Manual Bed Leveling Assistant huge values returned
  • Hey there,
    I believe I have my Duet set up properly for using the Manual Bed Leveling Assistant, but I get ridiculously high values return from its output:
    Manual corrections required: 0.00 turn up (0.00mm) 3743725.00 turn down (1871862.50mm) 3743724.75 turn down (1871862.38mm) 3743724.00 turn down (1871862.00mm)
    Here is my config.g:
    ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sat Dec 05 2020 14:37:53 GMT-0800 (Pacific Standard Time)
    G90                                            ; send absolute coordinates...
    M83                                            ; ...but relative extruder moves
    M550 P"BD-HEVO"                                ; set printer name
    M669 K1                                        ; select CoreXY mode
    M552 P192.168.0.69 S1                          ; enable network and set IP address
    M553 P255.255.255.0                            ; set netmask
    M554 P192.168.0.1                              ; set gateway
    M586 P0 S1                                     ; enable HTTP
    M586 P1 S0                                     ; disable FTP
    M586 P2 S0                                     ; disable Telnet
    M569 P0 S1                                     ; physical drive 0 goes forwards
    M569 P1 S1                                     ; physical drive 1 goes forwards
    M569 P2 S1                                     ; physical drive 2 goes forwards
    M569 P3 S1                                     ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                               ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z400.00 E409.00              ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z300.00 E1200.00        ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                        ; Set idle timeout
    M208 X0 Y0 Z0 S1                               ; set axis minima
    M208 X265 Y280 Z410 S0                         ; set axis maxima
    M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
    M558 P5 C"^!zprobe.in" I0 H5 F120 T6000        ; set Z probe type to switch and the dive height + speeds
    G31 P500 X-25.914 Y-53.86 Z0.882               ; set Z probe trigger value, offset and trigger height
    M557 X26:239 Y54:226 S20                         ; define mesh grid
    M671 X26:26:239:239 Y54:226:226:54 P0.5          ; point1 (26,54), point2 (26,226), point3 (239,226), point4 (239,54)
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 B0 S0.90                               ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                        ; map heated bed to heater 0
    M143 H0 S100                                   ; set temperature limit for heater 0 to 100C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
    M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
    M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
    M563 P0 D0 H1 F0                               ; define tool 0
    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
    M501                                           ; load saved parameters from non-volatile memory
    T0                                             ; select first tool
    And my bed.g file:
    ; bed.g
    ;M561 ; clear any bed transform
    ;G29  ; probe the bed and enable compensation
    G28 ; home
    ;G0 X0 Y0
    G30 P0 X26 Y226 Z-99999 ; probe near an adjusting screw
    G30 P1 X26 Y226 Z-99999 ; probe near an adjusting screw
    G30 P2 X239 Y226 Z-99999 ; probe near an adjusting screw
    G30 P3 X239 Y54 Z-99999 S4; probe near an adjusting screw and report adjustments needed
    G28 ; home
    Any help is greatly appreciated.
  • What does your height map look like ?
  • I have not created a height map yet. I am trying to set up my Capacitive NPN switch and the suggested steps include to first manually level the bed. I have done that by hand, now I wanted to get the Manual Bed Leveling Assistant working so I can dial in the bed level as best as possible before creating that height map.
    Do I have the steps wrong?
  • @bdelia
    just run a G29 and look at the image. it will help
  • @Veti said in Manual Bed Leveling Assistant huge values returned:
    @bdelia
    Ok, will do once I get back home. Thanks for the assistance in this.
  • Probing twice the same point?
  • Moderator
    @bdelia said in Manual Bed Leveling Assistant huge values returned:
    G28 ; home
    What is in your homeall?
  • @BoA said in Manual Bed Leveling Assistant huge values returned:
    Well that explains the double tap on that corner 😉 Thanks for the proofreading!
  • @Phaedrux said in Manual Bed Leveling Assistant huge values returned:
    G28 ; home
    Here is my homeall
    ; homeall.g
    ; called to home all axes
    G1 H2 Z5 F6000          ; lift Z relative to current position
    G1 H1 X-270 Y-295 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-270             ; home X axis
    G1 H1 Y-295             ; home Y axis
    G1 X5 Y5 F6000          ; go back a few mm
    G1 H1 X-270 F360        ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-295             ; then move slowly to Y axis endstop
    G1 X25.914 Y53.86 F6000 ; go to first bed probe point and home Z
    G30                     ; home Z by probing the bed
    ;G91                    ; relative positioning
    ;G1 Z5 F100             ; lift Z relative to current position
    ;G90                    ; absolute positioning
  • Ok, first off I want to thank this community for always being willing to help out.
    I think probing that one point twice that @BoA pointed out was the issue. I updated my bed.g file and all seems good now.
  • Moderator
    You may want to uncomment this, because you would want any mesh compensation or other bed surface alterations to be canceled when doing the leveling.
    Thanks for the tip
