Det 3d 6hc using expansion 1XD, stepper not moving
; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 11:43:55 GMT+0530 (India Standard Time); General preferences
M550 P"Duet 3" ; set printer name; Drives
;M569 P0.0 S1 ; physical drive 0.0 goes forwards
;M569 P0.1 S1 ; physical drive 0.1 goes forwards
;M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards (Extruder)
M569 P40.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (X-axis)
M569 P41.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Y1-axis)
M569 P42.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Y2-axis)
M569 P43.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Z1-axis)
M569 P44.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Z2-axis)
M584 X40.0 Y41.0:42.0 Z43.0:44.0 E0.0 ; set drive mapping
;M584 X40.0 Y41.0 Z43.0 E0.0 ; set drive mapping (single X,Y,Z & E)M350 X11 Y1 Z1 E16 I1 ; configure microstepping with interpolation
M92 X3200.00 Y3200.00 Z3200.00 E90.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
M906 X7000 Y7000 Z7000 E2000 ; set motor currents (mA)
M84 S0 ; Disable motor idle current reduction; Axis Limits
M208 X230 Y230 Z230 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!^40.io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
M574 Y1 S1 P"!^41.io1.in" ; configure active-high endstop for low end on Y1 via pin !^io1.in
M574 Y1 S1 P"!^42.io1.in" ; configure active-high endstop for low end on Y2 via pin !^io1.in
M574 Z1 S1 P"!^43.io1.in" ; configure active-high endstop for low end on Z1 via pin !^io1.in
M574 Z1 S1 P"!^44.io1.in" ; configure active-high endstop for low end on Z2 via pin !^io1.in; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:220 Y15:220 S20 ; define mesh grid; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B5000 ; configure sensor 0 as thermistor on pin temp1
M950 H0 C"out2" T0 ; create bed heater output on out2 and map it to sensor 0
M308 S1 P"temp0" Y"thermistor" T100000 B5000 ; configure sensor 1 as thermistor on pin temp0
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S230 ; set temperature limit for heater 1 to 230C; Fans
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M575 P1 S1 B57600
M570 H0 P999 S240
M552 S1
M552 192.168.0.120; Miscellaneous
@dkraja42 showing error on stepper driver :
Er 03: Position error; The position deviation counter exceeds the set value
@dkraja42 0.0 is undefined and microstepping 11 is unusual:
but only 0.3 defined.
don't know whether 11 is valid, I expect not.
Can you send M122, M122 B1, and M98 P"config.g" and post the results?
As @Phaedrux says, but also post the results of sending M122 B40, M122 B41, M122 B42, M122 B43 and M122 B44.
