    First Layer and Extrusion Problems
    6.0k
    • Frederikundefined
      Frederik
      ok ,looks good so far. i startet my first 20mm xyz test cube 🙂 fingers crossed , i hope it will run through without clogging
      • Frederikundefined
        Frederik
        This is my very first successful Print:
        It should be 20x20x20
        And the actual dimensions are
        X 20.10 MM WITH STEPS 160
        Y 20.10 MM EITH STEPS 160
        Z 20.40 MM WITH STEPS 400
        • Vetiundefined
          Veti
          you have not calibrated you e steps yet
          Frederikundefined 1 Reply Last reply Reply Quote 0
          • Frederikundefined
            Frederik @Veti
            @Veti i forgot E 830
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti @Frederik
              @Frederik said in First Layer and Extrusion Problems:
              i forgot E 830
              i dont know what you mean by that
              here is a guide on how to calibration it
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
              • Frederikundefined
                Frederik @Veti
                @Veti My extruder steps are correct. 100mm are 100mm
                • Vetiundefined
                  Veti
                  the bottom looks a bit strange, did you enable raft?
                  • Frederikundefined
                    Frederik @Veti
                    @Veti brim was activated. but i´m struggling with the z offset a little bit. sometimes its really good , on the next try its scrubbing over the bed.
                    The cube was also printed on the backside of my buildplate. not the pei side to avoid any additional damage to my surface. 😞
                    i adjusted the bed to the subframe assembly with my digital calipers to ~ 0.05mm equal distances.
                    then i checked my bltouch mountig if it is perpenticular to the bed. that is also good.
                    then i homed z.
                    after that a true bed level with G32
                    another G32
                    Then mesh compensation with G29 and another G32 to Load the new Heightmap.
                    Now im testing with ABS Filament. because the pla before was constantly clogging in the heatbreak.
                    i adjustet my retraction to 1mm with 25mm/s speed and will see if it will be better. i have zero stringing with these settings.
                    • Vetiundefined
                      Veti @Frederik
                      another G32
                      that is not a good idea. the G32 after the G29 will mess up the mesh. also after running G32 you need to establish a new Z
                      Frederikundefined A Former User? 2 Replies Last reply Reply Quote 0
                      • Frederikundefined
                        Frederik @Veti
                        @Veti oh, I didn't know that. Then I won´t do a G32 after the G28 anymore 🙂
                        is the software handling everything after the G32 automatically from the heightmap every time I start a new print?
                        • A Former User?
                          A Former User @Veti
                          @Veti said in First Layer and Extrusion Problems:
                          If you have a bed.g like below you already re-establish the Z datum all in one go.......
                          ; bed.g
                          G28                         ; Home all
                          G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw
                          G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw
                          G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw
                          G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw (Second Pass)
                          G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw (Second Pass)
                          G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw (Second Pass)
                          G91                         ; Switch to relative positioning moves
                          G1 H2 Z5 F8000              ; Drop the Z axis (the bed) by 5mm relative to its current position
                          G90                         ; Revert back to absolute positioning moves
                          G1 X160 Y155 F8000          ; Position the nozzle at the centre of the bed
                          G30                         ; Probe and set the height as probed
                          G29 S1 P"heightmap.csv"     ; Load the height map
                          • A Former User?
                            A Former User @Frederik
                            G32 must be initiated AFTER the printer has homed all axises otherwise the printer has NO reference to work from.
                            Here is what the Duet G-Code dozuki lists G28 & G32 as :
                            G28 Home
                            Example
                            G28 ; Home all axes
                            The purpose of homing is to allow the printer to obtain a reference of where it is in space.
                            G32: Run bed.g macro
                            Parameters
                            None
                            Example
                            G32:
                            The firmware executes macro file bed.g. This macro normally uses G30 commands to probe the bed and then perform auto calibration of a delta printer (see Calibrating a delta printer), or perform bed leveling by moving the Z leadscrews independently, or display the manual corrections needed to the bed levelling screws.
                            So if you do not carry out G28 before you attempt to carry out G32 you will receive and error message ; Not enough axises homed
                            Unless the printer was already homed which is what G28 does anyway.....
