    My quad carriage machine is failing on Tools. AGAIN.
    3.6k
      Phaedrux Moderator @MaracMB
      @MaracMB said in My quad carriage machine is failing on Tools. AGAIN.:
      As suggested by @engikeneer, i have joint the Z axes. Is this now a problem?
      homez.g :
      G91 ; relative positioning G1 H2 Z5 F600 G1 Z-405 F900 H1 G1 Z2 F900 H2 G1 Z-5 F360 H1 G1 Z3 F900 ; lift both Zs to 3 G90 ; absolute positioning
      This is correct in RRF3, but you've not changed the endstop configuration to match.
      M574 X1 S1 P"!xstop" 			; configure active-low endstop for low end
      M574 Y1 S1 P"!zstop" 			; configure active-low endstop for low end
      M574 Z1 S1 P"!duex.e2stop" 		; configure active-low endstop for low end
      M574 U2 S1 P"!ystop" 			; configure active-low endstop for high end
      M574 V1 S1 P"!e0stop" 			; configure active-low endstop for low end
      M574 W2 S1 P"!e1stop" 			; configure active-low endstop for high end
      M574 A1 S1 P"!duex.e3stop" 		; configure active-low endstop for low end
      The Z endstop should be `M574 Z1 S1 P"!duex.e2stop+!duex.e3stop"
      Assuming the second Z axis was A before the change. You'd also need to remove any references to the A axis unless you want to retain the ability to move/jog them independently. If all you want is the auto leveling with endstops, you don't need to split the Z into separate axis at all.
      MaracMBundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @MaracMB
        @MaracMB I notice you have one of your motors (Y-axis?) very close to the Duet/Duex ribbon cable. Might it be that that is causing EMI and impacting the I2C? I'd try unplugging the Y-motor completely and seeing if it helps things.
        Was the M122 output after you'd had some failed homings? I don't know what values you'd be looking for but they didn't seem crazy. Maybe someone who knows can comment...
        One other thought - if your current Duex is a clone, there is always the chance that there is an issue with the board. In particular, I'd pull it out and double check all the soldering. I got a clone Duet WiFi earlier in the year and had to redo a few of the joints that they hadn't soldered properly (one was the bed heater so very glad I spotted!).
        i3 clone with a bunch of mods
        • MaracMBundefined
          MaracMB @Phaedrux
          @Phaedrux yes i do only use split Z to Z and A when homing. I did try to join those, make a double endstop on single axis. but was experiencing the same thing. will try again as suggested maybe just because it makes no difference and there is one less thing to worry about as it certainly makes no difference otherwise.
          @engikeneer you might be correct. there must be some EMI. with the abundant wiring, that can easily be the case.
          yes, sadly, clone it is for now. original got damaged smd component (my fault) and also got shot on some voltage regulators for a fan due to closed circuit i overlooked. So i had a duex clone at hand so that's what i used. sux, not ideal, but has to do for now.
          i can not afford originals until i get this working, but after that, i will most certainly put an original Duex5 in it. Not because it would work better, but reliability (better capacitors, fuse, latest version of pcb, etc), warranty, support i get here... it is just the right thing to do.
          I suggest people on socials to use original duets because of that. it is the support that one pays. Clones are waaay too expensive for what one gets imho.
          Anyhow.
          In the time waiting and thinking i got pretty intimate with e3d toolchanger configs and scripts (from nibbles). They don't have so many axes moving, but that code is much nicer and thought out with running conditionals, low current homing (probably due to sensorless homing i guess) and m400's within called scripts. Much better. I must adapt that.
          for the time being, i just home Z by manually calling it , then Gcode just homes X Y U V W. That works for now.
          Anyhow, i'll report here if EMI is the cause it's the most logical next reason.
          Thank you all for now.
            Do you think you could upload your complete config file as files so I can take a look at them together in my text editor more easily? It's a rather complex config and it would be a lot easier than scrolling around trying to find the current versions. Once I can see the whole picture it may become more apparent what should change.
