Slow upload rates and connection errors
Hello!
After being totally frustrated I´m trying to find some help in here.
I have 3-4 printers with duet 2 or duet 3. All of them are working fine. Today I finished my newest build and updated everything on the duet. After getting a blank screen, I tried different DWC versions and when updating again I got it running.
The whole file upload is very slow, often I´m getting connection errors and when starting heater auto tuning for example I´m just getting this error:
Connection interrupted, attempting to reconnect...
HTTP request timed outI tried nearly everything, restartet router, restartet board, scanned the wifis and changed to channel 1 with my router - nothing helped.
Now I´m getting the blank screen again... connection via pronterface works fine...
I hope you can help me.
William
M122 says
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta3 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SD-6J1FA-3S86P-9BMMF
Used output buffers: 1 of 24 (12 max)
Static ram: 23996
Dynamic ram: 100424 of which 56 recycled
Never used RAM 5572, free system stack 174 words
Tasks: NETWORK(ready,210) HEAT(blocked,306) MAIN(running,415) IDLE(ready,19)
Owned mutexes: USB(MAIN)
Last reset 00:04:21 ago, cause: power up
Last software reset at 2020-11-11 19:05, reason: User, GCodes spinning, available RAM 6356, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0x00
Error status: 0x00MCU temperature: min 33.2, current 33.6, max 33.9
Supply voltage: min 22.9, current 22.9, max 23.0, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2020-11-11 20:03:12
Cache data hit count 423162907
Slowest loop: 3.53ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.2ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 4.01ms; fastest: 0.01ms
HTTP sessions: 0 of 8- WiFi -
Network state is active
WiFi firmware version 1.24
WiFi MAC address cc:50:e3:6a:87:e4
WiFi Vcc 3.31, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25248
WiFi IP address 192.168.0.173
WiFi signal strength -58dBm, reconnections 1, sleep mode modem
Clock register 00002002
- WiFi -
@WillGIam said in Slow upload rates and connection errors:
Do you get the same problems when running 3.1.1?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
The wifi server version in 3.2beta2 is updated (1.24) and you don't mention any firmware versions.
If you upload that complete zip file to the system tab in DWC it should flash everything back for testing.
Hey Phaedrux,
Thanks for your reply.Server FW is 1.24, as you see in my comment. Also you can see, that I was using 3.2-beta3.
Because I´m not able to upload anything on DWC, I have to change the files on SD.
I changed the Duet2CombinedFirmware to the 3.1.1 and the DWC too. -- still blank.
After a while I´m getting the DWC (instead of blank screen) and can do something, but not uploading.
After putting 3.1.1 and DWC on SD I got no system drop down settings, but it seems as I´m now able to upload a firmware file without breakdown. - Lets see what happens.
Can you place this wifi server bin file on the SD card in the /sys folder and then send M997 S1 to flash the module back to 1.23?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetWiFiServer.bin
Hey Phaedrux,
Thanks for your reply.== Diagnostics ===
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Used output buffers: 1 of 24 (11 max)
Static ram: 27980
Dynamic ram: 93836 of which 84 recycled
Exception stack ram used: 312
Never used ram: 8860
Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:15 ago, cause: software
Last software reset details not available
Error status: 0
Error status: 0MCU temperature: min 32.2, current 32.8, max 33.1
Date/time: 2020-11-11 20:53:38
Cache data hit count 170296728
Slowest loop: 7.05ms; fastest: 0.14ms
=== Storage ===
SD card longest read time 2.8ms, write time 0.0ms, max retries 0
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 1167.20ms; fastest: 0.00ms
Responder states: HTTP(1) HTTP(1) HTTP(1) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
WiFi firmware version 1.23
WiFi Vcc 3.32, reset reason Unknown
WiFi flash size 4194304, free heap 24280
WiFi signal strength -55dBm, reconnections 0, sleep mode modem
Socket states: 2 2 2 0 0 0 0 0
I flashed everything back to 3.1.1 and Server to 1.23, but still the same problems.
Could a board erase help?
- WiFi -
Thats what it looks like most of the time. After a while DWC appears, but very slow with connection breaks.
Doubtful, since we've already flashed the firmware again.
When you send M997 S1 does the flash process appear to proceed correctly with a percentage complete list?
When you lose connection, does the light on the module go out?
Can you create these macros and use them to clear the saved networks and reset the module with your SSID?
; Clear all wifi networks ; M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10 M552 S0 ; Disable network module G4 S5 ; wait 5 seconds M588 S"*" ; Clear all saved wifi networls M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
; Add default wifi network ; M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10 M552 S0 ; Disable network module G4 S5 ; wait 5 seconds M587 S"NETWORKNAME" P"PASSWORD" ; Add duet wifi SSID to remembered networks list G4 S5 ; wait 5 seconds M552 S1 ; reenable wifi module M291 R"duetwifi SSID added." P"Check console to verify IP address."
IT's easier to use the macros because you can execute them from command line more easily than retyping everything. Just send M98 P"macroname" to run them.
Is this a brand new duet wifi? When and where was it purchased?
@Phaedrux said in Slow upload rates and connection errors:
Well...
Yes.
No. its still on.
will do that now.
thanks a lot.
@WillGIam, are you certain that there isn't another device using that IP address? Try pinging it. Then turn the Duet off and try pinging it again.
Tried to clear all networks and added it again - same problem.
I dont really know when and where this duet was bought...@dc42 said in Slow upload rates and connection errors:
Yes. When duet is turned off, there is a timeout.
Does the Duet show up in the router interface?
That would make it difficult to ascertain it's warranty status. If it's within 6 months from an authorized reseller you would be covered.
@Phaedrux Yes, it shew up in the router interface.
Yes, I´m not covered I think. I dont think its a hardware issue - I tried nearly everything now.
Only other thing I can think of is to try a new SD card in case it's having problems reading the file system.
