    Powering Arduino Nano and LEDs from 5V rail
    608
    • taconiteundefined
      taconite
      Hey guys,
      I want to power a Arduino Nano from the 5V Rail of a Duet 2 Wifi (v1.4) and controll LEDs with it (I don't have heater or fan outputs to spare).
      I will use one remaining fan output to control the state of the LEDs
      Is there enought power to drive the Arduino Nano and approx 30 LEDs of a (300 LED/5m WS2812b LED strip)?
      Best Regards
      Adrian
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      peter247undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • peter247undefined
        peter247 @taconite
        @taconite
        I would say at a guess , NO , the best way is use a buck converter off the main psu.
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        • Vetiundefined
          Veti
          see this on how to do the wiring
          https://www.blvprojects.com/blv-mgn-cube-3d-printer?pgid=k8hkwn62-f7fe97b7-2106-47ec-9a07-47b5b8c9a191
            dc42 administrators @taconite
            @taconite said in Powering Arduino Nano and LEDs from 5V rail:
            Hey guys,
            Best Regards
            Adrian
            Arduino Nano: yes (although Arduino Pro Micro is a better one to use if it will take inputs directly from the Duet)
            LED strip: 30 LEDs * up to 60mA per LED = up to 1.8A. That's more than we recommend drawing from the Duet's 5V supply; so no.
            • taconiteundefined
              taconite
              Thank you for your replies!
              Why using a buck converter when I could just bi-pass the buck on the Nano. My concern is more about the current draw from the Duet.
              As my fans are running on 24V I will use a optocoupler to convert it to 5V
              Custom ANET A8
              • taconiteundefined
                taconite
                Thank you @dc42
                What is the recommended max current draw from the 5V supply?
                Custom ANET A8
                  Thank you @dc42
                  2A total, less 200mA for the Duet and any current drawn by LCDs, endstops and Z probes.
                  • taconiteundefined
                    taconite
                    So I guess I will do it like that:
                    Custom ANET A8
                    peter247undefined 1 Reply Last reply Reply Quote 0
                    • peter247undefined
                      peter247 @taconite
                      @taconite
                      Why the optocoupler ?
                      I can't see why you need one , if it is to switch the buck converter on you can find some buck converter which have a enabled pin.
                      • taconiteundefined
                        taconite
                        @peter247 With the PWM output of the Fan I want to control the color of the LED. e.G. 10% dutycylce = green. My Fan Voltage is 24V but the Arduino can only take 5V
                        Custom ANET A8
                        • peter247undefined
                          peter247 @taconite
                          @taconite
                          So if I have got this right you are going to power your arduino and looks like spi controlled leds from a fan with pwm ?.
                          your diagram makes not sense to me !!!!
                          Are you use spi controlled leds like dotstar ?
                          • taconiteundefined
                            taconite
                            So I kind of made it work with this scematic
                            Simulation show good results:
                            The Problem with that is, even if i just put on the Fan_PWM at 10% (S0.1) I get already 2.5V. Does anyone has an explanation of that? Because of that I am limited to less colors ("just 6").
                            This is the PCB I put together with an optocoupler, an DC/DC converter and an Arduino Nano.
                            Custom ANET A8