            Also, I think it might be best to stick to 3.1.1 for the time being. I don't think there are any fixes in there that would help you, and there may be other bugs in 3.2 that would hurt.
            • MaracMBundefined
              MaracMB @Phaedrux
              @Phaedrux sure. i'll make a backup zip of the whole thing when i get back to it.
              reverted back to 3.1.1 already.
              spent way to much time just watching it fail.
              changed the wires for that possible EMI at IDE cable... no luck.
              as linked, i did a video, where i click home Z button in DWC. Only that button. If you observe, you can see that sometimes it fails to run left Z motor, then works like couple of times, then fails right, then left, then altough it runs motors it fails to stop on an endstop... i mean, it really makes no sense. it's a machine. an error should make repeatable fails.
              https://drive.google.com/file/d/1bWrnUszf52sSI6WxNkiBHYnSRBgFj5J1/view?usp=sharing
              the thing that is repeating is it fails on the same drivers. but different board did no difference.
                can you also provide the results of sending M98 P"config.g" in the gcode console?
                • MaracMBundefined
                  MaracMB @Phaedrux
                  @Phaedrux
                  calling config with m98 returns:
                  m98 p”config.g”
                  Warning: Macro file ”config.g” not found
                  whole zipped package is here:
                  https://www.dropbox.com/s/67teetv5d67ot7z/firmware backup 2020-11-8.zip?dl=0
                    p”config.g”
                    I think it's the curly quotes. Note the difference between ” and "
                    Are you using a mac by chance?
                    https://bear.app/faq/How to disable smart quotes and dashes/
                    MaracMBundefined 2 Replies Last reply Reply Quote 0
                    • MaracMBundefined
                      MaracMB @Phaedrux
                      @Phaedrux no, but it’s probably due to teamviewer with iphone issue. That’s how i communicate with it while away
                      • MaracMBundefined
                        MaracMB @Phaedrux
                        @Phaedrux
                        Error: in file macro line 158 column 14: M567: array too long, max length = 2
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 302C
                        Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 665C
                        Warning: Heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 482C
                        8. 11. 2020 20:25:01 Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                          Looks like this one
                          M567 P4 E1:1:0:0
                          But no error from this one
                          M567 P5 E1:1:1:1
                            dc42 administrators @Phaedrux
                            @Phaedrux said in My quad carriage machine is failing on Tools. AGAIN.:
                            Looks like this one
                            M567 P4 E1:1:0:0
                            That figures. The M563 command that creates tool 4 is this:
                            M563 P4 S"DITTOFront" D0:1 H1:2 X0:5 F0:1 ; Tool 2 uses extruders 1 and 2, hotend heaters 1 and 2, maps X to X and U, uses tool fans 4 and 5
                            Tool 4 uses two extruder drives, so it expect two E values, not four.
                            • MaracMBundefined
                              MaracMB
                              Dc42, thank you. Yes, those tools... don’t even have tfree, tpost, etc files . WIP.
                              while this obviously causes something while printing - using tools, when they will be configured...
                              why would it cause stepper motors 5&6 (first motors on duex and their endstops) to “stutter” occasionaly on homing Z ?
                              Before rewiring, when those stepper drivers were mapped for X carriages for tools T1 and T2, those axes stuttered mid print.
                              It was hard to see. Was seen on print once you know what too look...
                              After rewiring, using and mapping those motors to Z, it’s easier to reproduce and hopefully debug
                                I don't think it's related. I'm still looking through your other files.
                                  So your package of config files currently has the A axis configured as the second Z axis. Are you wanting to keep it this way for independent jogging? If it's just for homing it would be better to remove it entirely.
                                  Here's a modified config.g with the recommended changes (removes A axis entirely, uses x16 microstepping with interpolation across the board, and changes the Z endstops to use both switches for homing/leveling, and fixes that error in M567.)
