Heat problems with Smart Effector
386
  • undefined
    rodsmith
    I'm having problems with the power to my hotend heater cutting out. I originally had a v1.3 with this problem. I repeatedly re-wired and replaced the cable-end connector, tested continuity, etc. It appeared that the connectivity would break as the effector moved around. After a thermal fault event, I could usually recover temporarily by jiggling the "input 1" connector, but the problem would always recur, often multiple times per print. The only thing I could find that would help for longer periods was to jam a small amount of aluminum foil into the connector, which presumably made for a more stable connection. Eventually, though, the Smart Effector gave out completely; it failed and I just couldn't get it to recover.
    I replaced it with a new v2 Smart Effector, but it's begun to develop the same problem. Again, I completely replaced the cable-end connector with one with a built-in strain relief, but the problem has recurred and is just getting worse, after less than a month with the new Smart Effector.
    Does anybody have any tips on how to get this to work reliably? Thanks!
    undefined 1 Reply Last reply 26 Nov 2020, 16:45 Reply Quote 0
    • undefined
      Adrian52 @rodsmith
      @rodsmith I bought this prewired strain relieved one from digikey
      https://www.digikey.co.uk/product-detail/en/molex/0451320610/WM16121-ND/6208008
      and had no further problems.
      • undefined
        rodsmith
        I bought something similar, but it's not really helped. I can't seem to find my order confirmation, so I'm not positive exactly what I got, but I think it was this:
        https://www.digikey.co.uk/product-detail/en/molex/2451320605/WM15769-ND/6565376
        It helped with one fan connection that was similarly unreliable, but it didn't really help with the heater cartridge connection. I tried this originally with the v1.3 board that's now completely shot. When the problem began to recur with the v2 board, I started over with a new Molex connector, but it's not helped. I'm considering bypassing the Smart Effector entirely and wiring the heater cartridge straight into the supply wires.
        undefined 1 Reply Last reply 26 Nov 2020, 18:01 Reply Quote 1
        • undefined
          Alex.cr
          I strain relived the whole cable by ziptieing the first 2 inches of the wire bundle to the Bowden tube coming from my extruder. I haven’t had any issues with cables breaking. Just a thought.
          Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
          undefined 1 Reply Last reply 26 Nov 2020, 18:13 Reply Quote 0
          • undefined
            Carlo @rodsmith
            @rodsmith
            Lengthen your cables and add something like
            https://www.amazon.co.uk/Retracting-Badge-Retractable-Carabiner-Individually/dp/B0016BVOM0
            • undefined
              dc42 administrators @Alex.cr
              @Alex-cr said in Heat problems with Smart Effector:
              That's what I did too. Wires that flex close to their terminations always need strain relief.
              undefined 1 Reply Last reply 26 Nov 2020, 18:34 Reply Quote 0
              • undefined
                rodsmith @dc42
                Thanks for the suggestions. I'm using a Zesty Nimble, so there's no Bowden tube, but the Nimble's drive cable should serve the same purpose. FWIW, I've been using this with the wires tied to one of the diagonal rods for strain relief, but I suppose the Bowden tube/Zesty Nimble cable might work better.
                • undefined
                  Alex.cr
                  You are using a high quality cable connection that I can’t imagine that would be the problem when it’s new. The nimble’s drive cable will flex less than an arm will. I would think it would help. The only other suggestion would be to use silicone wiring but I don’t think that would help much over you’re pre assembled wire bundle.
                  1 out of 8
