Problem with G31 Trigger Z-height
502
  • undefined
    gringo
    after I rebuilt my IDEX printer, I wanted to do the software configuration today.
    As described in the documentation, I moved the nozzle onto the print bed and set G92 Z0. After measuring the Z offset (0.8404mm) several times, I entered it in the G31 Command of config.g.
    When I start a print with Tool 0, the nozzle is far too high above the print bed.
    I do not understand that.
    Anybody of yours offering an idea?
    Thanks
    gringo
    undefined 1 Reply Last reply 14 Nov 2020, 11:43 Reply Quote 1
    • undefined
      Veti
      always post your config.g
      • undefined
        Can you post your config.g?
        Can you post your homeall.g?
        Can you send M122 and post the results?
        Can you send M98 P"config.g" and post the results?
        undefined 1 Reply Last reply 14 Nov 2020, 16:05 Reply Quote 0
        • undefined
          fcwilt
          After updating config.g did you reboot the printer or run config.g via M98?
          • undefined
            gringo
            Config.g :
            M550 P"Der Duale" ; set printer name
            ;-------------------------------- Network ----------------------------------------------------------
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            ;--------------------------------- Display PanelDue 7i ----------------------------------------------
            M575 P1 S1 B57600
            ;----------------------------------------- Drives ----------------------------------------------------
            M569 P0 S1 ; physical drive 0 goes backwards x
            M569 P1 S0 ; physical drive 1 goes backwards y
            M569 P3 S1 ; physical drive 3 goes forwards u
            M569 P2 S1 ; physical drive 2 goes forwards z links
            M569 P9 S0 ; physical drive 9 goes forwards z hinten rechts
            M569 P4 S1 ; physical drive 4 goes forwards z rechts
            M569 P5 S1 ; physical drive 5 goes backwards extruder links
            M569 P6 S1 ; physical drive 6 goes forwards extruder rechts
            M584 X0 Y1 Z2:9:4 U3 E5:6 ; set drive mapping
            M671 X-132:148:428 Y-25:385:-55 S5 ; Positionen der Trapezgewindespindel für das Bed Leveling
            M350 X16 U16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
            M92 X80.00 U80.0 Y80.00 Z2133.33 E415.00:415.00 ; set steps per mm
            M566 X900.00 U900.00 Y900.00 Z12.00 E600.00:600.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 U12000.00 Y12000.00 Z600.00 E36000.00:36000.00 ; set maximum speeds (mm/min)
            M201 X1000.00 U1000.00 Y1000.00 Z250.00 E800.00:800.00 ; set accelerations (mm/s^2)
            M906 X1000 U1000 Y1000 Z1000 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S120 ; Set idle timeout
            ;------------------------------------------------- Axis Limits -------------------------------------------------
            ;M208 X-88 U0 Y-40 Z0 S1 ; set axis minima
            ;M208 X278 U368 Y295 Z280 S0 ; set axis maxima
            M208 X-88: 290 U0: 380 Y-25: 325 Z0: 270
            ;------------------------------------------------- Endstops -------------------------------------------------------
            M574 U2 S1 P"e0stop" ; configure active-high endstop for low end on U via pin e0stop
            M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
            ;M574 Z2:4 S1 P"zstop + e1stop" ; configure active-high endstop for low end on 2 Z Motoren via pin zstop + e1stop
            M574 Z0 S2 ; Z-Home mit Sonde
            ;-------------------------------------------------- Z-Probe --------------------------------------------------------------
            M558 P5 C"zprobe.in" H5 F150 T10000 ; disable Z probe but set dive height, probe speed and travel speed
            G31 P500 X0 Y25 Z0.8404
            M557 X0:280 Y20:290 S20 ; define mesh grid
            ;-------------------------------------------------- Heaters -----------------------------------------------------------------
            ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
            M307 H0 A214.2 C887.4 D1.5 S1.00 V24.0 B0 ; PID Tuning
            M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"duex.e2heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
            ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M307 H1 A606.0 C166.7 D3.6 S1.00 V24.1 B0 ; PID Tuning
            M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
            M950 H2 C"duex.e3heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
            ;M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M307 H2 A581.7 C168.9 D3.2 S1.00 V24.1 B0 ; PID Tuning
            ;---------------------------------------------------- Fans -------------------------------------------------------------------
            M950 F0 C"duex.fan4" Q500 ; create fan 0 on pin duex.fan3 and set its frequency
            M950 F1 C"duex.fan3" Q500 ; create fan 1 on pin duex.fan4 and set its frequency
            M950 F2 C"duex.fan5" Q500 ; create fan 2 on pin duex.fan5 and set its frequency
            M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
            M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
            M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on
            ;----------------------------------------------------- Tools ---------------------------------------------------------------
            M563 P0 S"Tool 1 links" D0 H1 F0 ; define tool 0
            M563 P1 S"Tool 2 rechts" D1 H2 X3 F2 ; define tool 1
            G10 P1 U0 Y0 Z0 ; set tool 1 axis offsets
            G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
            • undefined
              Veti @gringo
              @gringo said in Problem with G31 Trigger Z-height:
              what do you mean far to high?
              normally after measuring the offset i adjust the first layer by babystepping and then add the babystepping to the offset to get the final result.
              B4138 is the default and wrong for your thermistors. find the correct beta value in your thermistor documentation.
              • undefined
                gringo
                When i Start a Printjob the Nozzle is 0,84mm above the Bed.
                That is excactly the G31 Z Trigger Distance.
                For testing i changed the G31 Z in Z-0,8404 and started a Printjob. The Nozzle was 1,6mm above the Bed.
                But why?
                undefined 1 Reply Last reply 14 Nov 2020, 12:11 Reply Quote 0
                • undefined
                  Veti @gringo
                  Z-0,8404
                  because this defines the trigger height below the nozzle. so if you want the bed to be closer you have to add, not subtract.
                  • undefined
                    gringo
                    Yes, this was a Test. To see what happened.
                    But why do I have to enter the double distance in the G31 Command?
                    Thanks for the Thermistor tip. I have installed Semitec 104GT2.
                    undefined 1 Reply Last reply 14 Nov 2020, 12:36 Reply Quote 0
                    • undefined
                      Veti @gringo
                      thats B4725 C7.06e-8
                      that not required.
                      maybe your bed is warping while beeing heated.
                      • undefined
                        gringo
                        I determined the Z-trigger at the same temperature bed 80 ° C and not cold
                        • undefined
                          Phaedrux Moderator @Phaedrux
                          We can only guess since you haven't shown us the rest of your gcode.
                          @Phaedrux said in Problem with G31 Trigger Z-height:
                          Additionally show us your slicer start gcode and bed.g if you use G32 anywhere.
                          • undefined
                            gringo
                            Now it works, i have performed the steps again.
                            Thanks for your help
