    Part Cooling Fan Reprap 3
    59
    • jaurand
      jaurand last edited by
      Hello I cannot for the life of me get my part cooling fan to work
      Part Cooling fan is plugged into fan 1 and heatsink fan is plugged into fan 2. I shorted the mosfet on the board for fan 0 so I shifted everything down. When I plug the part cooling fan into the always on pins, spins up no trouble.
      The heat sink fan works just fine. Turns on at 45C as expected.
      M950 F0 C"fan1" ; create fan 0 on pin fan1
      M106 P0 C"PartCoolingFan" ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"fan2" ; create fan 1 on pin fan2
      M106 P1 C"Heatsink" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
      • jaurand
        Here is rest of Config.g
        ; generated by RepRapFirmware Configuration Tool v3.1.8 on Sun Nov 22 2020 22:50:11 GMT-0500 (Eastern Standard Time)
        M550 P"Workstation 1" ; set printer name
        M669 K1 ; select CoreXY mode
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
        M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X-10 Y4 Z0 S1 ; set axis minima
        M208 X330 Y330 Z400 S0 ; set axis maxima
        M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
        M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
        M574 Z1 S2 ; configure Z-probe endstop for low end on Z
        M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P750 X-36.4 Y-4 Z2.73 ; set Z probe trigger value, offset and trigger height
        M557 X60:270 Y60:270 S15 ; define mesh grid
        M307 H0 A121.5 C394.6 D1.5 V23.9 B0 S1.00 ;disable bang-bang mode for the bed heater and set PWM limit
        M143 H0 S100 ; set temperature limit for heater 0 to 100C
        M307 H1 A592.9 C189.8 D3.1 V23.9 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
        M143 H1 S255 ; set temperature limit for heater 1 to 255C
          First can you send M115 and confirm you are using RRF 3.1.1?
          You're missing some parameters. Try:
          M106 P0 C"PartCoolingFan" S0 H-1
          That disables thermostatic mode and allows it to be controlled manually. Starting in the off position.
          • jaurand
            Here is M115 response
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2-beta3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-11-12
            I also updated the fan parameter to include M106 P0 C"PartCoolingFan" S0 H-1 and still no response when setting the fan selection to 100%
              Phaedrux Moderator @jaurand last edited by
              @jaurand said in Part Cooling Fan Reprap 3:
              Where are you setting this?
              From the console try sending M106 P0 S1
              jaurand 1 Reply Last reply Reply Quote 0
              • jaurand
                jaurand @Phaedrux last edited by jaurand
                @Phaedrux I'm moving the slider on he dashboard.
                When I try M106 the fan remains off
                  How do the mosfets look? I wonder if the short that killed the other header has weakened the others and now it has failed as well.
                  • jaurand
                    @Phaedrux I thought they looked fine
                    How hard are they to replace? As long as I know what I'm looking at I can resolder new ones in. Or pivot to a heater pin to use for the fan
                    • jaurand
                      Here is the fan mosfets
                        Sorry that photo is too blurry to make them out clearly. They are the little black chips with 3 legs beside the fan ports.
                        They are replaceable. They can also be tested to check if they are working or not.
                        https://www.google.com/search?q=how+to+test+a+mosfet&oq=how+to+test+a+mosfet&aqs=chrome..69i57j0l5.2615j0j7&sourceid=chrome&ie=UTF-8
