    A solution to shutdown Duet and SBC
    905
    • chas2706undefined
      chas2706
      If anyone is interested I have a solution that synchronises shutdown between the Duet and SBC.
      Complete shutdown of both Duet and SBC is performed by pressing the atx power button in DWC.
      Without this solution there are two problems, firstly the power relay or SSR does not latch until the pi has fully booted and has run config.g where M80 exists.
      Secondly, there is no facility to shutdown both the SBC and Duet together.
      For the solution you just need an arduino and a relay or SSR of which are very cheap - and a bit of coding for the arduino.
      Anyone interested ?
      If so I will upload the code.
      semi55undefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR
        Have you seen execonmcode?
        • chas2706undefined
          chas2706
          @PCR said in A solution to shutdown Duet and SBC:
          Yes and used it too.
          The problem with that IMO is that all is ok until the next firmware update.
          When it happened to me it caused major problems with the Duet firmware operation. Then you have to disable it and wait for the updated version - and RRF is changing all the time.
          • chas2706undefined
            chas2706
            execonmcode would be a great solution if it became a built in plugin and therefore updated everytime.
            • chas2706undefined
              chas2706
              ....but you would still have to hold the power button for 30+ seconds on start up until the SBC boots and has read the config.g file that contains the M80 command to latch the power relay or SSR.
              • A Former User?
                A Former User @chas2706
                @chas2706 said in A solution to shutdown Duet and SBC:
                you never know, wilriker might just get around to it when the dust settles and the plugin interface is released along with RRF 3.2
                anyways, without having seen the elaborate design, can't help think the arduino is a bit overkill and having the SSR latch before the pi has booted could be solved with a pull up resistor?
                • chas2706undefined
                  chas2706
                  @bearer said in A solution to shutdown Duet and SBC:
                  You got me re-visiting execonmcode and wondering why I stopped using it.
                  The answer is easy. It is not a solution to enable remote shutdown of the whole system.
                  shutdownsbc.service will shut down the SBC but then you cant power off the duet because you no longer connected!
                  So my solution involving a £2.50 arduino uno surely cannot be overkill?
                  • dhusoloundefined
                    dhusolo
                    I'd be interested in checking this out
                    • A Former User?
                      A Former User
                      I guess I don't see why the duet can't turn the ssr of itself after having asked the pi to turn off. any feedback the arduino get, the duet could get, or a simple G4 would do the trick to let the pi shutdown with a minimum of grace
                      so it might not be overkill in terms of $, but added complexity imho (without having seen it ofc..)
                      • chas2706undefined
                        chas2706
                        Don't get what you saying. How can you shut the rest of the system down after SBC is down? You no longer have connection or control. You could send a G4 delay but then the pi is in shutdown process and duet has no control, the pi is dead. The pi needs to shut down first, then duet. Pi can't shut down duet after it is shut down itself and you now have no control over duet????
                        • A Former User?
                          A Former User
                          If the Duet can't keep a command or two in its pipeline then there is no need to turn the pi off-off*, enough to save whatever state you wanna keep and go read-only before telling the Duet to pull the ssr low, or move the ssr to the Pi. But you've made your point, not gonna beat a dead horse.
                          *)it will poweroff when duet power off the psu, being in a clean state already. if holding a physical button for 30 seconds was the problem to solve then it follows there is no need for a 5v stand-by supply (or it could be powered down along with Vin as it serves no purpose after the Pi is done.
                          • chas2706undefined
                            chas2706
                            If the Duet can't keep a command or two in its pipeline then there is no need to turn the pi off-off, enough to save whatever state you wanna keep and go read-only before telling the Duet to pull the ssr low, or move the ssr to the Pi. But you've made your point, not gonna beat a dead horse.
                            My last word.... If you need a complete power down, In your senario you power down the duet and leave the pi shutdown but not powered off. No point beating a dead horse!
                            • semi55undefined
                              semi55 @chas2706
                              @chas2706 I would be interested, could you please upload your code?
