Incredibly slow print speed
Hi Chaps, finally got my corexy printer working and new "genuine paneldue " after ali express refunded my faulty clone. Im running the duet2 ether, I purchased simplify 3d and run test print but got bad warping with pla , with same hardware as before which never warped, so I went back to Cura slicer to test same print, problem is , printing is now incredibly slow ??? cura slicer says 50mm/sec but printing is more like 1mm / sec any help appreciated.
I've made the mistake of having the speeds in Simplify 3D set to mm/minute instead of mm/second.
50mm/minute is about 1mm/second.
Is that your problem?
@alankilian Thanks for reply this test piece was sliced in Cura and Ive just checked and it is set at 50mm / sec in cura so not sure if thats the answer or no
@GG Post both your GCODE files. That will tell for sure.
Or at least one G1 move with an extrusion from each file.
I would bet that your cure slicer start gcode has some speed limits defined which are limiting your speeds.
@alankilian ;FLAVOR:Marlin
;TIME:6876
;Filament used: 5.53586m
;Layer height: 0.15
;MINX:116.513
;MINY:116.511
;MINZ:0.3
;MAXX:213.486
;MAXY:213.489
;MAXZ:15
;Generated with Cura_SteamEngine 4.8.0
M140 S55
M105
M190 S55
M104 S200
M105
M109 S200
M82 ;absolute extrusion mode
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset FlowrateG28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G1 Z2.0 F3000 ;Move Z Axis upG92 E0
G92 E0
G1 F1500 E-6.5
;LAYER_COUNT:99
;LAYER:0
M107
G0 F6000 X130.894 Y130.531 Z0.3
;TYPE:SKIRT
Hi this is the cura gcode , having trouble getting simplify 3d code
@GG said in Incredibly slow print speed:
you are setting the speed to about 8mm/sec here
Delete the M201 M203 and M204 lines and restart your printer
@Veti You beat me to it!
What a great community we have here.
Delete M205 as well.
@Phaedrux I removed the sugggested above gcode from the start gcode in cura in machine settings and akso changed gcode flavour to reprap but still runs at snailpace
did you restart the printer afterwards?
Post your config.g as well.
If you post your GCODE we can take a look again.
@Phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 06 2020 16:21:04 GMT+0800 (中国标准时间); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; core xy mode
M555 P2 ; set output to look like marlin
G21 ; work in mm,s
M552 S1 ; enable network
M552P 192.168.1.12 ;
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S1 ; physical drive 3 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
;Dual Z
M584 X0 Y1 Z2:4 E3 ;
M671 X-100:415 Y160:160 S2.0 ;
M92 X80.00 Y80.00 Z400.00 E396.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X 0 Y-15 Z0 S1 ; set axis minima
M208 X310 Y310 Z380 S0 ; set axis maxima; Endstops
M574 X1 Y1 S0 ; set active low and disabled endstops
;Filament Run Out Sensor
M591 D0 P1 C4 S1; Filament run out sensor for extruder E0 on E1 end stop input P1 = signal HIGH .
M574 Z1 S2;M558 P1 H5 F600 T6000 A10 S0.03 I1 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 1
M305 P2 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 2
M143 H2 S280 ; set temperature limit for heater 2 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1:2 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 S"Extruder" ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CG31 .65; set z offset
T0; This is curent gcode
M302 P1;FLAVOR:RepRap
;TIME:6876
;Layer height: 0.15
;MINX:116.513
;MINY:116.511
;MINZ:0.3
;MAXX:213.486
;MAXY:213.489
;MAXZ:15
T0
M190 S55
M104 S200
M109 S200
G1 Z2.0 F3000 ;Move Z Axis upM83 ;relative extrusion mode
G1 F1500 E-6.5
;LAYER_COUNT:99
;LAYER:0
M107
;TYPE:SKIRT
G1 F1500 E6.5
M575 P1 S1 B57600; Enable paneldueThis is the curent config g and yes I did restart machine, just tried it again with same result. Strage thing is the printer worked fine when slicing with simplify 3d but the print warped and the vertical sides of the cylinder were wasted in the middle , I ve never had warping before with the old cheapo mini chitu board ??? atached below is current start gcode
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup JerkIf this is the same gcode file as before you would need to delete it and re-slice after you've removed those lines from the start gcode.
@Phaedrux that seemed to solve the speed issue, so I printed same cylinder shape but the print quality is awful, as I saids the vertical sides of the cylinder are waisted in the middle , scalloped I guess when they shoule be strait, the old mini board used to print these fine, coule it be the mother board the problem I wouldnt have thought so. ???
M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)In your config.g file change the Z acceleration and jerk values to be a bit higher. As they are now they would cause some problems with mesh compensation.
Try
M566 Z60
M201 Z200Can you share a photo of what you mean about the quality issues?
