    Inconsistent results with optical encoder wheel filament sensor
    Filament Monitor
    9
    168
    11.6k
    • JohnOCFIIundefined
      JohnOCFII @arhi
      @arhi said in Inconsistent results with optical encoder wheel filament sensor:
      @JohnOCFII I Don't have any black scrap that are 1-2mm thick and no pla at all but I just tested 2 pieces of nontransparent PETG, 1mm (silver) and 2mm (red) and oh boy they are transparent to IR ...
      take a remote controller and your mobile phone and look at the front of the remote with the camera, press "volume+" or some other "non stop going" button and you should see it strobing with your camera. now put a piece of plastic 1mm thin between the camera and remote and ...
      this is my test with PETG
      https://youtu.be/97H7YQFgKSw
      and phone camera has IR filter and my remote led is not very strong (some old remote from drawer with batteries from who knows when)... on the other hand the IR receiver on the gap sensor is much more sensitive to IR .. dunno if PLA (if you printed that with PLA) is more transparent but..
      Fascinating! I just tested with some cut apart vase-mode prints and an IR webcam in a dark room. The light easily shined through 1 layer (about 0.42mm) and was somewhat viewable through 2 layers. I'll print up some larger disks (not in vase mode -- just to replicate what I have now in the encoder wheel) and use that with various coverings to see what happens. I have some thick "liquid electrical tape" that might work well.
      https://www.homedepot.com/p/Gardner-Bender-Black-Liquid-Electrical-Tape-4-oz-LTB-400/100119178
      arhiundefined 1 Reply Last reply Reply Quote 0
      • arhiundefined
        arhi @JohnOCFII
        @JohnOCFII dunno how the liquid tape will do against IR, note that the sensor in the end stop is much more sensitive than your phone's camera as it does not have an IR filter. ALU tape is always my go-to for these type of things. It's good for so many things around 3d printing I always stock it. 🙂
        https://www.amazon.com/aluminum-tape/s?k=aluminum+tape
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          JohnOCFII @arhi
          Turns out -- I had purchased a roll of copper tape to try to resolve some other 3D printing related issue a couple of years ago. I assume that'll work here in place of aluminum?
          • arhiundefined
            arhi
            same thing only tad heavier 🙂 .. will work for this purpose
              JohnOCFII @arhi
              The encoder wheel in this design is so small -- just not sure how well any tape will work.
              I'm currently running the encoder wheel in the middle - 12 spokes.IMG_2013.jpeg
              • arhiundefined
                arhi
                should work ok with the middle one, glue the tape over the back side, then cut the "windows" open with a scalpel knife, should work like a charm
                JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                  JohnOCFII @arhi
                  Thanks for the advice. I'll try a fresh blade and give that a shot -- likely tomorrow.
                    JohnOCFII @arhi
                    That wasn't as tricky as I thought it'd be. I do think I'll try it again with a fresh X-Acto blade.
                    • arhiundefined
                      arhi
                      that should work like a charm, no transparency there now. the only question now is, will it provide a better readout now - was this transparency a problem or there's something else in play here.
                        JohnOCFII @arhi
                        I prepared the new axle and wheel with the copper tape. I used two coats of a black Sharpie to "paint" the shiny copper and installed the new axle. Sadly, the results are very similar. This is also from the vase mode print with no PA and no retraction.
                        Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 3.000mm/pulse, allowed movement 30% to 1500%, check every 10.0mm, measured sensitivity 0.581mm/pulse, measured minimum 70%, maximum 2543% over 1021.1mm
                        Next test will be in a few days when the new Saleae logic analyzer shows up - or if I decide to try the BitScope logic analyzer in a VM.
                        • arhiundefined
                          arhi @JohnOCFII
                          @JohnOCFII damn, so it was not transparency issue, damn, well, one idea out of the window 😞
                          dunno how to test for filament slipping on the tpu wheel
                            JohnOCFII @arhi
                            By removing the optical sensor, I can visually watch the wheel move during the test print I was using. As it was a vase mode cylinder, it was easy to confirm the wheel was moving continuously and (within the calibration of my MARK 1 EYEBALL) consistently. So, while it is possible during a "normal" print where I might have moves at 250mm/sec or other such changes in filament movement, I don't think that is an issue with this particular test.
