    My quad carriage machine is failing on Tools. AGAIN.
    3.6k
      Phaedrux Moderator @MaracMB
      @MaracMB said in My quad carriage machine is failing on Tools. AGAIN.:
      p”config.g”
      I think it's the curly quotes. Note the difference between ” and "
      Are you using a mac by chance?
      https://bear.app/faq/How to disable smart quotes and dashes/
      MaracMBundefined 2 Replies Last reply Reply Quote 0
      • MaracMBundefined
        MaracMB @Phaedrux
        @Phaedrux no, but it’s probably due to teamviewer with iphone issue. That’s how i communicate with it while away
        • MaracMBundefined
          MaracMB @Phaedrux
          @Phaedrux
          Error: in file macro line 158 column 14: M567: array too long, max length = 2
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 302C
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 665C
          Warning: Heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 482C
          8. 11. 2020 20:25:01 Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
            Looks like this one
            M567 P4 E1:1:0:0
            But no error from this one
            M567 P5 E1:1:1:1
              dc42 administrators @Phaedrux
              @Phaedrux said in My quad carriage machine is failing on Tools. AGAIN.:
              Looks like this one
              M567 P4 E1:1:0:0
              That figures. The M563 command that creates tool 4 is this:
              M563 P4 S"DITTOFront" D0:1 H1:2 X0:5 F0:1 ; Tool 2 uses extruders 1 and 2, hotend heaters 1 and 2, maps X to X and U, uses tool fans 4 and 5
              Tool 4 uses two extruder drives, so it expect two E values, not four.
              • MaracMBundefined
                MaracMB
                Dc42, thank you. Yes, those tools... don’t even have tfree, tpost, etc files . WIP.
                while this obviously causes something while printing - using tools, when they will be configured...
                why would it cause stepper motors 5&6 (first motors on duex and their endstops) to “stutter” occasionaly on homing Z ?
                Before rewiring, when those stepper drivers were mapped for X carriages for tools T1 and T2, those axes stuttered mid print.
                It was hard to see. Was seen on print once you know what too look...
                After rewiring, using and mapping those motors to Z, it’s easier to reproduce and hopefully debug
                  I don't think it's related. I'm still looking through your other files.
                    So your package of config files currently has the A axis configured as the second Z axis. Are you wanting to keep it this way for independent jogging? If it's just for homing it would be better to remove it entirely.
                    Here's a modified config.g with the recommended changes (removes A axis entirely, uses x16 microstepping with interpolation across the board, and changes the Z endstops to use both switches for homing/leveling, and fixes that error in M567.)
                    ; by MaracMB
                    G90  							; send absolute coordinates...
                    M83  							; relative extruder moves
                    M550 P"MarX-Quad"  				; set printer name
                    M552 S1  						; enable network
                    M586 P0 S1  					; enable HTTP
                    M586 P1 S0  					; disable FTP
                    M586 P2 S0  					; disable Telnet
                    M569 P0 S0  					; physical drive 0 X goes backwards - X0
                    M569 P1 S1  					; physical drive 1 Y goes forwards - X1
                    M569 P2 S1  					; physical drive 2 Z goes forwards - Y
                    M569 P3 S1  					; Physical drive 3 E0 goes forwards - X2
                    M569 P4 S1  					; Physical drive 4 E1 goes forwards - X3
                    M569 P5 S1  					; Physical drive 5 E2 goes forwards - Z1
                    M569 P6 S1  					; Physical drive 6 E3 goes forwards - Z2
                    M569 P7 S0  					; physical drive 7 E4 goes backwards - e1
                    M569 P8 S0  					; physical drive 8 E5 goes backwards - e2
                    M569 P9 S0  					; physical drive 9 E6 goes backwards - e3
