            Veti @FelixH last edited by
            @FelixH
            yes it takes effect without rebooting, but you need to do a new home
              Perhaps using baby stepping would be more appropriate, then you wouldn't need to rehome.
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M290_Baby_stepping
              • fcwilt
                fcwilt @FelixH last edited by
                @FelixH said in Z trigger height:
                I have a pair of macros (print_begin.g and print_end.g) that are called (using M98) by settings in the slicers I use.
                Two of the things that happen in print_begin.g are a call to a macro configprobe.g and then a call to a macro probez.g
                The Z trigger height setting happens in configprobe.g using G31.
                So if I need to change it, I just edit the file and then subsequent prints use the new settings.
                No need to re-boot, no need to home.
                • FelixH
                  Thank you all for your inputs.
                  • FelixH
                    Is there any kind of trick on finding out the correct trigger height? Any time I have to re-calibrate is like a trip to hell. After following this guide:
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    I get, for example, a trigger height of 1.50mm. I set it on the config.g file and I do a test. The nozzle is way too far from the bed and I try to use Babystepping to get it closer. The Babystepping shows me a -0.15 (for example)... now what? Should I correct the config.g file and set the trigger height to 1.35 (1.5-0.15) ??
                    Phaedrux fcwilt 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @FelixH last edited by
                      If it's consistent, yes.
                      If you do the G30 S-1 test multiple times over does it give a consistent result? Are you also homing in that same spot?
                      • FelixH
                        FelixH @Phaedrux last edited by
                        @Phaedrux yes it is consistent and also yes, it homes to the same spot.
                        • fcwilt
                          To get the nozzle to be closer to the bed you increase trigger height.
                          In your example you decreased it.
                          The trigger height determines how far the nozzle must move to reach Z=0. If the current value of the trigger height is leaving the nozzle above the bed then the nozzle did not move far enough. To get the nozzle to move more you increase the trigger height.
                          FelixH 1 Reply Last reply Reply Quote 1
                          • FelixH
                            FelixH @fcwilt last edited by
                            @fcwilt
                            This is exactly what puzzles me every time. The pop up on the Panel Due shows a minus value an yet, it’s the opposite...
                            fcwilt 1 Reply Last reply Reply Quote 0
                            • fcwilt
                              I know it can be confusing.
                              When the probe is triggered the trigger height setting (assume 2 mm) says to the firmware "hey the nozzle is now 2mm above the bed". The firmware says to itself "ok so to move the nozzle to Z=0 I must move closer to the bed by 2mm"
                              When you adjust baby stepping to a negative value you are saying to the firmware "hey you need to move closer to the bed".
                              And as you can see to move closer to the bed requires a larger trigger height.
