Problems with Using the manual bed levelling assistant
@the_dragonlord
no why are you running the G32?
@Veti said in Problems with Using the manual bed levelling assistant:
@the_dragonlord
to have an idea on how to adjust the 6 screws.....wouldn't be this the purpose of G32?
@the_dragonlord
as wrote here: https://forum.duet3d.com/topic/12356/error-calibration-failed-computed-corrections-nan-nan-nan-nan/2
In the last G30 I've changed S6 with S-1 and I get:
G32 bed probe heights: -0.634 -0.719 -0.818 -0.339 -0.068 0.045, mean -0.422, deviation from mean 0.327
try redung the x300 value in your bed get to 290
ook, thanks
@the_dragonlord said in Problems with Using the manual bed levelling assistant:
ook, thanks
I've adjusted the screw and now I got
G32
G32 bed probe heights: -0.369 -0.432 -0.442 -0.440 -0.284 -0.312, mean -0.380, deviation from mean 0.063It doesn't seem too bad, inst'it?
Now I'm starting to build the height mesh with G29 S0 let's see what happens
@the_dragonlord
only allows for max of 4 points
@the_dragonlord
uh, that was the problem...ok, thanks
@the_dragonlord
Here's my height map....looking at the graph it looks awful is it really so?
@the_dragonlord
that depends on the prints it produces. -
@the_dragonlord
uh, yes, of course....now I'm printing a bed leveling test in wich start GCode I've placed:G28 XY ;Home XY
M561 ; Clear any bed transform that might be in place
G1 X165 Y165 ; Move Probe to middle of bed
G30 ; Do a single probe
G29 S1 ; load height map
G1 Z20.0 F6000 ; Move Z to 20we'll see....
@the_dragonlord
That looks like it could be gantry sag rather than the bed being warped up. Regardless, mesh compensation should be able to correct for it. Only way to know for sure is to test.
bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
Print twice. Once with G29 heightmap loaded and again without.
@Phaedrux said in Problems with Using the manual bed levelling assistant:
@the_dragonlord
excellent, thanks!
