Trianglelab Matrix Extruder somebody?
Hi *,
does anybody own one of the "Trianglelab Matrix Extruder"?
https://aliexpress.com/item/1005001723097241.htmlAnd if so: Are you willing to share some experience with me/us?
It is beginning of December, I hope that I get a new board soon, the frame is almost ready but the guys from E3D do restock the Hemera. So I plan to leave the valley of "original only" and I will pass the deep dell of doom aka "china noble scrap" till the guys from Brexit-Island decide to restock.
So what are your experience? Did it work out of the box? Is it reliable? Pros? Cons?
I would need two of it, so not a easy decision to buy them only to learn that they are completely waste of time and money.
Cheers, Chriss
@Chriss said in Trianglelab Matrix Extruder somebody?:
i dont think it will have arrived for people who have ordered it.
it was released around black friday and it takes some time with shipping.its not a direct clone from what i can gather.
they used their heatbreak from the dragon hotend.https://youtu.be/GREhHw2ynsc?t=49
not sure if i like that design.
Mine will come soon.
@PCR
Cool, how long will be his journey than? And to which continent? -
China Germany. Hopefully 2 weeks.
@PCR
Oh, I need to order soon than. -
they just releases a water cooled version.
https://de.aliexpress.com/item/1005001842881581.html
currently aliexpress standard shipping is 3-4 weeks to germany.
@Veti
Water cooled..... Hmmmmmm... That may change my mind. I have to think about that. It is a overkill for that printer, but a nice thing to play with. -
that is going to make enclosure printing a lot nicer.
@Veti
True, but my new build, a ratrig v-cast, will never be in a enclosure. But I hate this tiny fans, they are far to noisy. So why not getting rid of two of them? -
How is the general quality of TriangeLab?
I am contemplating another printer with up to 150C chamber temperature. Was planning to mill the fins off an Hemera and add a liquid cooling block, as well as mounting the stepper on a liquid cooling block to keep that one cool also.
This Matrix-LC thing fits the bill quite nice.
triangelabs is among the top stores on aliexpress if not the best store
Quality similar to E3D & co, then?
Or would trying to obtain and modify a genuine Hemera deliver a more robust extrusion? -
@DaBit It is always advisable to pay the inventor for there work.
It sure is, and in the end reliable operation and endurance is worth more than a few bucks, at least for me it is. Hemera uses hardened gears, what about TriangleLab, for example?
But, there are no liquid cooled Hemera's yet so if you want one you have to modify it yourself. I do have a CNC mill, so it can be done. Then there is only the next issue: try to buy one. Out of stock everywhere.
My quite unfinished idea about making the Hemera 150C-chamber-resistant (and my first FreeCAD experience; wanted to see if it is a viable alternative for Fusion, and I am only going to figure that out by doing a real project with it):
Cooling blocks are drawn as simple cross-drilled pieces of tooling plate. A bit of insulation around the stepper and they can keep cool enough. Would be fairly easy to make the Hemera block L-shaped. But still, if TriangleLab already offers a watercooled version and quality is decent...
@DaBit I fully agree and I do not wanted to start a clone/noclone discussion. I avoided the word clone so far for that reason.
The watercooling could be a very good reason than. I ordered two today and I will replace them with two original when they are available.That is a interesting implementation.
@Veti said in Trianglelab Matrix Extruder somebody?:
+1. Very good quality and good reputation in general and they often improve on the brand names (e.g. better silicon socks than E3D or smaller 5i paneldue).
How does the weight ( 414g) and esteps (335.4 with x16 microsteps) compare to the Hemera?
I think that my BMG + 150g 0.9deg steppers beat it on both counts.
@zapta said in Trianglelab Matrix Extruder somebody?:
my hemera weighed in at 368
@bearer said in Trianglelab Matrix Extruder somebody?:
That's pretty good. IIRC they have a larger than needed (?) stepper for a X3 geared extruder and could go even lighter.
as for watercooling, I do have a spare heatsink but haven't bothered milling it flat as the bearing support protrudes a little on the surface limiting the available area for potential flattening so bolting a cots water block to is probably won't fly. soldering a section of tubing to it proper-printing-style might work but
i think there has been talk of a pancake version, but whatever issues they're having seems to push that back. my next hemera will be the pankcake version and direct drive (maybe)
