    Connect OLED display to stepper motor
    468
    • coolice2020undefined
      coolice2020
      I wonder if any of you have experience/tried to add those 0,96” OLED displays for a standard nema stepper motor ? (In my case: e3d super whooper)
      I know it is possible to buy complete servo kit from BIGTREE, but what I am looking for is to add it to a normal stepper motor.
      I know it is strange idea, but it looks super awesome 🙂 , so why not ?
      Many thanks for any help/guidance !
      • Vetiundefined
        Veti
        to display the information like rpm, you would need a closed loop setup.
        this would mean you would loose the ability to use the duet tmc stepper drivers.
        bigtree sells the closed loop board without the stepper motor
        https://www.biqu.equipment/products/bigtreetech-s42a-42-stepper-motor-closed-loop-driver-board-with-oled-display?variant=31362657615970
        see
        https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
        for connecting external stepper motors.
        coolice2020undefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User
          Whats the end goal? The display doesn't really do anything usefull unless coupled with a driver.
          As linked to you can buy the board and use with any stepper, but its much much more than just a display.
            coolice2020 @Veti
            @Veti
            I see, thanks for the heads up! Since you already recommended earlier the standard stepper motor setup against of the closed loop one, I would not sacrifice that just for having the displays. Many thanks!
              coolice2020 @A Former User
              @bearer said in Connect OLED display to stepper motor:
              Just purely for fun, as I had written it. No real function, but as Veti pointed out, since its only for closed loop, I need to drop this.
                Phaedrux Moderator @coolice2020
                @coolice2020 said in Connect OLED display to stepper motor:
                Don't give up on your dreams.
                Vetiundefined coolice2020undefined 2 Replies Last reply Reply Quote 0
                • Vetiundefined
                  Veti @Phaedrux
                  @Phaedrux
                  there is a new version
                  https://www.biqu.equipment/collections/stepper-motor-board/products/bigtreetech-s42b-v1-0-closed-loop-driver-control-board-42-stepper-motor-oled-3d-printer-parts
                  with canbus support.
                  there is a chance that someone will write support for it for the duet3.
                  But still not a good idea, since the stepper driver on it is a A4950, so it will be noisy.
                  coolice2020undefined 1 Reply Last reply Reply Quote 1
                  • oliofundefined
                    oliof
                    If you'd just install the encoder and power the board, but drove it via the normal 4 wire stepper driver, wouldn't the screen at least show the RPM?
                      coolice2020 @Phaedrux
                      @Phaedrux
                      Never!! Just try to listen on all of you, whom smarter on this field, than me.
                        coolice2020 @Veti
                        @Veti
                        Yeah, thats what I was afraid of. Thats life, at least for now
                          coolice2020 @oliof
                          @oliof
                          Excellent question, but I am afraid, I dont know.
