    why my web status always starting ?
    391
    • huai3895undefined
      huai3895
      3.2.0-beta4.1
      the status should show ''normal'' or ''busy'', but it just show ''Starting''now, and mabe that make my "trigger2.g" cant work by m581
        More detail please.
        Where are you seeing "starting" ?
        Can you confirm your firmware version with M122?
        Have you updated the DWC as well?
        If this is with a PanelDue can you confirm you have up to date firmware there as well?
        huai3895undefined 1 Reply Last reply Reply Quote 0
        • huai3895undefined
          huai3895 @Phaedrux
          @Phaedrux
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
          Board ID: 08DJM-956BA-NA3TN-6J9D6-3S86M-TVB6T
          Used output buffers: 1 of 40 (13 max)
          I have update my duet pi to beta, and i dont have panedue.
            post your config files
            • huai3895undefined
              huai3895 @Phaedrux
              This post is deleted!
                Send M98 P"config.g" and report the results
                huai3895undefined 2 Replies Last reply Reply Quote 0
                • huai3895undefined
                  huai3895 @Phaedrux
                  @Phaedrux
                  • huai3895undefined
                    huai3895 @Phaedrux
                    @Phaedrux
                    I can see what you mean mabe. I'll check the config line by line
                      Did it work with firmware 3.1.1 and DWC 3.1.1?
                      Are you using a raspberry pi as well?
                      Can you connect via USB and try M122 and the M98 command?
                      huai3895undefined 3 Replies Last reply Reply Quote 0
                      • huai3895undefined
                        huai3895 @Phaedrux
                        @Phaedrux
                        yes ,it work with 3.1.1,
                        yes,im using a raspberry pi(duet pi)
                        And i will try usb,but it may take time
                        • huai3895undefined
                          huai3895 @Phaedrux
                          @Phaedrux Found the reason,if i del m501,everything normal,because i dont have configoverride at sys/.
                          • huai3895undefined
                            huai3895 @Phaedrux
                            @Phaedrux
                            Thanks every much,m98 p"config" give me inspire.