                            • Frederikundefined
                              Frederik @A Former User
                              @CaLviNx Thank you, then i think is everything ready. i startet to print a fanchroud out of ABS. im very curious how it comes out.
                              what would i have to change in my config.g to use a capazitive sensor with 3 wires ?
                              is the connection on the duet 3 like: +5V, GND, and io.in ?
                              what musst be changed in these lines ?
                              M950 S0 C"io7.out"                                    ; create servo pin 0 for BLTouch
                              M558 P9 C"^io7.in" H5 F120 T6000                      ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y0 Z1.8                                 ; set Z probe trigger value, offset and trigger height
                              the last point , i want to change my mechanical endstop switches to optical ones.
                              But what i am doing, the endstopps are lighting up but i cant get them to trigger.
                              i´ve got 2 different ones.
                              one with high level when no trigger
                              and one with low level when no trigger
                              but i cant get the mo work
                              A Former User? Vetiundefined 2 Replies Last reply Reply Quote 0
                              • A Former User?
                                @Frederik561
                                Im sorry i only used that type of Z sensor when i first started with the duet years ago, I found them to be very unreliable, they were very susceptible to temp changes , so I have forgotten how I wired them up. I only use the Duet IR sensor now
                                It would appear they would be as you say VCC, GND, SIG which would correspond with what you wrote.
                                there is a section in the Dozuki on Z-Probes
                                As for the optical end stops again I dont use them, I only use Omron mechanical switches, they operate fine even at high temps in a chamber.
                                You might try inverting the signal on either of those two switches to see if that gets them working, or another thing is to check to see what triggers them, i dont know they might be looking for a metal or a dark colour to trigger them if they are an optical IR sensor
                                • Frederikundefined
                                  @CaLviNx how do you like the mini ir sensor ? is it working better than the bltouch ?
                                  • A Former User?
                                    Well that's a touchy subject for me at the moment....
                                    I have 8 operational printers (and 1 core-xy in the build stage) at home, 6 of those that are running have Duet-3 's (with LC-1 tool-boards) 2 have Duet-2 wifi's installed.
                                    All have IR Sensors fitted. The Duet-2 machines are still running RRF-2 as they just run and run and print day in day out without issue and have ran for years and years without issue.
                                    The Duet-3 boards (all with LC1 Tool-boards) all suffer from an intermittent issue of the IR sensor triggering too soon (as in triggering when the head is about 20mm from the bed surface) doesnt happen all the time, you can boot and home and they home fine to the correct height. then you can go to home and the sensor triggers at 20mm again, I can overcome it by issuing a G92 Z30 command and manually driving the bed up very close to the head then homing Z again and this time it reads and prints correctly.(it is not the print surface as this happens on a few differing surfaces and if it was the print surface it wouldn't explain why it only happens intermittently)
                                    As of the other day i updated my boards (and tool boards) to the newest firmware and the issue seems to be gone but we will see.
                                    On the Duet-2's with older firmware, NO issues ever.
                                    And as much as I personally dont like the Bl-Touch (I dont like moving parts of the pin which can get bent, and I dont like the packaging issues in mounting it), I do have a genuine one here, I did test it when I started getting early trigger issues on the IR sensor and it worked fine.
                                    • Vetiundefined
                                      Veti @Frederik
                                      see
                                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
                                      or
                                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_PNP_output_normally_open_inductive_or_capacitive_sensor
                                      • Frederikundefined
                                        Frederik @Veti
                                        @Veti Thank you.
                                        Do you have an idea why I can't get optical switches to work? the LED on the sensor work and trigger, but the duet doesn't recognize it
                                        • Frederikundefined
                                          @CaLviNx WOW, 8 operationl Printers ? Thats amazing. Do you make a living out of printing ?
                                          Ok, good to know, i was thinking about getting one for testing purposes.
                                          • Vetiundefined
                                            Veti @Frederik
                                            maybe you switched signal and ground. how did you connect it. the lerdge endstop work fine in my delta.
                                            btw only black objects will really block the light.
