    2 Component Fans
    Firmware installation
    148
    • Heartleander81
      Heartleander81 last edited by
      Hi Guys.
      I have a question about a Duet Wifi 2 and Duet 3 6hc board.
      I have 2 component fans that should start up at the same time.
      How do I enter this under RRF 3?
      Would that be for duet 3 e.g.
      M950 F2 C "out6" Q500
      M106 P2 S1 H1 T50
      Is that for Duett 2 wifi then:
      M950 F2 C "fan2" Q500
      M106 P2 S1 H1 T50
      Will both component fans start up on the M106 S255?
      • Veti
        Veti last edited by
        @Heartleander81 said in 2 Component Fans:
        H1 T50
        this means the fan turns on if the heater 1 is above 50
        in that case it can not be controlled by m106.
        H-1
        this would mean controlled by m106
        omni 1 Reply Last reply Reply Quote 0
          Your question is a little unclear. Are you using a Duet3 or Duetwifi? are you wanting to use 2 fans on the same tool?
          • arhi
            arhi last edited by arhi
            if you are using 2 fans to work on same hotend as aprt cooling fans, I do it, @omni is doing it, many others are doing it for sure, just connect them to the same output, if they are rated as your Vin connect them in parallel, if they are rated as Vin/2 (e.g. your Vin is 24V and your fans are 12V) wire them in series and ideally add 2 100uF across each one. 2 elcos, 100uF each, one across each fan.
            • omni
              omni @Veti last edited by
              @Veti Yup, as Arhi said - if your fans are rated the same voltage as your VIN run them in parallel. If they are half your voltage, run them in series - and you might want to put a zener diode on each end of the series just to protect the fans. That's how I am using these two beefy 12v blowers on a 24v VIN
              Heartleander81 1 Reply Last reply Reply Quote 1
              • Heartleander81
                Heartleander81 @omni last edited by
                I have two 24V Fans.
                My question is for a friend and me.
                I have a duet 3 6 hc and my friend has a duet 2 wifi.
                Ok i try this.
                M106 P2 S1 H-1
                Heartleander81 1 Reply Last reply Reply Quote 0
                • Heartleander81
                  Heartleander81 @Heartleander81 last edited by
                  I have config the Firmware with the tool but the both fans not start with M106 S255.
                  On the main can i start the Fan.
                  M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                  M106 P0 C"Hotend" S0 H0 T45 ; set fan 0 name and value. Thermostatic control is turned on
                  M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                  M106 P1 C"Bauteil1" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                  M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
                  M106 P2 C"Bauteil2" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
                  M563 P0 S"Hotend" D0 H1 F1:2 ; define tool 0
                    Phaedrux Moderator @Heartleander81 last edited by
                    Try specifying the fan number with M106 P1:2 S1
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
                    Are you sure both fans actually work?
                    Do they work if you connect them to the always on fan ports?
                    Are they wired to the right ports?
                    Can you control them both independently?
                    In the DWC do both fans turn on when using the Tool Fan slider?
                    • Heartleander81
                      Heartleander81 @Phaedrux last edited by Heartleander81
                      @Phaedrux yes both Fans work.
                      Yes i Can control them both independently.
                      In the DWC have i fan1 slider at 100% work fan1 and fan2 slider at 100% work fan2.
                      With M106 P1 S255 work fan 1, with M106 P2 S255 work fan 2 but M106 P1:2 S255 work only fan 1
                        M106 does not support a list of P parameters.
                        To use two part cooling fans on one tool, the simplest approach is to connect them in parallel to a single fan output. However, an alternative is to map them in the M563 command, for example:
                        M563 P0 D0 H1 F1:2
                        Then when tool 0 is selected, M106 Sxx with no P parameter will control both of them.
                        • Heartleander81
                          Heartleander81 @dc42 last edited by
                          @dc42 that have I make.
                          But doun't work.
                          M950 F1 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                          M106 P1 C"Hotend" S1 H0 T45 ; set fan 0 name and value. Thermostatic control is turned on
                          M950 F0 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                          M106 P0 C"Bauteil1" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                          M563 P0 S"Hotend" D0 H1 F F0: 1: 2 ; define tool 0
                          There is my code i Config.g
                            dc42 administrators @Heartleander81 last edited by dc42
                            Should be: M563 P0 S"Hotend" D0 H1 F0:2
                            Remove the second F and do not include the thermostatic fan in the M563 command.
                            Heartleander81 2 Replies Last reply Reply Quote 0
                            • Heartleander81
                              @dc42 i have change it. My finger was faster then my eyes 🙂
                              But fan 1 start fan 2 start not.
                              • Heartleander81
                                Ok i hope that is so ok now, but with M106 S255 start only Fan1. Fan2 can I only contol on DWC.
                                M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
                                M106 P1 C"Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                                M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                                M106 P0 C"Bauteil1" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                                M563 P0 S"Hotend" D0 H1 F0:2 ; define tool 0
                                  I think this is the expected behaviour. During a print do both fans work as expected?
                                  • Heartleander81
                                    @Phaedrux
                                    Unfortunately not. I can only control Fan2 via the slider in the DWC. With M106 S255, only fan 1 starts, not fan 1 and fan 2 together
                                      In DWC there should be a tool fan slider that controls both.
                                      • Heartleander81
                                        @Phaedrux
                                        I only have one for Fan1 and one for Fan2, none for both
                                          Can you post a screenshot of your DWC fan sliders?
                                          • Heartleander81
                                            • Heartleander81
                                              @Phaedrux need you more from the DWC ore is that so ok?
                                                Is that a screenshot from your phone? Can you connect to the DWC via a PC web browser?
                                                • Heartleander81
                                                  Heartleander81 last edited by Heartleander81
                                                  yes it was from my Phone. Now a screen from my Pc
                                                    If you click on "Allgemein" What version of Duet Web Control is shown?
                                                    If you look on the "status" page, you should see another fan control slider there that should have tool fan as well as the two part cooling fans. Tool fan should control both at the same time.
                                                    • Heartleander81
                                                      i change the language to english, i think is better for you
