    Please help the Duet fans in Japan.
    24
    798
      A Former User @kotuo
      @kotuo
      Only an indirect info for you maybe of interest for all options:
      You could also take one of the duet3-family boards to connect a raspi/raspberry-pi to it directly so that you have all options...
      https://duet3d.dozuki.com/c/Duet_3_Hardware
      The new duet3mini should be released Q1/2021 as far as I undertstood here https://forum.duet3d.com/topic/17409/duet-3-mini-5-initial-announcement/70?_=1605710723339
      Sorry to only be able to help indirectly, but maybe of some use for you
      kotuoundefined 1 Reply Last reply Reply Quote 1
      • kotuoundefined
        kotuo @A Former User
        @LB Thanks for the reply.
        I did not know that there is an option to use Duet3.
        I consider it one of the solutions.
          A Former User
          As of firmware 3.2 you can also use Raspberry Pi with existing Duet 2 Wifi, replacing the Wifi with SPI connection to Raspberry Pi, but it it only available as beta version still.
          https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc/ (warning, long thread)
          • kotuoundefined
            @bearer Thanks for the reply.
            I'll take the time to read it
              Welcome to the forum!
              You can replace the ESP-12S by ESP-12F. The ESP-12F has some extra pins at the back of the module but they do not need to be connected to anything.
              The WiFi version of the forthcoming Duet 3 Mini uses the WROOM-02U module. I have not found a TELEC certification document for this module, but the version with internal antenna (WROOM-02D) is TELEC-certified.
              HTH David
              • kotuoundefined
                kotuo @dc42
                @dc42 Thank you for your reply.
                This is my first post, so I didn't expect to get many replies and responses from the admins.
                I'm glad to get so many responses.
                Are there any past threads on how to switch the wifi module on the ESP-12f?
                I would like to know if there are any.
                But I'm confused.
                1, reload the wifi module
                2, Duet 2 Ethernet SBC
                3, wait and buy a duet 3 mini
                Three fascinating answers are running through my head.
                Oh my God!(^ω^)
                  By the way, you're not the first to request this.
                  https://forum.duet3d.com/topic/12029/replace-the-wifi-or-ethernet-module-by-the-esp-13?_=1605735139506
                  kotuoundefined 1 Reply Last reply Reply Quote 0
                  • kotuoundefined
                    kotuo @Phaedrux
                    @Phaedrux Thank you for your reply
                    • oliofundefined
                      oliof
                      Another option if you don't want to void the warranty by replacing components or cannot solder well enough for a replacement: use a small wifi router like the GL.inet AR150. I did this successfully with the old duet 0.6 board and the duet 3 mini beta board which came with ethernet (my workbench still does not have ethernet). These routers can be configured as bridges where the router only connects to the wifi to pass through the connected devices.
                        deckingman @kotuo
                        @kotuo said in Please help the Duet fans in Japan.:
                        However, Ethernet is not available in Japan.
                        The only Duet2 sold in Japan is the Duet 2Wif (clone).
                        Just out of curiosity, can't you buy an Ethernet Duet directly from the UK?
                        As an aside, we've signed a significant trade deal between the two countries. If I were part of the Duet team, I'd be looking seriously at this opportunity.
                        • kotuoundefined
                          kotuo @oliof
                          @oliof Sorry for the delay in replying.
                          Thank you for telling me the safest and easiest way.
                          I'm also new to Duet, so I thought this was the best way.
                          • oliofundefined
                            oliof
                            @kuoto your way certainly is an option for those with the tools and ability!
                            • kotuoundefined
                              kotuo @deckingman
                              @deckingman Sorry for the delay in replying.
                              I'm also new to Duet, so I'd like to have a real one, if possible.
                              But I think the only problem is the cost of importing it and how many days it will take for delivery.
                              • Vetiundefined
                                Veti @kotuo
                                are there easy placed to import from?
                                what about shanghai?
                                https://www.robotdigg.com/product/1221/DuetWifi-or-DuetEthernet-from-Duet3D
                                oh they dont have them in stock
                                • kotuoundefined
                                  kotuo @Veti
                                  @Veti I don't know which ones are easy to import, since this is my first time importing, but I think the closest countries are China and Korea
                                  But there is no doubt that pounds are cheaper than dollars, including importation costs.
                                  • kotuoundefined
                                    kotuo
                                    People who have seen this thread
                                    Thank you for posting your solution in this thread.
                                    I've bought an Ethernet at E3d today.
                                    It's my first Duet and I was scared of the future of modifying and breaking it, so I chose the easiest and safest way to connect the Ethernet to my wifi router.
