    Whats does the roadmap look like for variables?
    Gcode meta commands
    11
    51
    2.8k
    • deckingmanundefined
      deckingman @dc42
      @dc42 From my perspective, there was a flurry of activity around the time of the launch, leading up to the TCT show, and for a few weeks after. But then all progress more or less dried up for the next 12 months which is why my patience ran out.
      Just out of curiosity, why is it taking soooo long to sort out PID tuning of heaters connected to expansion boards? It's a fairly basic thing to want to do. It's not my field of expertise but I wouldn't have thought that PID tuning is particularly processor intensive and most of the time is simply monitoring a single temperature channel or waiting for the temperature to settle/stabilise. Also the code exists for the main board so why is it so difficult to transfer to expansion boards?
        deckingman @deckingman
        BTW, has anybody else ever reported the seemingly random hot end fan blips when the machine is otherwise idle, that I mentioned repeatedly way back then. It's a minor annoyance but if it's just my machine, I would gladly know what I can can do to fix it.
        • A Former User?
          A Former User @deckingman
          @deckingman said in Whats does the roadmap look like for variables?:
          I have noticed that occurring in tandem with when my PSU internal fan kicks in at idle, so it might be related.
          deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
            deckingman @A Former User
            @CaLviNx said in Whats does the roadmap look like for variables?:
            Interesting..........although my PSUs are fanless so........
              dc42 administrators @A Former User
              That's interesting!
              I have 2 tools using tool boards, and I have never heard it happening.
              @deckingman , I could put some extra diagnostics in the firmware to try to track the cause down, but you would need to be using the beta firmware.
                deckingman @dc42
                @dc42 No I don't fancy the idea of running a beta firmware at this stage - it's one more potential variable that I don't want to throw into the equation. At least with 3.1.1, I know what the problems are.
                As to the issue itself, it's a minor irritation as I said at the outset. And unless you have the printer in very quiet environment with no other fans running (such as board cooling fans), and the hot end fan is reasonable noisy, you might not notice it happen unless you happen to be staring at it. It's a short blip - maybe one second or less.
                TBH, it may have even "gone away" on my machine running 3.1.1. - now that I've moved my printer out of my study into it's own "booth" in my garage, I can't say that I've noticed it (but I probably wouldn't due to the new location). Having said all that, I've just changed to liquid cooling so if it does happen again, I'd likely see/hear to coolant pump "blip" (although being a pump, it might not react to short sharp transient in any case).
                I'd guess that the only time it might be a problem is if someone happened to be poking around with the hot end fan when the "blip" happened. But even then, it's unlikely to even draw blood or do any physical harm, given the power of the average hot end fan. But it might make you jump......
                  Phaedrux Moderator @deckingman
                  While I understand the reluctance, wouldn't it be helpful to test the firmware before release to ensure the bugs are resolved rather than wait for the final release and discover there are the same or different bugs meaning having to wait again for another firmware release? Just sayin.
                    The experience so far is that beta 1 is stable, but beta 2 has a few glitches. We hope to release beta 3 next week.
                      Phaedrux Moderator @dc42
                      @dc42 I assume there is a release candidate coming as well once it's deemed stable and feature complete?
                        deckingman @Phaedrux
                        @Phaedrux said in Whats does the roadmap look like for variables?:
                        Up until a few months ago I used to do exactly that. But I've had my fingers burnt a few times in the past.
                        Classic example - earlier design versions of my hot end suffered a lot of stringing and I thought it was the complexity of the mixing chamber making retractions less effective. It turns out that the cause was the poor step pulse frequency. I had been using 64x micro-stepping (because that's what I used on Duet2) but RRF 3 did not report hiccups on expansion boards so I had no way of knowing about the firmware step pulse frequency issue. It was only when 3.1.1 came along that hiccups were reported and could see immediately that I was getting very high hiccup count during retractions. So I wasted a lot of time and effort re-designing my mixing chamber to reduce stringing when all I needed to do was reduce the micro-stepping from 64X to 16X to get around the firmware problem and restore proper retractions.
                        So if something strange or unexpected does happen with this hot end version, and I change the firmware as well, I can't be sure whether any problems would be related to the design or configuration of the hot end, rather than caused by a potential bug/change in behaviour of the firmware.
                        In a nutshell, I don't have a working hot end as a baseline against which I could evaluate any firmware changes. So any feedback I could give might be flawed due to some sort of mechanical issue with my experimental hot end.
                        The old adage "change only one thing at a time" is the only sensible way to develop something IMO.
                        arhiundefined 1 Reply Last reply Reply Quote 1
                        • arhiundefined
                          arhi @deckingman
                          This post is deleted!
