    First Layer and Extrusion Problems
    5.6k
    • Frederikundefined
      Frederik
      pla_unload.g pla_load.g pla_config.g Hello togehter,
      i finished my first corexy build yesterday and wanted to tune the z offset for a good first layer with your tutorial for BLtouch and independent Z leveling.
      But now i have the Problem that my z offset is way to high and i dont know where to put the new values in.
      in my config is the following line for my BLtouch:
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch
      G31 P500 X-26 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X50:400 Y50:400 S50 ; define Mesh Grid
      After Leveling the bed with a piece of paper and setting Z=0 with G92 Z0
      then a single measurement with G30 S-1 where i get the value of x.xxx
      when i am changing the Z value, i dont get it right. or is there something i am missing ?
      The indipendent Z Leveling seems to work just Fine.
      But my High Map is a Desaster 🙂 i tried Tue BEd Level First and then a Mesh Compensation.
      The other Problem is that my Extruder seems to skip steps and is constantly feeding to less material. The E STeps are 830 for a Original Direct Drive BMG with a E3d Volcano with 0.4 Nozzle. When i am manual Extrudiong at 225° i cant go with the speed over 5 -15 mm bevor it starts making strange clicking noises.
      Where can i set the Retractions Paramters etc. ?
      I tried using the Filaments Macros with the load, unload and config files , but i dont know if it is correct .
      Reprap 3.1.1
      Duet 3 + RPI 3b+
      0.9° Pancake Stepper on the BMG
      1.8° Z Stepper
      Tried printing PLA with 215 ° Nozzle and Bed 60°
      config (1).g
      homez.g
      bed.g
      pla_config.g
      pla_load.g
      pla_unload.g
      Kindly Regards
      Frederik
      • Frederikundefined
        Frederik
        I dont know where i can change the offset ?
        Do i have to add a command after the BLTouch Lines or change the trigger height ?
        The dozuki only says to change the G31 , but how ?!?
        • piperswundefined
          pipersw
          in config.g :
          G31 P500 X-26 Y2 Z2.5 <= modify the Z, increase value for reduce height of nozzle
          • Frederikundefined
            Frederik
            ok thanks , one moment i will try it
            • Frederikundefined
              Frederik
              Is the Right way to do a bed leveling:
              first G32
              then G 28
              and then adjusting for the right layer height ?
              This is my First Printer build 🙂
              • Vetiundefined
                Veti
                G29 S1 ; Load previously set bed map
                this should not be in the config.g
                the mesh should be loaded after you have established z=0
                so a good place is the start of your slicer g code
                for the offset see
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                • Frederikundefined
                  Frederik
                  when i run first a true bed level and then a bed mesh compensation i get the following heightmap:
                  RepRapFirmware height map file v2 generated at 2020-11-20 14:53
                  xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                  0.00,340.00,0.00,370.00,-1.00,20.00,20.00,18,19
                  2.000, 1.878, 1.875, 1.890, 1.685, 1.642, 1.517, 1.442, 1.358, 1.253, 1.180, 1.145, 1.135, 1.138, 1.160, 1.177, 1.250, 1.333
                  1.715, 1.562, 1.735, 1.757, 1.603, 1.550, 1.423, 1.320, 1.240, 1.132, 1.075, 1.030, 1.020, 1.020, 1.048, 1.062, 1.105, 1.183
                  1.683, 1.645, 1.835, 1.725, 1.558, 1.397, 1.267, 1.160, 1.070, 1.010, 0.943, 0.925, 0.910, 0.922, 0.975, 1.005, 1.022, 1.100
                  1.635, 1.677, 1.760, 1.573, 1.440, 1.302, 1.163, 1.052, 0.970, 0.905, 0.847, 0.815, 0.802, 0.815, 0.855, 0.892, 0.930, 1.010
                  1.603, 1.555, 1.608, 1.442, 1.285, 1.150, 1.060, 0.953, 0.833, 0.755, 0.712, 0.690, 0.685, 0.695, 0.730, 0.770, 0.818, 0.927
                  1.483, 1.513, 1.510, 1.255, 1.155, 1.025, 0.943, 0.828, 0.795, 0.685, 0.597, 0.578, 0.573, 0.578, 0.613, 0.653, 0.722, 0.812
                  1.440, 1.442, 1.358, 1.160, 0.998, 0.858, 0.715, 0.642, 0.648, 0.542, 0.507, 0.507, 0.510, 0.533, 0.557, 0.610, 0.675, 0.775
                  1.478, 1.415, 1.267, 1.017, 0.917, 0.797, 0.743, 0.680, 0.615, 0.605, 0.432, 0.413, 0.420, 0.440, 0.455, 0.505, 0.573, 0.677
                  1.355, 1.205, 1.100, 0.875, 0.770, 0.672, 0.648, 0.590, 0.523, 0.417, 0.307, 0.300, 0.312, 0.333, 0.352, 0.392, 0.455, 0.555
                  1.212, 1.145, 0.953, 0.783, 0.632, 0.550, 0.560, 0.490, 0.360, 0.280, 0.203, 0.208, 0.225, 0.233, 0.238, 0.292, 0.352, 0.453
                  1.112, 1.010, 0.820, 0.632, 0.493, 0.390, 0.395, 0.347, 0.243, 0.158, 0.092, 0.100, 0.127, 0.120, 0.127, 0.163, 0.215, 0.333
                  1.005, 0.875, 0.705, 0.480, 0.358, 0.243, 0.212, 0.165, 0.115, 0.045, -0.010, 0.005, 0.010, 0.007, 0.012, 0.047, 0.097, 0.212
                  0.913, 0.750, 0.557, 0.318, 0.233, 0.108, 0.057, -0.002, -0.062, -0.110, -0.153, -0.148, -0.132, -0.137, -0.108, -0.068, 0.005, 0.095
                  0.797, 0.625, 0.425, 0.248, 0.127, -0.012, -0.097, -0.160, -0.220, -0.270, -0.283, -0.288, -0.270, -0.265, -0.227, -0.158, -0.105, -0.023
                  0.698, 0.483, 0.167, 0.115, -0.005, -0.145, -0.248, -0.302, -0.368, -0.440, -0.453, -0.475, -0.470, -0.430, -0.387, -0.315, -0.265, -0.182
                  0.500, 0.312, 0.070, -0.078, -0.193, -0.310, -0.408, -0.467, -0.552, -0.592, -0.575, -0.573, -0.578, -0.547, -0.495, -0.427, -0.350, -0.267
