    SSID Changed - can not be found
    405
    • pro3dundefined
      pro3d
      So I sold my V-King and are trying to help the customer connecting to his wifi. The SSID has been changed on the router to "Sørensen Sport" and when I try to ender this to the network list it saves but when activating the wifi with M552 S1 it does not find the network
      Do I need the original SSID or is there a problem with unknown characters in this name?
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      • pro3dundefined
        pro3d
        Here is the error from YAT:
        ok<LF>WiFi module started<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>
          Phaedrux Moderator @pro3d
          @pro3d said in SSID Changed - can not be found:
          Sørensen
          I wonder if the ø is an issue.
          https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
          You can send M587 by itself to read back saved SSIDs to see if anything was added sucessfully.
          You can also send M588 S"*" to forget all currently saved SSIDs and then try to readd them.
          Sometimes sending SSIDs over USB is problematic due to the way terminals send special characters or all capitals, so sometimes it can help by creating a macro on the SD card with the command to add the SSID and then executing the macro.
          Example:
          ; Add default wifi network
          M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
          M552 S0			; Disable network module
          G4 S5			; wait 5 seconds
          M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
          M552 S1			; reenable wifi module
          M291 R"duetwifi SSID added." P"Check console to verify IP address."
          ; Clear all wifi networks
          M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10
          M588 S"*"			; Clear all saved wifi networks
          M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
          pro3dundefined 1 Reply Last reply Reply Quote 0
          • pro3dundefined
            pro3d @Phaedrux
            @Phaedrux
            The networks seems to be saved:
            M587
            Remembered networks:<LF>Sørensen Sport IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
              If possible I would try testing with a simplified SSID such as sorensonsport no special characters, no capitals, no spaces.
                Also, are you sure the SSID in question is a 2.4Ghz access point? The Duet cannot connect to a 5Ghz network. If possible on the router, create a separate 2.4Ghz network.
                • pro3dundefined
                  pro3d @Phaedrux
                  @Phaedrux
                  It is an access point with 2.4 and 5ghz network. We will try to set up another one with a simple ssid
                    As a sanity check you can configure the Duet to run in access point mode to see if the wifi module, etc is functioning correctly.
                    https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M589_Configure_access_point_parameters
