new duet 2 wifi not reading sd card
I have a Duet 2 Wifi that I finally was able to update the firmware but I couldn't use the web page and come to find out (using the M122 command) that the SD 0 was connected but only reading at 0.2 MBs So it looks like it isn't actually reading the SD card. I tried 6 different micro SD cards of varying capacities, all formated to FAT32, and none of them worked.
please help. -
@knightwolf313 said in new duet 2 wifi not reading sd card:
whats the error?
Can you post the results of M122?
Can you post a photo of the back of the SD card slot showing the solder tabs clearly?
When and where did you purchase your board?
@Veti it says that the duet rejected the http request: page not found. It then says to check that the ad card is mounted and has the correct files in the /www folder.
@Phaedrux ![alt text] (image url)
Sorry I thought I got a pic of the M122 but it didn't take. though today it said the sd card was reading at 30MBs as opposed to 0.2MBs as it did hte other day.
I bought the card through Filastruder on April 16th. I know I held off using it for a while, but I needed to wait till I had all the components and the display took forever to get here. (then I had to move last month and it took awhile to get everything ready after the move.)
check on your computer whats the content of the www folder on the sd card.
better to copy/paste the text if possible.
now that you've confirmed the computer sees the files, try
M20 S2 P"/www"
to see if the duet sees the same, but odds are it won't otherwise it'd just-work(tm). -
Yes please show the results of
M122
andM20 S2 P"/www"
If it's unable to read the /www folder then the web interface won't work and you can't upload gcode files, so that's no good.
If you have confirmed the same results with a few different cards and it's (intermittently?) showing the read speeds as 0.2MB/s then there is likely an issue with the SD card slot and we will do a warranty exchange. In which case, contact Filastruder and initiate a warranty claim. Include a link to this thread as authorization.
And I have tried with 6 different SD cards with no luck reading any of them.
Thanks for all the testing. Please contact Filastruder and initiate a warranty exchange. Please include a link to this thread as authorization.
@Phaedrux Thanks for the help and working with me on this.