                  0.358, 0.160, -0.092, -0.172, -0.295, -0.415, -0.500, -0.573, -0.642, -0.665, -0.627, -0.595, -0.637, -0.640, -0.583, -0.515, -0.438, -0.347
                  0.265, 0.068, -0.240, -0.307, -0.420, -0.557, -0.640, -0.690, -0.735, -0.715, -0.660, -0.653, -0.730, -0.743, -0.698, -0.627, -0.542, -0.432
                  0.105, -0.070, -0.250, -0.320, -0.557, -0.677, -0.762, -0.797, -0.802, -0.773, -0.743, -0.795, -0.852, -0.833, -0.752, -0.670, -0.625, -0.517
                  • Frederikundefined
                    Frederik
                    That is the orresponding height map picture from my DWC
                    • Vetiundefined
                      Veti
                      post the output of 3 consecutive G32.
                      most likely your motor order is wrong
                      • Frederikundefined
                        Frederik
                        1.G32
                        Leadjustments made: -2.618 -0.246 -0.521, points used 3, (mean, deviation) before (-0.997, 0.862) after (0.000, 0.000)
                        2.G32
                        Leadscrew adjustments made: -0.054 1.112 0.200, points used 3, (mean, deviation) before (0.399, 0.459) after (-0.000, 0.000)
                        3.G32
                        Leadscrew adjustments made: 0.044 0.756 -0.011, points used 3, (mean, deviation) before (0.228, 0.321) after (0.000, 0.000)
                        Vetiundefined 1 Reply Last reply Reply Quote 0
                        • Frederikundefined
                          Frederik
                          i´ve checked the cabling.
                          left front spindle is connected to driver 2
                          back center spindle to driver 3
                          right front spindle to driver 4
                          • fcwiltundefined
                            fcwilt @Frederik
                            Do you lead screws really have pitch of 1.25?
                            Regards bed.g:
                            I'm not sure what having two P parameters is going to do to your bed leveling.
                            Why did you add the second P1.25?
                            • Vetiundefined
                              Veti @fcwilt
                              @fcwilt said in First Layer and Extrusion Problems:
                              he has z400. where did you see 1.25 leadscrew?
                              M92 X160.00 Y160.00 Z400.00 E830.00 ; set steps per mm
                              • Vetiundefined
                                Veti @Frederik
                                @Frederik said in First Layer and Extrusion Problems:
                                1.G32
                                2.G32
                                3.G32
                                that seems to be converging. can you run a g29 now and post the picture
                                • fcwiltundefined
                                  fcwilt @Veti
                                  @Veti said in First Layer and Extrusion Problems:
                                  See his bed.g file.
                                  He has two P parameters for each G30. Not sure if that is messing things up or not.
                                  • Vetiundefined
                                    Veti @fcwilt
                                    @fcwilt
                                    good catch.
                                    yes the second P1.25 parameter should be removed. this is not a valid parameter for G30
                                    your pitch is 8mm btw.
                                    • fcwiltundefined
                                      fcwilt @Veti
                                      How can we be sure the pitch is 8mm? The config values might be wrong. Maybe the comment in bed.g is correct?
                                      Clarification is needed from the OP.
                                      Vetiundefined Frederikundefined 2 Replies Last reply Reply Quote 0
                                      • Frederikundefined
                                        Frederik
                                        ok ,i have changed it.
                                        is it possible to create a homez.g file where it automatically probes the bed on three points and enable compensation ?
                                        perhaps like :
                                        ; homez.g
                                        ; called to home the Z axis
                                        ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
                                        G91 ; relative positioning
                                        G90 ; absolute positioning
                                        G1 X240 Y220 F6000 ; go to first probe point
                                        G32 ; home Z by True bed leveling 3 points in bed.g
                                        or do i have to include the three positions like
                                        G30 P0 X330 Y240 Z-9999 ; Front Left
                                        G30 P1 X150 Y0 Z-9999 ; Middle Back
                                        G30 P2 X0 Y248 Z-9999 S3 ; Front Right and compensate 3mm
                                        Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                        • Vetiundefined
                                          Veti @Frederik
                                          @Frederik
                                          create a macro that calls G28 and G32
                                          • Vetiundefined
                                            Veti @fcwilt
                                            i cant, but there is a very high chance that isnt a M8 metric lead screw.
