    when will the new Z-height actually be saved?
    2.2k
      ;Generated with Cura_SteamEngine 4.8.0
      T0
      M190 S60
      M104 S210
      M109 S210
      M82 ;absolute extrusion mode
      G32
      G21 ;metric values
      G90 ;absolute positioning
      M82 ;set extruder to absolute mode
      M107 ;start with the fan off
      G28 ;Home
      G1 Z15.0 F1000;short move
      G92 E0 ;zero the extruded length
      G1 F200 E3 ;extrude 3mm of feed stock adjust so I don't have to remove any filament
      G92 E0 ;zero the extruded length again
      G1 F4000 ;move to bed
      ;Put printing message on LCD screen
      M117 Printing...
      ;G5; this is in order to resume on Power failure (only works on SD prints)
      M83 ;relative extrusion mode
      G1 F3000 E-8
      ;LAYER_COUNT:99
      ;LAYER:0
      M107
      G0 F3600 X-20.499 Y-9.085 Z0.25
      ;TYPE:SKIRT
      G1 F3000 E8
      G1 F1800 X-20.49 Y-9.761 E0.02459
      G1 X-20.438 Y-10.692 E0.03392
      G1 X-20.306 Y-11.615 E0.03392
      I think you should remove the G32 from the Extruder start gcode. That's not a usual place to put it.
      Also remove the G28 from bed.g. It's better to keep the commands separate so it's more clear about what is happening when.
      Then change your start gcode in cura to be this
      G21 ;metric values
      G28 ;Home
      G32 ; calibration
      M117 Printing
      • holco62undefined
        holco62
        Works perfectly now 👍 👍 👍
        https://youtu.be/tdl2iDNiC9Q
        What did the line "G1 Z15.0 F1000; short move" that has now been removed?
        Btw, I think it's really remarkable that you can remember all those codes 👌
        Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
          Phaedrux Moderator @holco62
          @holco62 said in when will the new Z-height actually be saved?:
          Nothing useful.
          holco62undefined 1 Reply Last reply Reply Quote 0
          • holco62undefined
            holco62
            Another question 😊
            If the printer runs the G32 calibration, the nozzle leaves a little filament on each calibration spot, now I wondered if it is possible that after each print job, for example, 50mm retraction takes place so that the hotend is always free of filament, and that after the G32 calibration the 50mm (or more) is immediately re-fed.
            • holco62undefined
              holco62 @Phaedrux
              @Phaedrux said in when will the new Z-height actually be saved?:
              Nothing useful.
              Haha, oké