                    M569 P10 S0  					; physical drive 10 Ext1 goes backwards - e4
                    ;Mapping drives
                    M584 X0 Y2 Z5:6 U1 V3 W4 	; Extruder mapping
                    M584 E7:8:9:10 					; Extruder mapping
                    M350 X16 Y16 Z16 U16 V16 W16 I1 ; Configure microstepping movement
                    M350 E16:16:16:16 I1 			; Configure microstepping extruders
                    ; Motion parameters
                    M92 X80 Y80 Z800 U80 V80 W80  		; Set steps per mm motion
                    M92 E396:396:396:396 							; Set steps per mm extruders
                    M566 X420 Y420 Z15 U420 V420 W420  		; set maximum instantaneous speed changes motion (mm/min)
                    M566 E320:320:320:320 							; set maximum instantaneous speed changes extruders(mm/min)
                    M203 X12000 Y12000 Z1200 U12000 V12000 W12000 ; set maximum speeds motion (mm/min)
                    M203 E7200:7200:7200:7200           				; set maximum speeds extruders(mm/min)
                    M201 X880 Y880 Z240 U880 V880 W880					; set accelerations motion (mm/s^2)
                    M201 E7200:7200:7200:7200                  		; set accelerations extruders (mm/s^2)
                    M906 X950 Y1050 Z1050 U950 V950 W950 I30 				; set motor currents (mA) and motor idle factor in per cent motion
                    M906 E950:950:950:950 I30 									; set motor currents (mA) and motor idle factor in per cent extruders
                    M84 S30 													; idle time
                    M208 X-170 Y-165 Z0 U-112 V-157 W-112 S1 					; Set axies minimas
                    M208 X115 Y155 Z350 U168 V112 W158 S0 						; Set axies maximas
                    M574 X1 S1 P"!xstop" 			; configure active-low endstop for low end
                    M574 Y1 S1 P"!zstop" 			; configure active-low endstop for low end
                    M574 Z1 S1 P"!duex.e2stop+!duex.e3stop" 		; configure active-low endstop for low end
                    M574 U2 S1 P"!ystop" 			; configure active-low endstop for high end
                    M574 V1 S1 P"!e0stop" 			; configure active-low endstop for low end
                    M574 W2 S1 P"!e1stop" 			; configure active-low endstop for high end
                    ;M558 P0 H5 F120 T6000 							; disable Z probe but set dive height, probe speed and travel speed
                    ;M557 X-125:125 Y-125:125 S125 	 				; define mesh grid
                    ; Heaters and sensors
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 	            ; configure sensor 0
                    M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1
                    M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2
                    M308 S3 P"duex.e4temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 3
                    M308 S4 P"duex.e5temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 4
                    M308 S5 Y"mcu-temp" A"MCU" 				    				; Configure sensor for MCU
                    M308 S6 Y"drivers" A"DRIVERS" 								; configure sensor 6 as temperature warning and overheat flags on the TMC2660 on Duet
                    M950 H0 C"bedheat" T0                                       ; create bed heater output on bedheat and map it to sensor 0
                    M307 H0 B0 S1.00                                            ; disable bang-bang mode for the bed heater and set PWM limit
                    M143 H0 S120                                                ; set temperature limit for heater 0 to 120C
                    M140 H0                                                     ; map heated bed to heater 0
                    M950 H1 C"duex.e2heat" T1                                   ; create nozzle heater output on duex.e3heat and map it to sensor 1
                    M143 H1 S300                                                ; set temperature limit for heater 1 to 300C
                    M307 H1 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                    M950 H2 C"duex.e3heat" T2                                   ; create nozzle heater output on duex.e4heat and map it to sensor 2
                    M143 H2 S300                                                ; set temperature limit for heater 2 to 300C