                                  ; by MaracMB
                                  G90  							; send absolute coordinates...
                                  M83  							; relative extruder moves
                                  M550 P"MarX-Quad"  				; set printer name
                                  M552 S1  						; enable network
                                  M586 P0 S1  					; enable HTTP
                                  M586 P1 S0  					; disable FTP
                                  M586 P2 S0  					; disable Telnet
                                  M569 P0 S0  					; physical drive 0 X goes backwards - X0
                                  M569 P1 S1  					; physical drive 1 Y goes forwards - X1
                                  M569 P2 S1  					; physical drive 2 Z goes forwards - Y
                                  M569 P3 S1  					; Physical drive 3 E0 goes forwards - X2
                                  M569 P4 S1  					; Physical drive 4 E1 goes forwards - X3
                                  M569 P5 S1  					; Physical drive 5 E2 goes forwards - Z1
                                  M569 P6 S1  					; Physical drive 6 E3 goes forwards - Z2
                                  M569 P7 S0  					; physical drive 7 E4 goes backwards - e1
                                  M569 P8 S0  					; physical drive 8 E5 goes backwards - e2
                                  M569 P9 S0  					; physical drive 9 E6 goes backwards - e3
                                  M569 P10 S0  					; physical drive 10 Ext1 goes backwards - e4
                                  ;Mapping drives
                                  M584 X0 Y2 Z5:6 U1 V3 W4 	; Extruder mapping
                                  M584 E7:8:9:10 					; Extruder mapping
                                  M350 X16 Y16 Z16 U16 V16 W16 I1 ; Configure microstepping movement
                                  M350 E16:16:16:16 I1 			; Configure microstepping extruders
                                  ; Motion parameters
                                  M92 X80 Y80 Z800 U80 V80 W80  		; Set steps per mm motion
                                  M92 E396:396:396:396 							; Set steps per mm extruders
                                  M566 X420 Y420 Z15 U420 V420 W420  		; set maximum instantaneous speed changes motion (mm/min)
                                  M566 E320:320:320:320 							; set maximum instantaneous speed changes extruders(mm/min)
                                  M203 X12000 Y12000 Z1200 U12000 V12000 W12000 ; set maximum speeds motion (mm/min)
                                  M203 E7200:7200:7200:7200           				; set maximum speeds extruders(mm/min)
                                  M201 X880 Y880 Z240 U880 V880 W880					; set accelerations motion (mm/s^2)
                                  M201 E7200:7200:7200:7200                  		; set accelerations extruders (mm/s^2)
                                  M906 X950 Y1050 Z1050 U950 V950 W950 I30 				; set motor currents (mA) and motor idle factor in per cent motion
                                  M906 E950:950:950:950 I30 									; set motor currents (mA) and motor idle factor in per cent extruders
                                  M84 S30 													; idle time
                                  M208 X-170 Y-165 Z0 U-112 V-157 W-112 S1 					; Set axies minimas
                                  M208 X115 Y155 Z350 U168 V112 W158 S0 						; Set axies maximas
                                  M574 Z1 S1 P"!duex.e2stop+!duex.e3stop" 		; configure active-low endstop for low end
                                  ;M558 P0 H5 F120 T6000 							; disable Z probe but set dive height, probe speed and travel speed
                                  ;M557 X-125:125 Y-125:125 S125 	 				; define mesh grid
                                  ; Heaters and sensors
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 	            ; configure sensor 0
                                  M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1
                                  M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2
                                  M308 S3 P"duex.e4temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 3
                                  M308 S4 P"duex.e5temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 4
                                  M308 S5 Y"mcu-temp" A"MCU" 				    				; Configure sensor for MCU
