    Falso on Fan Output
    fan broken
    416
    • MauriceMundefined
      MauriceM
      Hey, i think i damage my fan output on my duet, it worked fine, but i think i wired a new fan wrong polarity, and now i dont get 24V on the fans, even on the allwys on fans is nothing, i checked the Fuse and it is not popped.
      Can it be that i damaged something else?
        Check your fan mosfets for damage.
        https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
        see here for an example iamge.
        • MauriceMundefined
          MauriceM
          i think they look fine, also the Allways in fans dont get any voltage...
          so it cant be a mosfet
          • MauriceMundefined
            MauriceM
            also this is a V1.03 i dont and it has only one fuse on it, i dont even know if this is a fan fuse or something else, i think i broke my board,
            Than is the question, im running a 24v printer with a duex with 12V for fans. how does the duet control the fans, via the ground pin? than i could go on 24V on my psu with the fans and control them over the expansion fan ports on the duex
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • MauriceMundefined
              MauriceM
              So i heard that it it possible to put the VIN from the fan on the psu and the GND on the Duex, i did that and it worked, but the fan dont want to shut of entirely, but it was controllable, what seems a little strange to me, also the fan spins a little on every fan ouput even if i dont asseign them in the config.
              my solution is to put the part cooling fan on the heater 1 Output and the Cold end fan on the PSU. Can i put a fan on the heater ouput or do i damage the board with that?
              • A Former User?
                A Former User @MauriceM
                @MauriceM said in Falso on Fan Output:
                brushless fan is ok
                • MauriceMundefined
                  MauriceM
                  i Found a other solution, it seems like the Fan putputs on my duet arent getting 24v , so i put out the jumper and feat them 24V on the middle Pin directly, now the fans ware working again properly
                  • Vetiundefined
                    Veti @MauriceM
                    see
                    https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_PCB_revision_v1_Num_03
                    The Fan MOSFETS now have a miniblade fuse in the VIN supply (not 5V supply).
                    so if your vin is 0 then the fuse is blown.
                    • MauriceMundefined
                      MauriceM
                      yeah i thought so, but i when i measure the fuse everything seams to be ok...
                      • MauriceMundefined
                        MauriceM
                        i pulled out the the fuse and put it back again and now it is working? 😄 WTF so much frustration without any reason 😄