                    M307 H2 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                    M950 H3 C"duex.e4heat" T3                                   ; create nozzle heater output on duex.e5heat and map it to sensor 3
                    M143 H3 S300                                                ; set temperature limit for heater 3 to 300C
                    M307 H3 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                    M950 H4 C"duex.e5heat" T4                                   ; create nozzle heater output on duex.e6heat and map it to sensor 4
                    M143 H4 S300                                                ; set temperature limit for heater 4 to 300C
                    M307 H4 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                    M950 F0 C"duex.fan4" Q1000 		; create fan 1 on pin duex.fan4 and set its frequency TOOL FAN 0
                    M106 P0 S0 H-1 					; set fan 1 value. Thermostatic control is turned off TOOL FAN 0
                    M950 F1 C"duex.fan5" Q1000 		; create fan 2 on pin duex.fan5 and set its frequency TOOL FAN 1
                    M106 P1 S0 H-1 					; set fan 2 value. Thermostatic control is turned off TOOL FAN 1
                    M950 F2 C"duex.fan6" Q1000 		; create fan 3 on pin duex.fan6 and set its frequency TOOL FAN 2
                    M106 P2 S0 H-1 					; set fan 3 value. Thermostatic control is turned off TOOL FAN 2
                    M950 F3 C"duex.fan8" Q1000 		; create fan 4 on pin duex.fan8 and set its frequency TOOL FAN 3
                    M106 P3 S0 H-1 					; set fan 4 value. Thermostatic control is turned off TOOL FAN 3
                    M950 F4 C"fan0" Q1000 			; create fan 5 on pin fan0 and set its frequency HOTEND FAN tool 0
                    M106 P4 S0 H1 T45 				; set fan 5 value. Thermostatic control is turned on HOTEND FAN tool 0
                    M950 F5 C"fan1" Q1000 			; create fan 6 on pin fan1 and set its frequency HOTEND FAN tool 1
                    M106 P5 S0 H2 T45 				; set fan 6 value. Thermostatic control is turned on HOTEND FAN tool 1
                    M950 F6 C"fan2" Q1000 			; create fan 7 on pin fan2 and set its frequency HOTEND FAN tool 2
                    M106 P6 S0 H3 T45 				; set fan 7 value. Thermostatic control is turned on HOTEND FAN tool 2
                    M950 F7 C"duex.fan3" Q1000 		; create fan 3 on pin duex.fan3 and set its frequency HOTEND FAN tool 3
                    M106 P7 S0 H4 T45 				; set fan 3 value. Thermostatic control is turned on HOTEND FAN tool 3
                    ;Extra fan ports
                    ;external stepper - PWMed
                    M950 F8 C"duex.fan7" Q500 		; fan 8 on pin duex.fan7 EXTRA FAN
                    M106 P8 S0 H-1 C"extFan" 		; set fan 8 value. Thermostatic control is turned off
                    ;LED strip
                    ;M950 F5 C"duex.pwm" 			; create port for LEDs on pin duex.fan8
                    ;M106 P5 S0 C"LIGHTS" 			; LED control
                    M563 P0 X0 D0 H1 F0 			; define tool 0
                    G10 P0 X0 Y0 Z0 U0 V0 W0 		; set tool 0 axis offsets
                    G10 P0 R0 S0 					; set initial tool 0 active and standby temperatures to 0C
                    M563 P1 X3 D1 H2 F1 			; define tool 1, ports X axis to U
                    G10 P1 X0 Y0 Z0 U0.45 V0 W0		; set tool 1 axis offsets
                    G10 P1 R0 S0 					; set initial tool 1 active and standby temperatures to 0C
                    M563 P2 X4 D2 H3 F2 			; define tool 3, ports X axis to A
                    G10 P2 X0 Y161.85 Z0 U0 V0.35 W0 ; set tool 2 axis offsets
                    G10 P2 R0 S0 					; set initial tool 1 active and standby temperatures to 0C
                    M563 P3 X5 D3 H4 F3 			; define tool 3, ports X axis to A
                    G10 P3 X0 Y175.2 Z0 U0 V0 W0.32 	; set tool 3 axis offsets
                    G10 P3 R0 S0 					; set initial tool 1 active and standby temperatures to 0C
                    ; DITTO TOOLs
                    G10 P4 X77 Y0 U-77    									; Set tool offsets and temperatures for tool 2 - moves X 77 left and U 77 right
                    G10 P4 R0 S0