                                  M308 S6 Y"drivers" A"DRIVERS" 								; configure sensor 6 as temperature warning and overheat flags on the TMC2660 on Duet
                                  M950 H0 C"bedheat" T0                                       ; create bed heater output on bedheat and map it to sensor 0
                                  M307 H0 B0 S1.00                                            ; disable bang-bang mode for the bed heater and set PWM limit
                                  M143 H0 S120                                                ; set temperature limit for heater 0 to 120C
                                  M140 H0                                                     ; map heated bed to heater 0
                                  M950 H1 C"duex.e2heat" T1                                   ; create nozzle heater output on duex.e3heat and map it to sensor 1
                                  M143 H1 S300                                                ; set temperature limit for heater 1 to 300C
                                  M307 H1 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                                  M950 H2 C"duex.e3heat" T2                                   ; create nozzle heater output on duex.e4heat and map it to sensor 2
                                  M143 H2 S300                                                ; set temperature limit for heater 2 to 300C
                                  M307 H2 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                                  M950 H3 C"duex.e4heat" T3                                   ; create nozzle heater output on duex.e5heat and map it to sensor 3
                                  M143 H3 S300                                                ; set temperature limit for heater 3 to 300C
                                  M307 H3 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                                  M950 H4 C"duex.e5heat" T4                                   ; create nozzle heater output on duex.e6heat and map it to sensor 4
                                  M143 H4 S300                                                ; set temperature limit for heater 4 to 300C
                                  M307 H4 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                                  M950 F0 C"duex.fan4" Q1000 		; create fan 1 on pin duex.fan4 and set its frequency TOOL FAN 0
                                  M106 P0 S0 H-1 					; set fan 1 value. Thermostatic control is turned off TOOL FAN 0
                                  M950 F1 C"duex.fan5" Q1000 		; create fan 2 on pin duex.fan5 and set its frequency TOOL FAN 1
                                  M106 P1 S0 H-1 					; set fan 2 value. Thermostatic control is turned off TOOL FAN 1
                                  M950 F2 C"duex.fan6" Q1000 		; create fan 3 on pin duex.fan6 and set its frequency TOOL FAN 2
                                  M106 P2 S0 H-1 					; set fan 3 value. Thermostatic control is turned off TOOL FAN 2
                                  M950 F3 C"duex.fan8" Q1000 		; create fan 4 on pin duex.fan8 and set its frequency TOOL FAN 3
                                  M106 P3 S0 H-1 					; set fan 4 value. Thermostatic control is turned off TOOL FAN 3
                                  M950 F4 C"fan0" Q1000 			; create fan 5 on pin fan0 and set its frequency HOTEND FAN tool 0
                                  M106 P4 S0 H1 T45 				; set fan 5 value. Thermostatic control is turned on HOTEND FAN tool 0
                                  M950 F5 C"fan1" Q1000 			; create fan 6 on pin fan1 and set its frequency HOTEND FAN tool 1
                                  M106 P5 S0 H2 T45 				; set fan 6 value. Thermostatic control is turned on HOTEND FAN tool 1
                                  M950 F6 C"fan2" Q1000 			; create fan 7 on pin fan2 and set its frequency HOTEND FAN tool 2
                                  M106 P6 S0 H3 T45 				; set fan 7 value. Thermostatic control is turned on HOTEND FAN tool 2
                                  M950 F7 C"duex.fan3" Q1000 		; create fan 3 on pin duex.fan3 and set its frequency HOTEND FAN tool 3
                                  M106 P7 S0 H4 T45 				; set fan 3 value. Thermostatic control is turned on HOTEND FAN tool 3
                                  ;Extra fan ports
                                  ;external stepper - PWMed
                                  M950 F8 C"duex.fan7" Q500 		; fan 8 on pin duex.fan7 EXTRA FAN
