    Please help the Duet fans in Japan.
    24
    797
    • kotuoundefined
      kotuo
      Nice to meet you, I'm a student who loves anime and 3D printing.
      Sorry for the long post.
      I posted this question here because I wanted to put it where you can see it.
      I'm really sorry if I've violated the etiquette.
      This is my first time in the International Forum, so I don't really know the etiquette.
      Please let me know if I have made a mistake.
      I think this issue is going to be very difficult.
      My question is: Is it possible to replace the wifi module of Duet2WIFI with another wifi module?
      I think most people will probably answer that you should use Ethernet.
      However, Ethernet is not available in Japan.
      The only Duet2 sold in Japan is the Duet 2Wif (clone).
      However, the Duet 2Wif's WIFI module is not allowed under Japanese law, so it cannot be used in Japan.
      But there are some WIFI modules that are allowed to be used in Japan.
      So I figured that if I replace the ESP-12s used for Duet 2 Wifi with another WIFI module, I can use it.
      Is it possible to replace the WIFI module?
      This is a famous WIFI module I researched that is available in Japan.
      ESP8266
      KP-ESPWROOM02
      ESPー12f
      Finally, the modules on this Japanese site are available
      https://eleshop.jp/shop/r/r2540_sgp/
      Thank you for reading to the end.
      I'd really like to use Duet.
      Because I think Duet is the best controller board out there.
      Please help Duet fans in Japan.
      A Former User? A Former User? deckingmanundefined 3 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User @kotuo
        @kotuo said in Please help the Duet fans in Japan.:
        yes, just run M997 S1 after the new module is soldered in place and the duet will write the firmware to the new wifi module
        • kotuoundefined
          kotuo
          Thanks for the reply.
          If I run M997 S1, will the firmware be written automatically?
          • A Former User?
            A Former User
            (if not clear you need to use a wifi module with the same physical pinout or make an adapter, but pretty much all esp8266 modules will work with the firmware)
            • A Former User?
              yes, provided the wifiserver.bin file is on the sd card in the /sys folder. which it normally is when installing/updating the firmware from the .zip file from a major release.
              • kotuoundefined
                kotuo
                I will create an adapter and transfer it to ESPesp8266.
                • Vetiundefined
                  Veti
                  does aliexpress ship to japan?
                  https://www.aliexpress.com/item/32917967705.html
                  you can convert you duet wifi to a duet ethernet that way
                  • kotuoundefined
                    kotuo
                    I've never used it, but I think it can be used.
                    But I would like to use it for one of the experimental machines in Iot development.
                    I think an Ethernet connection is the last resort.
                    But I didn't know there was a module for Ethernet connectivity.
                    Thank you very much.
                    • A Former User?
                      @kotuo
                      Only an indirect info for you maybe of interest for all options:
                      You could also take one of the duet3-family boards to connect a raspi/raspberry-pi to it directly so that you have all options...
                      https://duet3d.dozuki.com/c/Duet_3_Hardware
                      The new duet3mini should be released Q1/2021 as far as I undertstood here https://forum.duet3d.com/topic/17409/duet-3-mini-5-initial-announcement/70?_=1605710723339
                      Sorry to only be able to help indirectly, but maybe of some use for you
                      kotuoundefined 1 Reply Last reply Reply Quote 1
                      • kotuoundefined
                        kotuo @A Former User
                        @LB Thanks for the reply.
                        I did not know that there is an option to use Duet3.
                        I consider it one of the solutions.
                        • A Former User?
                          A Former User
                          As of firmware 3.2 you can also use Raspberry Pi with existing Duet 2 Wifi, replacing the Wifi with SPI connection to Raspberry Pi, but it it only available as beta version still.
                          https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc/ (warning, long thread)
                          • kotuoundefined
                            @bearer Thanks for the reply.
                            I'll take the time to read it
                              Welcome to the forum!
                              You can replace the ESP-12S by ESP-12F. The ESP-12F has some extra pins at the back of the module but they do not need to be connected to anything.
                              The WiFi version of the forthcoming Duet 3 Mini uses the WROOM-02U module. I have not found a TELEC certification document for this module, but the version with internal antenna (WROOM-02D) is TELEC-certified.
                              HTH David
                              • kotuoundefined
                                kotuo @dc42
                                @dc42 Thank you for your reply.
                                This is my first post, so I didn't expect to get many replies and responses from the admins.
                                I'm glad to get so many responses.
                                Are there any past threads on how to switch the wifi module on the ESP-12f?
                                I would like to know if there are any.
                                But I'm confused.
                                1, reload the wifi module
                                2, Duet 2 Ethernet SBC
                                3, wait and buy a duet 3 mini
                                Three fascinating answers are running through my head.
                                Oh my God!(^ω^)
                                  By the way, you're not the first to request this.
                                  https://forum.duet3d.com/topic/12029/replace-the-wifi-or-ethernet-module-by-the-esp-13?_=1605735139506
                                  kotuoundefined 1 Reply Last reply Reply Quote 0
                                  • kotuoundefined
                                    kotuo @Phaedrux
                                    @Phaedrux Thank you for your reply
                                    • oliofundefined
                                      oliof
                                      Another option if you don't want to void the warranty by replacing components or cannot solder well enough for a replacement: use a small wifi router like the GL.inet AR150. I did this successfully with the old duet 0.6 board and the duet 3 mini beta board which came with ethernet (my workbench still does not have ethernet). These routers can be configured as bridges where the router only connects to the wifi to pass through the connected devices.
                                      • deckingmanundefined
                                        deckingman @kotuo
                                        Just out of curiosity, can't you buy an Ethernet Duet directly from the UK?
                                        As an aside, we've signed a significant trade deal between the two countries. If I were part of the Duet team, I'd be looking seriously at this opportunity.
                                        • kotuoundefined
                                          kotuo @oliof
                                          @oliof Sorry for the delay in replying.
                                          Thank you for telling me the safest and easiest way.
                                          I'm also new to Duet, so I thought this was the best way.
                                          • oliofundefined
                                            oliof
                                            @kuoto your way certainly is an option for those with the tools and ability!