                    M567 P4 E1:1 								; Set mix ratio 100% on both front extruders
                    M563 P5 S"QUAD" D0:1:2:3 H1:2:3:4 X0:3:5:6 F0:1:2:3		; Tool 6 uses extruders 1,2,3and4, hotend heaters 1,2,3and4, maps X to U,A and B, and tool fans 4,5,6 and 7
                    G10 P5 Y0 X0 U-155 V0 W-155   							; Set tool offsets and temperatures for tool 2 - moves X 77 left and U 77 right
                    G10 P5 R0 S0
                    M567 P5 E1:1:1:1										; Set mix ratio 100% on all extruders
                    M563 P6 S"DD left" D0:2 H1:3 X0:4 F0:2
                    G10 P6 X0 Y0 U0 V0 W0
                    G10 P6 R0 S0
                    M563 P7 S"DD right" D1:3 H2:4 X3:5 F1:3
                    G10 P7 X0 Y0 U0 V0 W0
                    G10 P7 R0 S0
                    ;Firmware retractions
                    M207 P0 S0.70 F2100 T2500 Z0.4
                    M207 P1 S0.70 F2100 T2500 Z0.4
                    M207 P2 S0.70 F2100 T2500 Z0.4
                    M207 P3 S0.70 F2100 T2500 Z0.4
                    ;Filament runout sensors
                    ; Automatic saving after power loss is enabled
                    M911 S23.00 R23.50 P"M913 X0 Y0 U0 V0 W0 G91 M83 G1 Z2 E-4 F3000" ; Set voltage thresholds and actions to run on power loss
                    ; MISC
                    M501
                    And a simplified homeall/homez
                    ; homeall.g
                    ; called to home all axes
                    ; scripted by Marac
                    G91                     	; relative positioning
                    G1 H2 Z2 F360           	; lift Z relative to current position
                    G1 H1 X-400 Y-450 U400 V-400 W400 F3600	; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 X5 Y5 U-5 V5 W-5 F3600         	; go back a 5 mm
                    G1 H1 X-10 Y-10 U10 V-10 W10 F360 			; second pass
                    M400
                    M98 Phomez.g			; call homing script for Z axes
                    G90
                    ; homez.g
                    ; called to home the Z axis
                    G1 Z-405 F900 H1
                    Can you give those a try? Send M98 P"config.g" first just to check for any syntax errors I may have inadvertently introduced.
                    Also, just a note for all of your homing files: Only use H2 modifier when you want to move an axis that isn't already homed. Using it otherwise can hide errors because it will allow an axis to move when it isn't homed.
                    example: G1 U-2 F600 H2 ; go back a few mm
                    That move is supposed to happen after the axis has been homed, so the H2 shouldn't be needed. If there was a failure to home the H2 would hide that failure and force movement anyway.
                    Normally it's just used to life the Z axis slightly before move the XY axis for clearance.
                    MaracMBundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    • MaracMBundefined
                      MaracMB @Phaedrux
                      @Phaedrux thank you.
                      tried proposed config. nothing new. same results.
                      it homes all the first time.
                      but then when i call to homeall again, it fails to home. It either does not move left or right Z motor, or it fails to trigger the endstop.
                      MaracMBundefined 1 Reply Last reply Reply Quote 0
                      • MaracMBundefined
                        MaracMB @MaracMB
                        correction, as i can't see both endstop states i sent home all from phone and monitored Endstops triggered from Settings>machine specific on the screen.
                        Ran homeall until it fails to home correctly.
                        It shows endstop as triggered but motor (in this case left Z) keeps grinding and does not stop. It also does this in it's own random pattern on the right side.
                        Endstops are OMRON optical endstops, fed by 5V from the CONN_SD.
                        I set the endstops voltage jumper select on the Duex5 to 5V. The endstops on duex are now wired and fed from their designated pins. Same results no matter how i connect them. No matter what the endstop voltage jumper position is.