                                  M106 P8 S0 H-1 C"extFan" 		; set fan 8 value. Thermostatic control is turned off
                                  ;LED strip
                                  ;M950 F5 C"duex.pwm" 			; create port for LEDs on pin duex.fan8
                                  ;M106 P5 S0 C"LIGHTS" 			; LED control
                                  M563 P0 X0 D0 H1 F0 			; define tool 0
                                  G10 P0 X0 Y0 Z0 U0 V0 W0 		; set tool 0 axis offsets
                                  G10 P0 R0 S0 					; set initial tool 0 active and standby temperatures to 0C
                                  M563 P1 X3 D1 H2 F1 			; define tool 1, ports X axis to U
                                  G10 P1 X0 Y0 Z0 U0.45 V0 W0		; set tool 1 axis offsets
                                  G10 P1 R0 S0 					; set initial tool 1 active and standby temperatures to 0C
                                  M563 P2 X4 D2 H3 F2 			; define tool 3, ports X axis to A
                                  G10 P2 X0 Y161.85 Z0 U0 V0.35 W0 ; set tool 2 axis offsets
                                  G10 P2 R0 S0 					; set initial tool 1 active and standby temperatures to 0C
                                  M563 P3 X5 D3 H4 F3 			; define tool 3, ports X axis to A
                                  G10 P3 X0 Y175.2 Z0 U0 V0 W0.32 	; set tool 3 axis offsets
                                  G10 P3 R0 S0 					; set initial tool 1 active and standby temperatures to 0C
                                  ; DITTO TOOLs
                                  G10 P4 X77 Y0 U-77    									; Set tool offsets and temperatures for tool 2 - moves X 77 left and U 77 right
                                  G10 P4 R0 S0
                                  M567 P4 E1:1 								; Set mix ratio 100% on both front extruders
                                  M563 P5 S"QUAD" D0:1:2:3 H1:2:3:4 X0:3:5:6 F0:1:2:3		; Tool 6 uses extruders 1,2,3and4, hotend heaters 1,2,3and4, maps X to U,A and B, and tool fans 4,5,6 and 7
                                  G10 P5 Y0 X0 U-155 V0 W-155   							; Set tool offsets and temperatures for tool 2 - moves X 77 left and U 77 right
                                  G10 P5 R0 S0
                                  M567 P5 E1:1:1:1										; Set mix ratio 100% on all extruders
                                  M563 P6 S"DD left" D0:2 H1:3 X0:4 F0:2
                                  G10 P6 X0 Y0 U0 V0 W0
                                  G10 P6 R0 S0
                                  M563 P7 S"DD right" D1:3 H2:4 X3:5 F1:3
                                  G10 P7 X0 Y0 U0 V0 W0
                                  G10 P7 R0 S0
                                  ;Firmware retractions
                                  M207 P0 S0.70 F2100 T2500 Z0.4
                                  M207 P1 S0.70 F2100 T2500 Z0.4
                                  M207 P2 S0.70 F2100 T2500 Z0.4
                                  M207 P3 S0.70 F2100 T2500 Z0.4
                                  ;Filament runout sensors
                                  ; Automatic saving after power loss is enabled
                                  M911 S23.00 R23.50 P"M913 X0 Y0 U0 V0 W0 G91 M83 G1 Z2 E-4 F3000" ; Set voltage thresholds and actions to run on power loss
                                  ; MISC
                                  M501
                                  And a simplified homeall/homez
                                  ; homeall.g
                                  ; called to home all axes
                                  ; scripted by Marac
                                  G1 H2 Z2 F360           	; lift Z relative to current position
                                  G1 H1 X-400 Y-450 U400 V-400 W400 F3600	; move quickly to X and Y axis endstops and stop there (first pass)
                                  G1 X5 Y5 U-5 V5 W-5 F3600         	; go back a 5 mm
                                  G1 H1 X-10 Y-10 U10 V-10 W10 F360 			; second pass
                                  M400
                                  M98 Phomez.g			; call homing script for Z axes
                                  G90
                                  ; homez.g
                                  ; called to home the Z axis
                                  G1 Z-405 F900 H1
                                  Can you give those a try? Send M98 P"config.g" first just to check for any syntax errors I may have inadvertently introduced.
