    MK2A Heated Bed causes board to crash
    2.4k
    • BoAundefined
      BoA @bdelia
      @bdelia at 1.7Ohm it would draw just over 14A of current!
      • Vetiundefined
        Veti
        that is defiantly not a dual voltage bed.
        • BoAundefined
          BoA @bdelia
          @bdelia According to reprap wiki - MK2b Dual power is what you expected. MK2a seems to be be a single power heatbed (and probably 12V). And in general dual power heatbed has 3 solder pads.
          • Vetiundefined
            Veti
            however something is still wrong here.
            a 600W meanwell power supply should be able to handle that.
            BoAundefined 1 Reply Last reply Reply Quote 0
            • BoAundefined
              BoA @Veti
              Perhaps the wire is too thin, and passing 14A+ (14A is bed alone) causes significant voltage drop.
              • Vetiundefined
                Veti
                yes. you would need a 2mm^2 wire for that.
                bdeliaundefined 1 Reply Last reply Reply Quote 0
                • bdeliaundefined
                  bdelia @Veti
                  @Veti said in MK2A Heated Bed causes board to crash:
                  2mm^2
                  I am using 14Gauge wire from my external Mosfet to the Bed.
                    If you set your multimeter to read resistance and then short the two probes together, what reading do you get? You need to subtract that reading from the 1.6 ohms that you measured.
                    • bdeliaundefined
                      bdelia @dc42
                      @dc42 said in MK2A Heated Bed causes board to crash:
                      When I read resistance by shorting the MultiMeter leads it reads .2 Ohms. So, if I understand you then that would mean my bed resistance, if measured at 1.6 is really 1.4 Ohms?
                      If the above is accurate then it seems the bed is on the fringe of 24V compatible? Does that sound correct?
                        Does your board have 2 solder pads or 3? The photo is a bit blurry.
                        @bdelia said in MK2A Heated Bed causes board to crash:
                        No. 1.4ohms would still indicate 12v. I think you're hoping pretty hard that this is just going to somehow work. I think your seller is clueless and is leading you astray. There's no way I would connect 24v power to that heatbed and leave it unattended in my own house.
                        • bdeliaundefined
                          bdelia @Phaedrux
                          @Phaedrux said in MK2A Heated Bed causes board to crash:
                          No. 1.4ohms would still indicate 12v. I think you're hoping pretty hard that this is just going to somehow work. I think your seller is clueless and is leading you astray. There's no way I would connect 24v power to that heat bed and leave it unattended in my own house.
                          Thanks for your thoughts. I have sent an email to my supplier for the bed and am waiting for a response. Worst case I am out about $50 for the bed and will have to source another one.
                          Does anyone here have a recommendation for a 24V 300x300 heated bed? I would prefer to source in the USA if possible for shipping timeliness.
                          Thanks
                          Brett
                            https://www.filastruder.com/products/e3d-varipower-heated-bed-pack?_pos=1&_sid=80bc0b874&_ss=r
                            Not sure if that suits your bed shape though.
                              Do you have a link to the item you've purchased?
                              • Vetiundefined
                                Veti
                                e3d makes 300x300 beds
                                https://e3d-online.com/collections/printer-parts-electrical/products/high-temperature-heated-beds
                                but they are ac beds.
                                their variopower bed 24v is only available in 300x200
                                https://e3d-online.com/collections/printer-parts-electrical/products/varipower-bed
                                you could try and source a voron 2 buildplate with a Keenovo heat pad
                                https://store.digmach.com/collections/voron-parts/products/build-plate-for-voron-2-3d-printer?variant=31774400675885 (us store but sold out, you could ask on the voron discord for other suppliers)
                                the matching kenoovo heater is avaiable in 24v (though voron guide says go with ac version at nearly twice the power)
                                https://keenovo.store/collections/standard-keenovo-silicone-heaters/products/keenovo-square-silicone-heater-3d-printer-build-plate-heatbed-heating-pad?variant=8324020895799
                                but to be honest if you are going for a 300x300 bed, you are in the territory of ac beds.
                                  https://www.amazon.com/310x310mm-Aluminum-HeatBed-Thickness-Creality/dp/B07H8DXVQD/ref=sr_1_6?dchild=1&keywords=cr-10+heated+bed&qid=1607369292&sr=8-6
                                  • JamesMundefined
                                    JamesM
                                    You could get a nice cast aluminum bed and put a 24v silicone heater on it. 713maker.com has some nice stuff. This is a 300x300 bed https://713maker.com/ft-5/ft-5-heated-bed
                                    • bdeliaundefined
                                      bdelia @Phaedrux
                                      Here is a link to what I purchased:
                                      http://www.zyltech.com/zyltech-3mm-aluminum-heated-heat-bed-3-sizes-available/
                                      If you look at the description I purchased the one labeled as 300 x 300 MK2A Heated Bed.
                                      300 x 300mm MK2A Heated Bed
                                      Outside dimension: 330x330 mm
                                      Usable size: 300x300mm
                                      Resistance: 1.05-1.3 ohm
                                      Voltage: 12-24 V (recommend 24V for better performance)
                                      Pre-wired with thermistor and power cable
                                        Thanks. That helps.
                                        In that case your measurement of 1.4 ohms is closer to the 1.3 ohms they specify.
                                        Still not clear how it's capable of 12 or 24 without different wiring, but at least Zyltech is a recognizable brand and not just some ebay seller or something.
                                        • A Former User?
                                          A Former User @Phaedrux
                                          From the specs it is effectively a powerful 24V bed, at 24V it is nominal 0.52W/cm^2 which is a little over the recommended 0.4 and at 12v it is at 0.13W/cm^2 which is borderline useless imho - so calling it dual voltage is BS.
                                          At 24W and 1R05 to1R3 it's 550W to 450W and 23-18A, but OP is using a external mosfet so that should be fine, leaving voltage drop due to thin wiring or power supply over current protection kicking in (prematurely).
                                          Phaedruxundefined BoAundefined 2 Replies Last reply Reply Quote 1
                                            Phaedrux Moderator @A Former User
                                            @bearer said in MK2A Heated Bed causes board to crash:
                                            Ok that makes more sense and explains why the reviews of the heater say using it at 12v is pointless because it can't reach even moderate temps.