                        • MaracMBundefined
                          MaracMB @MaracMB
                          after failed homing:
                          as said, on failed Z homing, while motors grinding and the endstop for Z showed as triggered. I hit emergency stop, board restarts. Endstop for Z shows as not triggered
                            jay_s_uk
                            Any i2c errors being reported in M122 when it fails to home?
                            • MaracMBundefined
                              MaracMB @jay_s_uk
                              @jay_s_uk when i hit homeall, and again until it fails (it's like a 3rd or fourth attempt) it grinds until i hit emergency stop.
                              Running m122 right after restart gives:
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                              Board ID: 08DGM-9T6BU-FG3SN-6J9F6-3SN6L-KUWVG
                              Used output buffers: 3 of 24 (18 max)
                              Static ram: 27980
                              Dynamic ram: 97812 of which 44 recycled
                              Exception stack ram used: 264
                              Never used ram: 4972
                              Tasks: NETWORK(ready,348) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:00:14 ago, cause: software
                              Last software reset at 2020-11-09 12:27, reason: User, spinning module GCodes, available RAM 4700 bytes (slot 0)
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                              Error status: 0
                              MCU temperature: min 35.3, current 35.8, max 36.2
                              Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 5: standstill, SG min/max not available
                              Driver 6: standstill, SG min/max not available
                              Driver 7: standstill, SG min/max not available
                              Driver 8: standstill, SG min/max not available
                              Driver 9: standstill, SG min/max not available
                              Date/time: 2020-11-09 12:28:02
                              Cache data hit count 23635152
                              Slowest loop: 6.31ms; fastest: 0.13ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 1.1ms, write time 0.0ms, max retries 0
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 15.71ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              - WiFi -
                              Network state is active
                              WiFi firmware version 1.23
                              WiFi MAC address 84:f3:eb:83:45:0d
                              WiFi Vcc 3.43, reset reason Unknown
                              WiFi flash size 4194304, free heap 23352
                              WiFi IP address 192.168.0.125
                              WiFi signal strength -48dBm, reconnections 0, sleep mode modem
                              === DueX ===
                              Read count 1, 4.07 reads/min
                              so, i'd say no.
                                Phaedrux Moderator @Phaedrux
                                ;Mapping drives M584 X0 Y2 Z5:6 U1 V3 W4 ; Extruder mapping M584 E7:8:9:10 ; Extruder mapping
                                I think we've defined too many drivers, haven't we?
                                5 on the duet, 5 on the duex. 0-9 for 10 total, Driver10 doesn't exist.
                                So you have both Z motors and 3 extruders on the Duex? And XYUVW on the Duet?
                                When you test the endstops individually and check them with M119 they all work and match the expected axis?
                                • MaracMBundefined
                                  MaracMB @Phaedrux
                                  Yes @Phaedrux, all endstops work at mapped axis.
                                  It has 11 motors, so there is motor 10 since you count from 0. not sure how would i count and set them otherwise?
                                  (5) XYUVW is on duet
                                  (2) Z1 and Z2 are on duex
                                  (3) Then there are 3 extruders at motors 7,8,9
                                  (1) and the 4th extruder is external wired to CONN_LCD
                                  5+2+3+1=11
                                    I didn't see you you were using an external driver as well.
                                      Does homeZ by itself work? G28 Z
                                      • MaracMBundefined
                                        MaracMB @Phaedrux
                                        @Phaedrux yes. But with occasional “glitching” as described.
                                          One thing I can think of to help narrow down the issue is to change over the motor mappings to have the Z motors on the Duet and move 2 of the carriages over to the Duex. If the problem homing moves to the motors on the Duex then we can be reasonably certain it's a comms issue between the duex and duet.
                                          • MaracMBundefined
                                            MaracMB @Phaedrux
                                            @Phaedrux this was already done. Having Z motors on duex instead of second and fourth X axis got me to here.
                                            engikeneerundefined 1 Reply Last reply Reply Quote 0