                                  Also, just a note for all of your homing files: Only use H2 modifier when you want to move an axis that isn't already homed. Using it otherwise can hide errors because it will allow an axis to move when it isn't homed.
                                  example: G1 U-2 F600 H2 ; go back a few mm
                                  That move is supposed to happen after the axis has been homed, so the H2 shouldn't be needed. If there was a failure to home the H2 would hide that failure and force movement anyway.
                                  Normally it's just used to life the Z axis slightly before move the XY axis for clearance.
                                  MaracMBundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  • MaracMBundefined
                                    MaracMB @Phaedrux
                                    @Phaedrux thank you.
                                    tried proposed config. nothing new. same results.
                                    it homes all the first time.
                                    but then when i call to homeall again, it fails to home. It either does not move left or right Z motor, or it fails to trigger the endstop.
                                    • MaracMBundefined
                                      MaracMB @MaracMB
                                      correction, as i can't see both endstop states i sent home all from phone and monitored Endstops triggered from Settings>machine specific on the screen.
                                      Ran homeall until it fails to home correctly.
                                      It shows endstop as triggered but motor (in this case left Z) keeps grinding and does not stop. It also does this in it's own random pattern on the right side.
                                      Endstops are OMRON optical endstops, fed by 5V from the CONN_SD.
                                      I set the endstops voltage jumper select on the Duex5 to 5V. The endstops on duex are now wired and fed from their designated pins. Same results no matter how i connect them. No matter what the endstop voltage jumper position is.
                                      • MaracMBundefined
                                        MaracMB @MaracMB
                                        after failed homing:
                                        as said, on failed Z homing, while motors grinding and the endstop for Z showed as triggered. I hit emergency stop, board restarts. Endstop for Z shows as not triggered
                                          jay_s_uk
                                          Any i2c errors being reported in M122 when it fails to home?
                                          • MaracMBundefined
                                            MaracMB @jay_s_uk
                                            @jay_s_uk when i hit homeall, and again until it fails (it's like a 3rd or fourth attempt) it grinds until i hit emergency stop.
                                            Running m122 right after restart gives:
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                                            Board ID: 08DGM-9T6BU-FG3SN-6J9F6-3SN6L-KUWVG
                                            Used output buffers: 3 of 24 (18 max)
                                            Static ram: 27980
                                            Dynamic ram: 97812 of which 44 recycled
                                            Exception stack ram used: 264
                                            Never used ram: 4972
                                            Tasks: NETWORK(ready,348) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
                                            Owned mutexes: WiFi(NETWORK)
                                            Last reset 00:00:14 ago, cause: software
                                            Last software reset at 2020-11-09 12:27, reason: User, spinning module GCodes, available RAM 4700 bytes (slot 0)
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                            Error status: 0
                                            MCU temperature: min 35.3, current 35.8, max 36.2
                                            Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 5: standstill, SG min/max not available
                                            Driver 6: standstill, SG min/max not available
                                            Driver 7: standstill, SG min/max not available
                                            Date/time: 2020-11-09 12:28:02
                                            Cache data hit count 23635152
                                            Slowest loop: 6.31ms; fastest: 0.13ms
                                            === Storage ===
                                            Free file entries: 10
                                            SD card longest read time 1.1ms, write time 0.0ms, max retries 0
                                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 15.71ms; fastest: 0.00ms
                                            HTTP sessions: 1 of 8
                                            - WiFi -
                                            Network state is active
                                            WiFi firmware version 1.23
                                            WiFi MAC address 84:f3:eb:83:45:0d
                                            WiFi Vcc 3.43, reset reason Unknown
                                            WiFi flash size 4194304, free heap 23352
                                            WiFi IP address 192.168.0.125
                                            WiFi signal strength -48dBm, reconnections 0, sleep mode modem
                                            === DueX ===
                                            Read count 1, 4.07 reads/min
                                            so, i'd say no.