                            Next will be to try to get a sense of what data is coming out of that sensor.
                            • arhiundefined
                              arhi @JohnOCFII
                              @JohnOCFII I'd still do that test without hotend
                              • remove hotend so you have only extrder drive and sensor
                              • disable "heating" in the g-code
                              • allow "cold extrusion" in the firmware
                              • do a print of a simple long extrusion g-code
                                JohnOCFII @arhi
                                Yes -- good idea. I will do that tomorrow.
                                  JohnOCFII @arhi
                                  I disconnected the extruder from the hot-end and set up some GCode to run so I could measure filament. I started with a test at 100mm, but M591 D0 is showing no data. Curious if not having the printer homed is causing the data collection to be ignored. Maybe I missed something.
                                  Here's my GCode:
                                  ; Test Extrusion
                                  M302 P1                                            ; Allow cold extrusion
                                  G92 X0Y0Z0                                         ; duet now assume we are homed
                                  M82                                                ; extruder absolute position
                                  G92 E0                                             ; reset extruder to 0
                                  M591 D0 P7 C"connlcd.encb" S0 R50:1500 L1.2 E5 A1  ; config filament sensor
                                  ; G1 E1000 F120                                     ; extrude 1000mm at 2mm/sec, so will be extruding around 8 minutes
                                  G1 E100 F120                                       ; extrude 100mm at 2mm/sec, so will be extruding around 1.2 minutes
                                  M591 D0                                            ; query filament sensor
                                  Time for some yard work! Got to go rake leaves.
                                  arhiundefined JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                                  • arhiundefined
                                    arhi @JohnOCFII
                                    @JohnOCFII you have to save that script as a file and make RRF print that file, you can't just execute the script as in that case filament monitor is disabled
                                      JohnOCFII @JohnOCFII
                                      @JohnOCFII said in Inconsistent results with optical encoder wheel filament sensor:
                                      Here's my GCode:
                                      ; Test Extrusion
                                      Yes, I saved it as ColdExtrusioTest.g and "printed" it same as I would any other file.
                                      There must be something else I'm missing. I'll have to think about it.
                                      10/31/2020, 3:10:14 PM	M591 D0
                                      Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, no calibration data
                                      10/31/2020, 3:07:37 PM	Finished printing file 0:/gcodes/Calibration/ColdExtrusionTest.g, print time was 0h 0m
                                      10/31/2020, 3:06:47 PM	M32 "0:/gcodes/Calibration/ColdExtrusionTest.g"
                                      File 0:/gcodes/Calibration/ColdExtrusionTest.g selected for printing
                                      Pulse-type filament monitor on pin (connlcd.encb,connlcd.3), disabled, sensitivity 1.200mm/pulse, allowed movement 50% to 1500%, check every 5.0mm, no data received
                                      10/31/2020, 3:05:50 PM	M591 D0
                                      10/31/2020, 3:03:59 PM	Finished printing file 0:/gcodes/Calibration/ColdExtrusionTest.g, print time was 0h 0m
                                      10/31/2020, 3:03:09 PM	M32 "0:/gcodes/Calibration/ColdExtrusionTest.g"
                                        JohnOCFII
                                        I homed the printer, then ran this file while it was still homed - no change in output.
                                        • arhiundefined
                                          arhi
                                          @JohnOCFII and it passed those 100mm trough extruder and sensor and the wheel were rotating? that's rotating rather slow right, can you check the impulses with a multimeter maybe? analog one would work great?
                                            JohnOCFII @arhi
                                            Yes. Also, the optical sensor board has an LED that was blinking at regular intervals.
                                            Depending on the weather, I'm supposed to fly with a student tomorrow (weekend flight instructor). If not, I'll try this tomorrow.
                                            Saleae LA should arrive Monday or Tuesday. 🙂
